Kenmore 4563291 top loading washer quit in rinse cycle power to machine is good but total unit is dead - Cant figure how to get to timer circuits etc. Cant find parts manual or circuit diagram
  • 72 Answers
Unplug for 30 seconds then plug back in and advance timer around to start again. if still nothing take off the top back panel there should be a fuse
Posted on Apr 15, 2009
My washer stops at end of the wash cycle;
do u mean the timer does not move forward in that case u would need to order a new timer you can order the timer directly from marcone appliancce parts and they will mail it directly to your front door this is quite an easy fix just make sure u unplug the washer before you attempt to change the timer hope this helps
Jul 21, 2010 | Kenmore 22422 Top Load Washer
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 80 series washer will sometimes not fill in rinse cycle, sometimes half fill, sometimes 1/4. fills fine for start but not rinse????
HI, This will be the result of a failing control sector. The control sector can be a timer module, or a single printed circuit board. In any case, this will be your culprit. Have this damaged control replaced, asap. Once replaced, your unit will operate correctly.
Dec 26, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Feb 13, 2009 | Kenmore 22422 Top Load Washer
I have a small Kenmore top loading washer that quits radomly just before the rinse cycle. I have to manually pull the knob and move it a little forward and press it in, then the washer starts and completes...
sounds like a defective timer,,,but test it first,,when it stops before rinse ..open and shut it firmly we are testing lid switch,,one of them is defective,,keep me posted onthejop
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Washer dead
ck to see if you here a lid switch click when lid is slowly closed if not suspect lid switch may be on right sidew of opening or under left rear of lid at hinge also ck for loose lid hinge screws left side first
Sep 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer timer dial is not advancing
ok " timer has a small stepper motor in it, and it can be replaced
take stepper motor out .
appliance parts store will have it
or just replace timer
take make and model number with you
Jan 13, 2008 | Washing Machines
Washing Machines Logo
192 people viewed this question
Top Washing Machines Experts
