Question about Jamo SUB300BA SUB 300 Powered Subwoofer Subwoofer
Jamo SUB 300 subwoofer has no power
My Jamo SUB 300 does not power up. There is power at the input power cord. However, no 120V AC power is delivered to the circuit board. I heard SUB 300 has a fuse which I was not able to find. How can I change the fuse? I opened the back panel. There is a lot of glue on the plug on the back of the panel inside the subwoofer.
  • Juventis Apr 16, 2009
    I find out how to change the 1.6Amp 250V fuse. It is inside where the power is plugged into the unit. Had to use a screwdriver to pop of the fuse housing. However, there is a shorty inside the board. I keep blowing up fuses. I need the schematics of the cicuit board to troubleshoot the problem.
4 Suggested Answers
sanjin
  • 56 Answers
SOURCE: I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Posted on Mar 18, 2008
  • 19 Answers
SOURCE: sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
Posted on Apr 03, 2009
SOURCE: Please help! Jamo SUB 300
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
Posted on Aug 20, 2011
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Sep 13, 2012 | Jamo SUB 200 Subwoofer
I was given a Jamo sub 1810, but have no instruction manual. I'm trying to hook up to my Pioneer HTP-2500 home theater system. What would be the correct way? Also if you could help me with the setup,...
Find it here...
http://www.jamo.com/na-en/support/owners-manuals/
http://www.jamo.com/images/download/779.aspx
The Jamo is self-amplified and accepts Line Level input ONLY.
The HTP-2500 receiver drives a subwoofer directly with SPEAKER LEVEL output only and does not have a volume-controlled output for driving externally-amplified devices.
May 21, 2011 | Jamo SUB 1810 Subwoofer
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
thank you
ron
Jan 08, 2011 | Jamo SUB300BA SUB 300 Powered Subwoofer...
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Feb 08, 2010 | Jamo SUB 200 Subwoofer
Sound faliure
Mar 29, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Jamo i330 i-pod dock has one channel out
I WOULD LIKE 2 NO IF I CAN RESET MY PASSWORD 4 KLH SURROUND SOUND SYSTEM. I BOUGHT AT A SALE AND THERES NO WAY I CAN FIND OUT PASSWORD. IT IS A KLH SURROUND SOUND SYSTEM DVZ-2500 MODEL # IS 0044224000657.I WOULD ALSO LIKE 2 NO IF AND WHERE I CAN GET A MANUEL....
Mar 04, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Jamo Sub300. No power. No lights
Well it would void the warrantee, but you can take the back panel off and the power supply will only have two leads (3 if grounded) in from the plug, and out to the crossover. It sounds as if you are correct that the power supply is bad.
Charles
Jan 05, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
JAMO SUB 650
hi
since it is a powered speaker, probably it just needs a sound signal which you can get from the headphone socket. please double check with someone else.
May 26, 2008 | Jamo D 4SUB Subwoofer
Dual Voice-Coil
Mar 15, 2008 | Jamo 1060 SW Speaker
Jamo 250
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
Jan 11, 2008 | Jamo D 4SUB Subwoofer
Jamo SUB300BA SUB 300 Powered Subwoofer Subwoofer Logo
879 people viewed this question
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
Steve
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
