Question about Qca Spas Jewel Series Topaz Plus Hot Tub
Diagnostic Message: Ec ...
I have no idea what has happened, but here is what I have been able to figure out so far. I have a Jewel Plus series spa (Topaz I think). As far as I know, outside of checking on it once or twice, it was pretty much left alone all of this last winter. This winter was extremely cold at times, somewhere in the realm of -20F. When I checked on the spa once it was warmer, nearly all the water was gone.
I had hoped the water had somehow evaporated out when one of the cold snaps hit. However, after cleaning in out today and filling it back up with water, there appear to be several issues with it. There is a click when I turn the blowers on, but nothing happens. When I try the jets, the spa makes a whirring sound at least similar to when they are working correctly, but nothing more happens. I have not opened up the side panel yet, but the spa appears to be leaking (the cement around the spa is wet now). Finally, I am getting a diagnostic message on the control panel that reads "Ec", which is not on the diagnostic message list in the manual.
My guess is that something went wrong during the winter and one of the hoses froze. But, if it was just a leaking hose, would that cause all the other issues? Does anyone know what "Ec" means?
Thanks.
Press the temp button, and then press the light button, that will change the mode of the tub.
Posted on Jul 25, 2009
  • 547 Answers
Your motor was frozen and you need to replace gaskits and most likly the impellar please have a look at where the water is coming from and get back to me thanks
RATE ME
Posted on Apr 20, 2009
Signature Titan II keeps tripping the breaker
check to see if recirculation pump is working if so check to see if heater element is not shorting out
Jul 13, 2014 | Qca Spas Jewel Series Topaz Plus Hot Tub
An Emerald Spa 1998 keeps tripping the breaker
with power off take cover off control box remove heater element lead make sure to take a picture or a drawing to see where they go back turn on breaker with wires taped up if it doesnt blow breaker you need a new heater element
Jul 10, 2014 | Qca Spas Jewel Series Topaz Plus Hot Tub
I have a qca jewel spa the heater only runs when one or both of the pumps are running ? Any suggestions thanks
I would assume this is by design. If water were not flowing through the heater it would constantly cycle and mineral deposit would accumulate on the heating elements much faster and shorten their lifespan.
Nov 02, 2013 | Qca Spas Jewel Series Topaz Plus Hot Tub
OH error QCA spa High jets work and heat
OH is the overheat code.
Your spa temperature is set above 108, or your thermostat is faulty & not reading correctly.
Jan 23, 2012 | Qca Spas Jewel Series Topaz Plus Hot Tub
How do you winterize a hot tub? QCA Jewel Model SUV M7
this is taken right from a jewel series QCA hot tub manual.....Winterizing
In very cold weather you may not want to venture outside to use your spa. In this case, you may move it to a heated area, or leave it as is until the weather warms. If you do leave the spa unused for a long period of time in severely cold weather, you should winterize the spa to avoid accidental freezing due to a power or equipment failure.. Follow these easy steps: Turn power to the spa OFF. Drain the spa. Use a wet vac to **** or blow out the air injectors, water jets and water suction fittings. Add 1-3 gallons of RV antifreeze, depending on the size of the spa, to all the air injectors, water jets, suction drains, and filter. Caution: Any lines not receiving adequate antifreeze are subject to freeze damage!
Dec 29, 2011 | Qca Spas Jewel Series Topaz Plus Hot Tub
How do i drain a jewel plus spa,
Most of this manufatcturers spas have a 3/4" drain valve tucked in between the control pak and the pump. If your does not have this, a sump pump connected to a hose is the best , fastest way to drain a spa. My favorite king is "little giant" which is sold at any lowes or home depot if your in america. If not, any local hardware store should stock these. Cost in USA is about $35
Apr 10, 2011 | Qca Spas Jewel Series Topaz Plus Hot Tub
We just bought a qca topaz hot tub from a person and we can't seem to get the jets to shut off. Any ideas?
reset the filter timer on the unit probably set at max since being powered up [replugged in ] 6hrs out of 12hrs every 12 hrs if u have manual will explain how to set temp and filter run time if no manual can notify company and they can advise --i believe on yours that if u hold down the light button for a few seconds it will flash a number and u can use up and down adjustment arrows to reset time usually set at 1
Aug 12, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
My jets on my topaz II won't shut off
maybe your filtration cycle is set to high.
check with your instruction manual on how to bring filtration cycle up and if showing FIL 8 or Fil C then this is the reason.
Is the spa up to temp? if not then spa is running all the time to try and heat.....
if not then may have a circuit board error or top side controller
Adam Miller
Service Manager, Canadian Spa Company, UK
OH reading on my spa
either dirty or old filter or bad temp sensor
Jul 16, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Qca Spas Jewel Series Topaz Plus Hot Tub Logo
367 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
