Question about Acer Aspire 3680-2682 Notebook
It wont go past tthe wire less security. and now the the cd wont restart
  • phil_NHCT May 11, 2010
    if you can tell me these things, I can probably solve your issue.
    what make and model laptop?
    what operating system?
    what type of wireless access point (make/model)?
    what is it that you are trying to "restart" from CD?
    if you need assistance in supplying this information, let me know where you need it.
Kenmore calypso wont come on
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
Nov 05, 2012 | Computers & Internet
Wont boot
hope this helps
Oct 08, 2012 | Seagate Computers & Internet
HP XW6200 wont torn on flash & bep in read???
hope this helps
Sep 16, 2012 | HP XW6200 2.8 80G 512M DP PE307UAABA PC...
My imac wont start . power has been a problem , anyone had the same problems. Over the past 3 months it will close down after 2 mins, I would rebootit and it would be ok, Now it just wont start? Anyone...
hope this helps
Sep 04, 2012 | Computers & Internet
Ptnc002002102034139600
if your computer wont start
hope this helps
Jul 25, 2012 | E-Machines eMachines Desktop PC
Gateway 4024 wont power on
One bad lead or faulty connection point can cause a computer to shutdown continue restarting on a cycle or fail to detect your hard drive boot up
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jul 14, 2012 | Gateway Computers & Internet
V6000 looping not starting?
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
check the CPU make sure it has thermal paste and dust free secure seating
hope it helps
Jun 24, 2012 | Compaq 449901-001 - HP Presario V6500...
Windows wont boot past the first xp screen restarts again and again in a loop and pressing f8 doesnt work wont le
In that case, place your System disk in the DVD/CD drive after setting the BIOS to CD ROM first boot and boot the machine choosing repair system from the menu.
Hope this helps.
Dec 30, 2010 | MPC Computers ClientPro 365 PC Desktop
My 1994 jeep grand cherokee wont stay running and tthe security light is on
Generally you can clear that by locking and unlocking the drivers side door using the key. Also try hatch lock and sometimes passenger side (rarely but sometimes used).
Dec 28, 2010 | 1994 Jeep Grand Cherokee
My cd player wont play cds
take the panel off 4 screws or so just on cd player & over heater control . remove cd player , cover screw's , wire harness ... cd 's probably stuck . remove all cd's put everything back together install cd's again . took me 6month's to figure out my girlfriend did in less than hour with wout breaking a nail!!!!!! lol gd luck .
Apr 28, 2010 | 2004 Nissan Titan
Acer Aspire 3680-2682 Notebook Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
