Question about Mitsubishi Diamond WD-65831 65" Projection HDTV
Trouble with the tv
Hi i have a troble with the tv. when i'm watching the tv some message apears saying that th e tv it's goning ot turn off ahd that we have check the ventilation but i have the tv next to ah window..¿what can i do?
It's a well known problem by mitsubishi and they have extended the warranty for an additional 2 years for that specific problem. Call them at 800.332.2119 It's also on their website.
Posted on Nov 27, 2007
The problem with Thermos sensor  which on the top of the lamp,
cut the connectors and rewire direct after soldering the wires  and tape them well.  because I believe the tv said in the message air flow  ,   if that right do what I told you ,becose that was one of the bu litton from mitsubishi. good luck.
Posted on Oct 12, 2007
    Genius:
  • 1,153 Answers
Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... 9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049020, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049020
Posted on Sep 14, 2007
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
It's at top dead centre on th crank the cam pully marks at top of head and inlet valve just on opening th dizzy pully marks are lined up with the crank locator when you look from th marks and have taken...
You have the wrong valve openong. To time an engine properly the Exhaust valve opens when you go past TDC, n ot the intake. The intake should be closing as you come up on TDC. Just pull the dizzy back out and give the engine one complete turn and put it back in. Hope this helps.
Jan 26, 2011 | Ford Futura Cars & Trucks
Configuring time, date etc for my O.T.S watch
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
Jan 01, 2010 | JCPenney Armitron Sport Watch
I used a mini DVD-RW to record something with my camcorder. Then took the disc out ahd tried to put it in my computer. The computer reformatted th disc. Now I can't find the recordings I made. Have I lost...
If the DVD-RW was re-formatted, everything is gone. There may be a possibility to find a program to recover them, a search on the net may find it, not sure.
Aug 31, 2009 | Cameras
Error code C-D351 on a Bizhub C250
didn't find this code, so dis you read the code correctly and is the model write. you can try troble reset. turn off printer and then on again, holding utility key down. push trouble reset, and reboot again.
May 05, 2008 | Konica Minolta bizhub C250 All-In-One...
Trouble Loading & Not Registering To TV
I can't say 100% but it sounds similar to the problem I had with the same model . The sleep mode in the on/off switch had gone bad and a new switch fixed the problem. It was about $42 to rtepair at my local electronics repair shop. Hope this helps.
Jan 30, 2008 | Yamakawa DVD-218 DVD Player
RGB
Press input until tv apears again. Or go into menu , setup Video input and select av or tv what ever you use.
Dec 23, 2007 | Vizio L37 Television
Troble tuning in
If your recorder is hooked up after the cable box, then it can probably only receive channel 3...the set-top box does the switching, and sends everything to the TV (and recorder) on Ch. 3
Sep 25, 2007 | Samsung DVD-HR720 DVD Recorder
Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
156 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
