Question about Garmin nuvi 205W GPS Receiver
Garmin Nuvi 205W tried to download map and now getting error message when I try to access maps "No detailed maps found that support routing. The nuvi cannot be used without them." Now what?????
  • Jnecco82 Apr 17, 2009
    HI - i have exact same problem, tried to click link but seems to be broken link...repost please?
  • bigdog_logr Apr 19, 2009
    i have the same prob but the link isnt workin
  • 385 Answers
See the link Here
Regards.
Posted on Apr 16, 2009
Please connect your Nuvi up to a PC and look to see if you have the map file "gmapprom.img" in the Garmin directory. The file should be around 1.5 to 2 GB in size. If the file is missing you will need to replace it. If you have registered your unit with Garmin, you may be able to log into your Garmin account and download the map file again. If you can't, then you will need to send the unit to have the map file restored by a service shop. More info on missing maps can be found here:
http://www.sharc.net/gps_lost_map.htm
Apr 15, 2013 | Garmin nuvi 205W GPS Receiver
No detailed maps found that support routing.need to download software on to micro sd card for garmin nuvi 205
The solution to the "No detailed maps that support routing" problem can be found at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
To set up a map on the micro SD card you can follow the instructions on http://www.fixya.com/support/r5628920-update_garmin_satnav_maps Don't download directly to the micro SD card as it won't be recognised by your satnav. Download to the computer and install from the computer to the card as described at the above link.
Apr 11, 2011 | Garmin nuvi 205W GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Keep getting
It means that your unlock file for you map has either been corrupted or deleted. The file needs to be restored. Please see this link for more information:
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Aug 11, 2009 | Garmin nuvi 205W GPS Receiver
GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
I had the same issue..what a pain in the ****.
I came up with a solution that worked for me.
After the update i deleted gmapprom.img and then created my own map using the garmin MapInstall program. start>programs>garmin>mapinstall
Apr 11, 2009 | Garmin nuvi 200W GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Error message appeared and can not do anything with it now
Here is the the lastest response:
Thank you for contacting Garmin International.
If you updated your nuvi 200, 200w, 205, or 205w to City Navigator North America NT 2010.10 between 4/7/09 and 4/25/09, and your unit is display the message, "No detailed maps found that support routing. The nuvi cannot be used without them." or "Can't unlock maps." A new revision of the 2010.10 update file (Garmin_RMU_CNNANT2010C.exe) has been released which corrects this issue. To download this new revision, please follow these steps:
2. Click Manage Maps and Downloads
3. Connect the nuvi to your computer
4. Click Download Again next to your nuvi
5. Click Launch Download Manager
6. Follow the prompts to install the Download manager
7. Save the file to your Desktop
The new download may take a few hours to download. Once the file has fully downloaded, double click the file to run it, and follow the onscreen prompts to begin the installation again. You will now be able to choose the appropriate region for your device.
Note: Please make sure to only select the region that originally came loaded to your device. For example, if you have a nuvi 200 that came with the Lower 49 States, select that region and not a region that includes Canada.
With Best Regards,
Mark S
Senior Product Support Specialist
Automotive Team
913-397-8200
800-800-1020
Dec 01, 2008 | Garmin nuvi 205W GPS Receiver
Updating maps
Press the power bar in the upper right c orner for 10 sec. and You will go into servicemood. Ther You can reset and run memorytests, Otherwise Use the lttle pihole under the tape on the bottom side
Aug 31, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
779 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
