Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
What does it mean when my sony trinitran wont turn
TV won`t turn on. The stand by light blinks about 7 times.
  • Raymond Zwiefka Apr 15, 2009
    I thought Sony was suppose to be a quality product.
  • Raymond Zwiefka Apr 16, 2009
    can u give me a ballpark dollar amount on how much this will cost-parts and labor?
  • 10,515 Answers
Hi rayz1969,
7 blink refers to "High Voltage Shutdown"...
  There might be millions of reasons and it's not possible to discuss each and every aspect in detail as it might take months to discuss those.
This means that the high voltage has exceeded 33k and unit goes immediately into safety shutdown.
This can be as small issue as power supply problem or might as big as the blowing of circuit board. These all blinks can be misleading sometimes. Many people would say, its a big issue and it's much better for you to replace the set.
  It depends, like if that's a small fault, you can fix that unless i would advise you to seek local tech for repair. You would be able to know an idea how much it might cost you.
 Usually what i have seen it might cost you 200 bucks if that's a major issue and even if you pay it would not guarantee the set......
Take a voltmeter and check the voltage across the circuit board in it.
Note :- 90% of such cases - 7 blinks - you need to replace 'D" board.
Thanks for using Fixya.
Posted on Apr 16, 2009
    President:
  • 1,197 Answers
THIS HAPPENS WHEN THERE IS GROUNDING..... THE SEVEN BLINK STANDBY MODE IS ACTUALLY PROVIDED TO SAFEGUARD UR TV...
U NEED TO UNPLUG THE TV FOR 4 TO 6 HOURS .... ONCE ITS DONE... AND WHEN U SWITCH IT ON AGAIN IT WILL WORK FINE
,EVEN I DID THE SAME THING ..... I unplugged it for 4 hours. The t.v. is back up and running fine. It's a nice t.v., better than the plasma I paid over a grand for, that's already shot. It's a good t.v. and good that Sony put in the stand by protection to prevent the t.v. from dying an unnecessary young death. Patience, don't rush it, unplug the t.v. and leave it sit. Also, don't use a power strip, that was my mistake, and unplug your t.v. if storms are in the area,
thank you
hope i was of help
have a nice day
Posted on Apr 15, 2009
  • SAM JAYANTH CHANDRASEKAR
    hi this s iversh again...
    seven blinks means "Horizontal Deflection Stopped" so even after keeping it off for a while and still it does the same... There are two components that you should check in the power sup. are
    T8005,and Cap 6532....you might need replacement of these two ICs as well.... IC6501 & IC8002... this is not a job for u... call upon a repair guy.... as connecting capacitors backwards will wreck havoc to ur tv... it might short...
    thank you
    good luck with ur tv
My tv kv-xr29m50 won'to on.stand-byl light blinks 8 time
Count the number of blinks occur at one time switch ON. These blinks are fault indications. After counting it, check this link for more details. There are details about Sony blinking codes. Search the site by brand name and model number to your TV in its search box.
Jan 29, 2013 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Sony trnitron tv won't turn on. stand by light blinks. Any ideas?
watch the blinking light---if a specific sequence like 7 blinks a pause and repeated endlessly that is a error code. It will not point to a specific part but will indicate where the issue might be.
Dec 19, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony blinking codes
If i remember correctly ten blinks means a high voltage error.
The only thing you could try is unplugging the power cord then plug it back in and try turning on the tv. If it still won't turn on try unplugging the power cord for five hours or longer and try again. If it still won't turn on it would be best to find a local repair shop that works on sony tv's and have them repair it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-51WS550 51" Rear...
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
My Sony KV-36XBR800 will no longer turn on when power is pressed it clicks and sounds like it's turning on but the screen stays black and the stand by light blinks 7 times.
7 times mean no horizontal deflection. So check horizontal output an solder of it and associate parts.Often resistor and transfo driver of base of h. output.
Apr 23, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony trinitron
The standby light should be blinking in a pattern. Count,pause,count... Please post the count and that will indicate the circuit in which a problem was detected. That will allow me to give you details and possible solutions.
Thanks,
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Wega Blinking Standby Light
No... we got it to come back on and now we havent tuned it off since... we just leave it on 24 hours a day!
Jan 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
