Question about Emerson EWF2004 20" TV
V-chip reset television is connected only to dish receiver as 2nd monitor. cant find owners manual to reset v-chip
  • Anonymous Apr 19, 2009
    I tried this and it wont let me access the v-chip still.
  • Anonymous Jan 26, 2010
    I tried the access code 0000 but it did not work. My daughter was playing witht he remote and put in a pin number for the V-Chip but don't remember the number. I am trying to find out is there a reset number for the V-Chip.
    Sniper:
  • 140 Answers
1) Hit [MENU]. Press [CH up / down] to select ?V-CHIP SET UP?, then hit [VOL up]. 2) Enter 4-digit access code with the Number buttons. If you have not set up your personal access code, enter 0000 (default access code).
Posted on Sep 14, 2007
    New Friend:
I lost my controller is there a way i can put 0000 for my v-chip?
Posted on Jan 13, 2010
SOURCE:
How do I hook up my satilite dish to our motor home?
Most TVs don't have a built-in satellite receiver. You'll need to buy and install a suitable satellite receiver box for the signals that your dish is capable of receiving. The dish connects to the satellite receiver. Then the sat receiver connects to the TV via either AV cables or HDMI. Hope this helps.
Sep 16, 2014 | Televison & Video
Snow on tv cant get bk to pic
Hi nelle_king my name is MikeHouston of DISH Network. There are a couple things we can do to get thatpicture back. What you will need to do is make sure the TV is on channel 3 orthe right input, and if the picture is still snowy and we are on the correctchannel/input you will need to reset the receiver by unplugging it for 10seconds and plugging it back in. After you plug it back in it will power up byitself and you should see the DISH Network screen. I will send the steps tohelp with the setup. b> # Sequentially follow the below steps until problem is resolved or until instructed to skip to another step 1 Verify HDMI Connections Verify HDMI cables are connected from the DISH receiver HDMI Out to the HDMI In of the Revue, and the HDMI Out of the Revue to the HDMI In of the TV. 2 Reset Revue and DISH Receiver Unplug both the Revue and DISH receiver for 10 seconds and plug back in. It may take up to 5 minutes for the reset process to be completed. 3 Check Receiver-to-TV Configuration Check that the wiring between your DISH receiver and your TV is configured properly using http://www.dish.com/wiring. 4 Secure Receiver-to-TV Connections Check that the connections between your DISH receiver, your TV, and any component(s) (VCR, DVD Player, etc.) in between are secure. 5 Bypass Revue Bypass the Revue and directly connect the DISH receiver to the TV using an HDMI cable.
Feb 02, 2011 | Toshiba Televison & Video
I have a Sova monitor that I'm trying to hook up to DishNetwork. I get sound but no picture
We would be happy to help you with that. The first thing wewant to try is unplugging the receiver for 10 seconds that plugging it back in,it should take about 5 minutes to reset. We also want to ensure that the DISHNetwork receiver is connected to your TV correctly, please visit this link tosee how it should be connected:http://www.dishnetwork.com/SupportSection/setup-receiver. If you are able to,connect another component (VCR, DVD Player, etc.) to the same TV, using samecable, same input, and same channel to see if it works. If it still doesn'twork, the cable needs to be replaced, if it does work with the other componentconnected, give us a call at 1-800-333-DISH (3474) for some additionaltroubleshooting.
We hope these steps get your picture up and running. Thanks for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Nov 22, 2010 | Sova Digital DST207-S37C Television
I just switched dish networks and now I have a green tint on my Sony KDS-60A2000. My other TV is fine so it has to be something with this unit. I tried resetting, unplugging for several hours, and system...
Since you have already reset the receiver I would recommendchecking the connections between the receiver and your TV. Please visit thislink for information on connecting your DISH Network receiver to your TV:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. If afterchecking the connections you are still seeing a green tint give us a call at1-800-333-DISH (3474) for some additional troubleshooting. We hope thisresolves your issue. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Department
Sep 03, 2010 | Sony KDS-60A2000 60" HDTV
I bought a Dish remote for a2nd tv and cant get it
strmason,
Are you still having problems with programming the remote to your receiver? I am assuming it is TV 1? You should have a green tab at the bottom of the remote with a "green 1" and no lettering after the 1. If you have the correct tab on the bottom, you should be on the "System Information" screen, showing on your TV, from the receiver. At the bottom of the screen you will have "primary and secondary remote addresses" with numbers in the white boxes. You can press the "record" button on the remote to address the remote to the receiver. I hope this helps.
Ray Calo
DISH Network
May 14, 2010 | DISH Network 322 DTV Receiver
TV Stuck on 1 channel
We would be happy to help get that fixed right away. The first thing we want to ensure is that all connected equipment is on. We want to then check what type of cable was used to connect the TV to the receiver. If you are using a Coax Cable to connect the receiver to TV1, check the receiver's back panel for the output name. If your receiver has a "TV CH 3/4 out": Tune TV to channel 3 or channel 4, back if it is labeled "Home Distribution": Tune TV to channel 62 or 75. If using non-Coax (RCA, Component, or HDMI) to connect receiver to TV1, cycle through the inputs until picture appears; Most TVs have a "TV/Video", "Input", or "Source" button. If we are still not getting a picture then unplug receiver for 10 seconds then plug it back in, this will reset the receiver, then try cycling the inputs again.
We hope these steps resolve the issue. We want to thank you for being a valued DISH Network customer!
Phillip Chang
Jan 22, 2010 | Emerson EWF2004 20" TV
SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Nov 02, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
V-chip reset
the password can be reset to 0000 by holding
the volume down and channel up buttons for 5 seconds.Then the 0000 password
can be used to access the menu and make changes.
Dec 03, 2007 | Televison & Video
Emerson EWF2004 20" TV Logo
1,603 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
