DVD will not e-ject - Televison & Video
    Novelist:
  • 159 Answers
Maintenance is needed for that set. Dust in the mechanism. stuck it.
Posted on Apr 15, 2009
I bought a Stanton T.52 turntable, but I need a belt. I've done some searches but can't seem to find anything. Where can I buy a belt?
Stanton is a hell when it comes to parts, just via a dealer is the best solution. But have you first tried to get the grease and dirt of this belt? and offcourse the poulies (round metal or plastic it spins on)degreasen. Do you use a clampweight or so..? Kind of waste of money and don't forget that the motor in this pricerange ain't a strong one is, which spins at a perfect 33, the st.150 is also cheap built and if you go for the music quality i recommened pro-ject or rega. Those have nice beginner hifi tables with a way better arm for 400 euro's new and pro-ject has the option to upgrade it , by give them the arm you use and buy the more expensive/better one for way less. And those sound way better then a stanton. The needledoctor.com sells a lot gear http://www.needledoctor.com/Pro-Ject-Debut-Carbon-in-Light-Grey?sc=2&category=352. but this table comes included 2mred , which i also have, but your records needs to be real clean, so i use them seldom:). And i have checked the side where i sometimes buy vestax gear, but yours wasn't between them. Just go to a dealer and they get one for you or check ebay.
But first try to clean it well, a little oil on it and your grip is gone.
Goodluck, greetings richard
Feb 08, 2014 | Stanton T52 Turntable
Pro-ject Debut III with USB turntable - produces high levels of distortion and static - why? (Has an internal pre-amp, so gets plugged into line level inputs. Is properly grounded. Line level input...
which pre-amp do you use, since the pre-amp and usb are cheap made components, especially pro-ject, i was amazed which low quality pre-amp i bought for 250 euro.
Dec 25, 2010 | Project DEBUT III Turntable
My dvd tray cannot eject automaticly.........it can ject by manually......
you can open the tray
Folow the steep
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is noharm in trying If you take a little riskcan solve . follow the instruction: Don'tpanic its very simply. 1. When running yourpc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all thescrew from the back side 5. press clip toopen the font panel 6. reverse thecd/dvd rw 7. just remove thecover 8. clean the optical lance 9. http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html 10. use a little ( not much )oil place on two steel shaft 11.cover all the equipment 12.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected. Hopeit will help you.
Dec 25, 2010 | Dell DVD-rom DVD Drive
Keep getting
your laser lens need to be clean/use a qtips and wood alcool /ject disk open cover keep door open
unplug dvd and you will see the lens just wiped whit the q tips ,gently and you done it should works fine
put the cover back and try it;if it wont work you may have to replaced the laser assembly its easy..
hope that will help you
regards ALAN
May 06, 2010 | GoVideo DVR4000 DVD Player/VCR
Dvd
does it act like or sound like it wants to open? This could be a small belt drive that is broken or slipping and not letting the door open. Also theres a cam inside thats driven by a belt or worm gear that if that dosent turn then the disc clamper wont raise up and let the door open or you could have a problem with the motor drive circuit that controls the tray motor and last but not least does the eject button feel like its making contact with the little swith inside or is it a flat feeling as maybe the switch could be broken or out of alighnment with the eject switch? Anywho if you unplug the unit it woulnd hurt for you to open the unit to check the belts worm gear or eject switch but if your not handy andy then I would seek a pro for assistance. Good Luck
May 25, 2006 | RCA DRC108N DVD Player
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
