Question about Boss IQ 3KD.1 Car Audio Amplifier
It wont come on
My amp will not come on everything is hooked up properly but it wont come on the fuses are good what is it
    Problem Solver:
  • 15 Answers
You or sumone while connecting the 12v power touched the screwdriver to the side of amp shorting the amp out sorry cant be fixed by anyone but who makes it or has internal board knowledge
Posted on May 22, 2009
  • 62 Answers
SOURCE: the amp wont come on
sorry to have to tell u this but you blew your amp or just the channels this happens when you dont have the ohm rite for amp and speakers
Posted on Dec 20, 2008
  • 149 Answers
SOURCE: power amp wont power up
Check the fuses-should be a pair of 30 amps on the side. use a paper clip and jump power from the power+ to the remote+ and see if that lights it up-if it does than your remote lead isnt giving it juice-
Posted on May 12, 2009
  • 19 Answers
SOURCE: Hooked up the amp, lights up, fans kick on and run
could be bad rca cables or no output from the radio rca outputs. the sub control may be turned off on the radio (ive seen that alot at my work). if all that is fine, the amplifier may be bad. the rca cables may be plugged into the "out" section of the amp. gotta look at all the small obvious things first. good luck.
Posted on Dec 27, 2009
oldmanewtoys
  • 414 Answers
SOURCE: amp blows fuses
fuses blow to save the amp. Are your speakers too big for the amp? If this amp is rated RMS @ 16olms it will only power around 600 to 800 @ 8olm and less as you drop down. better to have too much amp then too little so if you are trying to push 1000 watts per speaker @ 8 olms you are way under powered. Also check to make sure your wires are correct inside your speaker cables
Posted on Mar 09, 2010
hch2011
  • 458 Answers
SOURCE: it wont Come on when
check for connection misadjustments. Sometimes the device may require power on provided with remote controls.
Posted on Jan 28, 2011
Neighbor hooked the wrong terminals to a new battery, the horn sounded and he reconnected properly. Now it wont start.
check the main fuse in the engine bay fuse box its a big one 80 amp this will have blown. doing this can also blow the ecu. but you may be lucky. horn going off is the alarm so this may have a problem to so would check this out as well.
Feb 22, 2014 | 2004 Toyota Highlander
No power going to amp
Hi there! Try to check the fuse from the amp. and the remote must have 12v power.There are 3 wires to hook up [+, remote and -] . That is the only way the amp could have power other than broken.. Good Luck...
Mar 12, 2012 | Legacy Audio LA930 Car Audio Amplifier
I hooked everything up on right the wireing and stuff..the ground cable seems fine i got a red wire hooked to the positive side of the battery. everything seems ok. The amp itself came on a couple of...
Issue With Pre initial Rom Fail To Voltage Routine Check Cause... Static on The Chip Unit Posibility Security Relais Wont click On.. Do do so check for Fuse or red push botton over load security Braker at the back of your unit.. if your fuse is good Well Open the case and surch for more fuse inside of the unit Make shure the unit is unplug from the wall...Then check The voltage on the Transformer to make shure you have the right voltage then check The Regulator The Coil and Capacitor If your not shure Well send it to a Reapair Shop it your best choice Amp cant be dangerous for hazard shock....Good Luck
Sep 23, 2010 | Crown MA-5002VZ 2-Channel Amplifier
I have an Dual brand 300 watt amplifier that I just bought and I hooked everything up right (battery---power, ground----sanded metal, bypassed remote with toggle switch remote-----+terminal on switch...
Is your toggle hooked to ground? Hook your toggle switch to the battery and then the other end of that toggle the remote input on the amp.
Aug 15, 2010 | Car Audio & Video
Wont turn on every thing is hooked up right pluged
A PLYE AMP IS NO GOOD AND ITS PROBABLY BLOWN SORRY FOR THE BAD NEWS
Feb 09, 2010 | Pyle PLA985R Car Audio Amplifier
Amp wont turn on,, do i need to do something else
make sure that you have the fuse in for the 12 pos if you do then the only other way to check it to make sure the amp works is put a jumper wire from the positive to the remote on the amp and it should come on if it does the you need to find a fuse in the fuse block and hook it up to it so that the fuse turns it on with the key just make sure you use a multimeter and make sure the fuse turns on and off with the key
Jul 10, 2009 | Lanzar VIBE236 Car Audio Amplifier
Power amp wont power up
Apr 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Wondering why im blowing fuses
The most common reason for an amp (in good working order) to blow fuses is a speaker load that's impedance is too low. You may need to rewire your speakers.
Let me know if you have any other questions.
Aug 21, 2008 | Legend LA1490 - American Legacy Series 2 -...
Amp hook up
To do it safely, you need to fully understand everything about the system. It would take too much to explain everything here. If you're really interested in doing this properly, read through the following site. Read the 'Fuses' page twice. It will help prevent an electrical fire.
Basic Car Audio Electronics
Aug 02, 2008 | Car Audio & Video
Amp wont work jxp340
hi if you got a voltmeter TEST IT ALL ON A LOW LEVEL OF VOLUME!! check the outlets of the amp if there is a signal at all... no? - the amp isnt hooked properly! yes? - check if the volt level on the outlets is higher then the level on the inlets of the amp (the amp is amplifying) no? - the amp isnt hooked properly! or its bad... yes? - connect a speaker to see if its working wont put out a lousy spark? check your system, the problem if probably there... check all the connections, fuses, wires begin from battery and go FWD antill the next device isnt working good luck
Feb 21, 2006 | Jensen JXP340 Car Audio Amplifier
Boss IQ 3KD.1 Car Audio Amplifier Logo
111 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
