Question about Garmin GPS
My Garmin eTrex Venture (software 1999-2002) won't boot.
My Garmin eTrex Venture doesn't boot properly. It's been stored quite a while with batteries in it, and had a lot of trouble booting up, but did so eventually. Changed batteries for fresh ones, and now it won't boot up and stay on at all. Tried to reset it but couldn't get the screen to do much more than scramble a bunch of lines and stripes. Turned off the GPS (using it inside to get used to the unit and explore the manual before taking it into the field), but that was as far as I could get. It is stalled at stripes. This unit was acquired in 2005 and used extensively by the non-profit volunteers of our organization. Then it was stored for a year or so, and recently relocated and reactivated. We can't get it to do much. Can you help?
The screen of the Etrex looks like the unit might have sustained a lightning strike, or been exposed to moisture. I tried several resets. Never could get it to the 'white screen' or the instructions I was to follow (even after pressing screen and on button 5 minutes). Took it to a meeting the next day ready to explain to the board that their expensive piece of equipment needs replacement. Except it worked. Sort of. It's needed to deliver WAAS readings on well sites. It sort of does that, in between flipping screens and scrambling screens. My theory is if I can try again (after my thumb and finger recover) to reset, maybe I can restore the thing, which was apparently lost under the seat of a car that was very near a fireball lightning strike or two, in a remote rural (read humid) salt waterfront community. Electronics hate surges, water, salt and battery corrosion, but it was found again after about a year, with the batteries still in place, not corroded, and still functional. Don't mess with these early Garmins. They're tough!!
Posted on Apr 17, 2009
Handheld gps just quit.
Go to GARMIN Website and seek help there [from their techys] asap ... ok
Nov 21, 2013 | Garmin eTrex Venture HC GPS Receiver
Garmin Etrex Venture HC will not power up/stay on.
You are not alone it appears. Follow the link below.
Try here.http://www.fixya.com/support/t2084694-gps_stay I had the same problem as you and I followed the advise to do a "bootlock" to download new software via Garmins WebUpdater. http://www8.garmin.com/support/download_details.jsp?id=931
But please note if the unit switches off during update it may cause problems.
Or you could just return to Garmin for a replacement.
Feb 17, 2010 | Garmin eTrex Venture HC GPS Receiver
My etrex Venture HC will not power up after changing batteries. Unit has been "on the shelf" for some time. HELP
I can only suggest that you insure that you have fresh batteries, and that they are installed properly. If you had batteries sitting in it, and they leaked, you might want to examine the contacts and make sure they are clean, and not corroded.
The Etrex are sealed and water-tight. Opening the unit will make them no longer able to resist water as well, and if there is anything wrong internally, it should be sent back for factory repair.
Nov 06, 2009 | Garmin eTrex Venture HC GPS Receiver
My GPS won't stay on
I can solve this by not solving it. First I tried reset the unit to default settings: hold down the power, page, and enter buttons at the same time, a message, "do you really wan to reset..." will appear. Select "yes." If the unit reboots, hurrah. If not, call tech support (1.800.800.1020). Get an RMA, send it back to them for repair. I had purchased mine over 30 days ago but less than 60: Amazon wouldn't replace it, Garmin will either replace or repair. If you want them to send a new unit while the old is in transit, just ask; they will charge and then credit a card once they have the old unit is in hand. Good luck.
Apr 25, 2009 | Garmin eTrex Venture HC GPS Receiver
Garmin Etrex Venture doesn't aquire satellites
I have an eTrex and you can reset the defaults which may help. I don't see any 'reset' operation in the manual other than Restore Defaults.
After switching on and letting the unit go through its initalisation press the button on the front (next to the etrex name) until you get to the main menu. Select Setup and press. Select System and press. Move the button to the left and press. Press the button again to restore defaults.
HTH
Peter
Mar 05, 2009 | Garmin eTrex Venture GPS Receiver
Screen appears to freeze up
Try updating the unit software. A new satellite was launched this year and has been causing problems. The updates from Garmin fix it. Disable the WAAS in the meantime and see if that solves the problem in the meantime.
Dec 06, 2008 | Garmin eTrex Legend GPS Receiver
Unlocking a Garmin etrex venture cx
The unit comes with a base map. You will need to purchase City Navigator software if you want more detailed maps which will show all roads. If the box contained a copy of the City Navigator and you threw away the code, you'll have to purchase another unlock code from Garmin.
May 22, 2008 | Garmin eTrex Venture Cx GPS Receiver
GPS Logo
451 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
