Question about SharpVision XV-S55U Multimedia Projector
Trying to put up a projector and screen
I'm wanting to know the distance between the screen and the projector.the screen is a 100 inch model B. the projector is xv-s55u
  • Anonymous Mar 30, 2014
    what adapters do I need?
  • 2,239 Answers
13 feet 5 inches.
Posted on Aug 19, 2009
SOURCE:
My projector dont show fuii screen,it show pictur but no full size
Couple of things here. Is the projector at the proper distance from the screen? (aka throw distance). If it as at the proper distance from the viewing surface then, if available, check and use your zoom.
Aug 22, 2014 | Office Equipment & Supplies
WHAT IS THROW RANGE ?
8ft to 40.6 foot throw distance. Screen size is 40-400 inches.
Jul 10, 2014 | Panasonic PT-AE700E Projector Lamp
We are a conference facility with a large projection screen we have recently bought a Vivitek projector and we are having problems making the picture small enouhg to fit on our Theatre screen the further...
You can go to the Vivitek website and they have a handy distance calculator to help you know the correct distance to place your projector from the screen to achieve an appropriate size.
http://www.vivitekusa.com/calculator/calculator.html
Mar 07, 2011 | Vivitek D945VX Projector
Projector to screen distance
hi,
minimum distance is 2 meters (projection 41 inch)
maximum distance is 13.4 meters (projection 300 inch)
ok
Jan 06, 2011 | Sanyo 6102607208 Projector Lamp for...
We need 2 know what 4 m o a means
MOA is the abbreviation for Minute of Angle, which measures 1/60 of 1 degree. If you want all the technical jargon and math that involves, this link explains it all: http://en.wikipedia.org/wiki/Minute_of_angle
But when you're talking about rifle scopes, here's what you need to know:
Adjusting the angle of your scope by 1 MOA will change the point of impact by about 1 inch at a distance of 100 yards. So 4 MOA is roughly 4 inches over on an object viewed at 100 yards.
Usually, the windage and elevation adjustments on a scope will be about 1/4 MOA, or about a 0.25 inch change over 100 yards.
Nov 22, 2010 | Redhead Pursuit (18-36x50)
Pls help how to correct the blury display on the screen..i have tried adjusting the Zoom to normal position and the display is still blury not very clear
first the obvious: is the lens clean?
the designed throw distance on that model is 5' - 29'. if your projector is outside that, it won't be able to focus. if it is within that distance, reset the settings in the menu to factory default. if that doesn't help, you may have physical damage to the lens assembly.
Dec 02, 2009 | Epson EMP-S3 Multimedia Projector
How to adjust for distance from the screen
I think I found the answer, I found a manual online for it. And I found a page that gave all the specs on it. I believe the specs page has the answers I was looking for. It specified the zoom and focus are manual adjustments. My co-workers will try that this morning
Jun 22, 2009 | Dell 2300MP Multimedia Projector
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
Distance from projector to screen
I need to know what screen size you are looking to get and the dimensions of your room
Thanks
Jordan Thomas
Port City AV
910 538 2754
Nov 05, 2008 | Panasonic PT-AX100U-EC DLP Projector
SharpVision XV-S55U Multimedia Projector Logo
120 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
