Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Failing lcd(s) in middle of screen from top to bottom
I have two lines of lcds that are failing vertically in my sony kdl-40s2010. Each line is about 2-3 lcd crystals wide. Anyone had this problem or seen Sony respond responsibly?
  • cjcozzens Apr 15, 2009
    These things should last at least 10-15 years. I bought this in 2005.
  • 116 Answers
Most likely the panel is bad. You have a year warranty on the panel. Please check your purchase date and contact a local Sony authorized repair facility.
Posted on Apr 15, 2009
  • Paul Buscema Apr 15, 2009
    I agree. Sony bought panels from Samsung and the failure rate was quite high. It is probably a waste of time, but I would get on the phone with Sony and make a fuss.
I have a sony bravia tv which i have had about eight years. four vertical lines have appeared in the bottom right hand area of the screen. one long red line one long green line. and two short lines on...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 18, 2015 | HCDZ General Remote Control Fit For Sony...
My sony bravia tv has vertical lines on it
If the lines are stationary and are the complete hieght of the picture then the screen has probably failed.
Mar 11, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The tv screen has blured colors on the left side and the entire screen will look like a plad shirt from time to time with horizontal and vertical lines. if you turn the set off and back on it will usually...
This problems,the board call the T-CON decoder board,have problems,about to dies.This T-CON decoder board sit right in the middle bottom of the LCD screen.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoder board for the replacement.
Oct 14, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Black line going down middle of screen and one side of picture darker also picture sometime is distorted on bottom
if the line is pixel thin, it could be a bad lcd panel. if it is a wider bar, it may be in the video circuitry. many of these sony tvs had bad panels, and sony has extended the warranty. call up sony with your model and serial # and date of purchase and try to get them to help you out, that is your best course of action. let me know if you need more troubleshooting assitance.
Jun 01, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
With the tv off, my new Sony kdlvl160 appears to have lines on the lcd screen. Am I seeing things? This is the second one and they seem to be in same general area. TV is mounted to wall so maybe this is...
What directions are the lines?
Are these lines lit up, or just a dark pattern on the display?
If it appears like the LCDs are switching on (e.g. this line is perfect vertical or horizontal line that appears to have color when lit with a flashlight), then there is likely an electronics fault that is causing a tiny amount of current to reach the LCD driver chips for a vertical or horizontal column/row. that would concern me as something that may get worse over time.
Most TVs are built to be rigid enough for wall mounting, so this should have no effect. The only crazy thing I can think of is if somebody put a toooo long screw in one of the mounting holes in the TV and is contacting some part of a circuit. Likely? No. Possible? maybe.
Oct 21, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Colored line runnung up and bown across the screen
Hi my name is Roety,
I can help you with your issue ,
Sony LCDs may develope a bad screen, if the line is there on every input.
Bad panel
If you can see the line with the TV off , the screen is bad
Call sony I think they extended the warranty on some of these screens,
best of luck
If I have helped you with your issue please click accept.
If you have more questions you can still respond,
I will reply asap
Thanks
Oct 10, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia 32in ... vertical gray line on right side of the screen about 4in from the edge of the screen. The line is about 5mm thick and present on all inputs. More visible over brown and blue...
The line should be visible, even with the television off. It is called "de-lamination" of the LCD panel, and occurs in lines, usually vertical, on the screen.
The panel does need to be replaced. You can contact Sony at 1800-222-SONY. They are good people, and should be able to help you.
Hope this helps...
Jan 05, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Vertical line on TV
usualy this problem is cause by the lcd drive board.
Oct 09, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
170 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
