Question about Sharp EL-531VB Calculator
Sharp EL 531w . the calculator doesn't turn on.
The calculator doesn't turn on.
  • Sharp Master
  • 8,068 Answers
Press the reset button on the back. If that does not work, batteries may be dead. Once you replace them press [ON/C].
Hope it helps.
Posted on Sep 20, 2009
marsrover
  • 682 Answers
SOURCE: compound interest
http://www.sharpusa.com/files/cal_man_EL531_509.pdf.
Posted on Mar 10, 2008
SOURCE: FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Posted on Apr 20, 2008
  • 90 Answers
SOURCE: SHARP EL-531W HOW DO YOU CALCULATE MEAN,STANDARD
for the mean, just add them together and divide answer by the amount of figures you put in. as for the others, i'm not sure a standard scientific calculator will do that
Posted on Jun 11, 2009
SOURCE: I have a Sharp EL-531W.All keys work except for sin cos tan hyp.
No solution, but I have the exact same problem with a Sharp EL-531W calculator. Doesn't matter whether mode is degrees, radians, etc., and resetting with button in back has no effect.
Posted on Aug 19, 2010
SOURCE: Why won't my sharp
i can't get rid off the deg off my screen on my calulatur
Posted on Sep 09, 2011
Changed batteries doesn't turn on no power
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Jan 22, 2013 | Texas Instruments TI-84 Plus Calculator
Doesn't start anymore
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.If this doesn't do it please reply to this post and we'll go on from there.
Apr 18, 2012 | Texas Instruments TI-84 Plus Calculator
My screen says
If pressing the CLEAR key doesn't get rid of it, reset the calculator.Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Turn the calculator on. You may have to adjust the contrast to make the screen visible.
Apr 18, 2012 | Texas Instruments TI-84 Plus Silver...
My Ti-86 wont turn on after i change batteries
If this doesn't do it, please reply to this post and we'll go on from there.
Feb 17, 2012 | Texas Instruments TI-86 Calculator
My calculator casio fx-350ES doesn't have equation.why? or this calculator doesn't have software equation.why?
Not all calculators have that. The Fx115ES and the FX991 ES have a lot more options thatn the FX300Es and FX350ES. I believe you only have COMP (general computational mode), Table and STAT.
Why? It was not designed that way.
Aug 18, 2011 | Casio FX-115ES Scientific Calculator
My calculator was left outside in the rain and doesn't turn on. I'm not exactly sure what's wrong with it specifically. It just doesn't operate.
The CPU of your calculator most likely got wet and rusted up the parts. If not, the screen may have gotten water damage. Either way, it will no longer work and you will have to buy a new one.
Aug 12, 2011 | Texas Instruments TI-84 Plus Calculator
My ti 84 plus does not want to turn on, i thought it was battery problem so, i bought new batteries but i stil have a blank screen.
Could it be that your screen has been dimmed in error. Turn the calculator on & press the 2nd key and then the up arrow. This darkens the screen.
If this doesn't work, try taking out the backup battery. It is located in the battery compartment, behind a little door that you must take off with a phillips screwdriver. Leave it out for about 10 hours. If this doesn't work, try replacing the backup battery.
Hope this helps.
Jun 21, 2011 | Texas Instruments TI-84 Plus Calculator
"ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Jun 18, 2011 | HP 48gx Calculator
Hi guys I just replace batteries after a long time of not using mi TI-83 but I get a Blank screen. I pushed some buttons and it turned clear again but doesn-t show any numbers doesn,t perform any...
You may have to force the calculator to boot up to reinstall the OS. Details are in the article . Read the part on Ti83Plus family.
The article contains links to additional pages.
Hope it helps.
Oct 27, 2009 | Texas Instruments TI-83 Plus Calculator
How to reset my HP 12 C calculator ? it's doesn operate right
I just follow the paper clip trick (took the batteries out, connect the + and - with th epaper clip, then turn it off). After clearing all the program memory and turned it on & off, it worked fine.
Thanks.
Jan 06, 2009 | HP 12c Calculator
Sharp EL-531VB Calculator Logo
415 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
