Question about Plantronics PL-CS55 Wireless Headset
I have plantronic headset model CS55 the green light is blinking
My Plantronic headset model CS55 green light is blinking any ideal?
Thanks
Lee
  • 32 Answers
Either the battery is low, or the unit is switched on.  If you're looking at the base unit of the CS55, on the right hand side there is a switch that either points to I or II.  If it's on II, your headset will be activated the second it is removed from the base.  If it's on I, it won't turn on, thus it won't turn the light on.  Check to make sure that dial is on I instead of II, and when you pick it up you shouldn't have that problem anymore.
If it's a problem with low battery you have to make sure that when you place the headset on the charging cradle that it's securely seated in there.  Also make sure that you clean the charging contacts (the brass-coloured contacts on the headset and on the base) about once a month with rubbing alcohol.
Posted on Apr 28, 2009
I was given a CS55 Plantronics head set. Looking for directions to set it up
If you click on the following page:
Plantronics CS55 Wireless Headset
Towards the bottom of the page, click on the tab labeled ADDITIONAL INFORMATION. Within that section, you will see PLANTRONICS CS50/CS55 INTERACTIVE USERS GUIDE to click on. This will help you visually see how to setup and start using your CS55.
Good Luck from Headsets Direct!
Jun 15, 2011 | Plantronics CS55 Wireless Headset
I need the manaul for this product. I do not know what the the flashing light mean, and I was given this product from another co-worker....but no one knows what the lights mean?
Hello, you can download the manual here: http://www.plantronics.com/us/media/media-resources/literature/user_guides/73156-01_CS55_US_DL.pdf?WT.dl=20 It says that a flashing amber light means charging, a solid amber light means charged, a solid red light means power, a solid green light means talking, and a blinking green light means muted.
May 16, 2011 | Plantronics CS55 Wireless Headset
My lg cu920 can't read my plantronic 220 what can i
Do you mean it "can" or can't connect to your CU920?
If your CU920 is already paired to a computer or other device this first pairing must be stopped before the steps below will work.
On the Bluetooth headset: 1. Turn your headset ON. 2. Hold down the headset power button until the power indicator light blinks an alternating red & blue.
Then using your CU920.... 3. Turn Bluetooth ON, 4. Search "New Device," 5. Under "devices found" select your headset. 6. Select "Add." The CU920 will ask for a passcode. 7. Enter "0000" (four zeros) the default for the Explorer 220.
The Plantronics earpiece should automatically "pair" with your CU920.
Oct 11, 2009 | Plantronics Explorer 220 Bluetooth Headset...
I am getting feedback and an echo in my Plantronic CS55 wireless
Had similar issue.
This how I fixed it
1) set bottom mic to A
2) set dial on the side of CS55 to "Setting 1" most typical
3) set sound lever on the back to "1"
4) played with mic control on the back until quality became sufficient
Jun 26, 2009 | Plantronics CS55/HL10 Wireless Office...
Blinking green light on microphone, headset not working
The blinking light means headset is muted. Un-mute the headset by pushing the small toggle switch on the back of the headset.
You may need to reset the headset. You can do this by first pressing the mute switch on the back of the headset and then simultaneously pressing the call switch on the side of the headset for about 4-5 seconds.
You will need to pair the headset with the base again.
Mar 13, 2009 | Plantronics CS55 Wireless Headset
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
The blue light doesn't turn off
Hey, I have managed to turn off blinking in My Plantronics 665 by
first: Turning off headset,
then pressing volume up and turning it on.
It will blink to show that it is on, , then blink one more time to show, that it is connecting to phone, and thats it, : no more blinks,
So You don't look like UFO :-)
Cheers from PL.!
XRafX
Aug 12, 2008 | Plantronics Explorer 330 Headset
Plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
Aug 04, 2008 | Plantronics PL-CS55 Wireless Headset
Plantronic 510s
The Voyager 510 is not a good fit for that phone. I would prefer the cs55 or awh55.
The headset will work with the phone, but will not alert you when there is a call.
Jul 03, 2008 | Avaya 5400 Series 5410 Phone
Plantronics PL-CS55 Wireless Headset Logo
3,181 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
