Horizontal color line across the screen
I have a 25" Sony trinitron and all of a sudden I have a horizontal color line across the screen...have sound .This is on Video 1. What is so very strange when we use our DVD player it will show half a screen with sound. It all started last evening when I was putting the audio and video cable in the back of the tv. I have to tilt it forward to me a little to be able to place the cables in properly. I was doing this and all of a sudden the screen appeared with only a colored horizontal line.It will show a half screen with sound for all the regular tv channels.Has me baffled. Any help would be appreciated. Thanks, Bob Weaver
  • 41 Answers
Most likely a bad Vertical IC or bad connections on the vertical IC. don't continue trying it on. If you have a bad connection it could do more damage. You also could damage the CRT ( picture tube ). If you remove the cover and look at the bottom side of the PC bord with a good magnifiing glass you may see what looks like rings around the leads comming from the Vertical IC. The Vertical IC is mounted on a heat sink usually towards the front of the set looking from back. If you do see the rings around the leads try reheating with a solder iron. If this dosen't fix you most likely need a new IC.
Posted on Apr 15, 2009
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Sony FD Trinitron WEGA KV27FS100 horizontal lines across top part of screen
Check and replace all electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them to replace. Replace all at one time. The fault you describes here is technically known as 'vertical retrace lines'. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Sometimes, you might get some more details from there.
Oct 13, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
If you are comfortable working inside the set and can solder, try resoldering both the vertical IC and the input jack connections. The vertical IC will be a small flat IC attached to a heatsink with about 9-11 pins. It will be marked LA7837 or something similar.
Let me know the results.
Dan
Apr 15, 2009 | Televison & Video
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron 21 inch KV-G21M1
Hi there!
Sounds like a power supply fault. You could try replacing all capacitors in the power supply and others areas around the line stage, with the same values. You may also want to check the tuner or "IF" circuit for dry joints. Hope this will help you. Kind Regards, JUS004
Oct 27, 2008 | Apex Digital AT2002S 20" TV
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Sep 18, 2008 | Sony KV-24FV12 24" TV
Sony kv36fs76u
hi there, your set has a capacitor problem, most of it are on the horizontal section and video section., usually 100 microfarad electrolytic capacitor with a high voltage is damage. try to test some parts. ty
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
