Question about Akai LCT2715 27 in. LCD Television
My LCT2701TD will not turn on, the small light on the front of the TV is constantly flashing red. I've turned the unit on and off with the power switch behind the TV but that doesn't change a thing.
  • 41 Answers
You most likely have low voltage power trouble. 5v line. This line feed the microprocessor. The power supply must be repaired or replaced.
Posted on Apr 15, 2009
  • 2,336 Answers
In addition to the previous post, the blinking light indicates a shorted zener diode, blown resistors and bulging capacitors.
I repair these power supplies, write to jah2mil@hotmail.com if you require further assistance.
Posted on Jul 02, 2009
Will not power on, blinking red "power on" light
The power supply might have a shorted/defective diode(s), blown resistors, capacitors if the light is blinking on the front of the LCD.
I repair these power supplies, write to jah2mil@hotmail.com if you need further assistance.
Jun 24, 2009 | Akai LCT2701TD Television
Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
May 26, 2009 | Akai LCT2701TD Television
Red power light on tv flashing. Unit wont power on or off
(1) check using the tv control or with the remote if it was actually turned on.
(2) if this won't work, the television's tube might have the problem. this needs a replacement. proceed to a certified service provider.
Apr 23, 2009 | Akai LCT2701TD Television
No Picture or operation
The red blinking light indicates a shorted part inside the TV. It normally happens when the power supply is trying to compensate the demand for proper or clean power to the rest of the boards. Most of these power supplies have defective capacitors and shorted zener diode(s) as well open surface mount resistors.
I repair these power supplies, if you need further assistance write to jah2mil@hotmail.com
Mar 02, 2009 | Akai LCT2701TD Television
Akai LCT2701TD Won't turn on. Red light in front blinks.
There is a high power supply failure rate on these LCDs. The power boards are not longer being manufactured or not easy to find.
Write to jah2mil@hotmail.com for more info.
Sep 14, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai LCT2701TD
I HAD THIS TV AND TOOK IT IN TO BE FIXED AND THEY NO LONGER MAKE THE PART SO I CHUCKED IT. THANK GOD I BPOUGHT A WARRENTY ON THIS TV I ONLY HAD IT FOR A YEAR! NOT A GOOD BRAND
Jul 09, 2008 | Akai LCT2716 27 in. LCD Television
AKAI LCT2701TD SMPS Failure: Red flashing light
I do not think there aren't any new power supplies available to fix these LCDs. The only way to make the LCD work again is to have someone to repair the power supply.
You could send me an email to jah2mil@hotmail.com for more info.
May 16, 2008 | Televison & Video
AKAI LCT2701td TV No Picture
I had the same problem; the blinking light problem is caused by a bad power supply. It try’s to power up but senses a failure so it shuts down and just keeps repeating this process. I troubleshot the problem and found that zener diode Z3 (27volt 1 watt) was shorted and zener resistor forgot designation (2 surface mount 10 ohm resistors in parallel) were open. The zener is under a heat sink so it is hard to see. Also there were 4 1000uf capacitors that were bulging so I changed them as well. I got the parts from digikey for 20 bucks and its now working fine. This was a lower cost TV at the time of purchase so it seem the manufacture used low quality parts and I would suggest trying to return the TV to Costco before fixing it. Good luck.
Dec 24, 2007 | Akai LCT2701TD Television
Akai LCT2715 27 in. LCD Television Logo
382 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
