Question about Tomtom XL 330 Car GPS Receiver
Flashing x i recently did a backup for my new tomtom one. now when i unplug the unit from my computer the only that it will do is show a picture of the tomtom with a white x inside a red circle. it also does this now when i turn it on. any suggestions on a solution?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 171 Answers
Connect yout tomtom to the computer. Go to my computer and open the tomtom drive to see if anything is there. You may have cut and paste instead of copy and paste. If this is the case format your tomtom drive and reload your backup.
Hope this helps.
Posted on May 29, 2009
SOURCE:
Ho can i erace everything on my gps
With out knowing which TomTom you own...try this generic how to...
First do a Backup of your unit, then update your device Then go to tomtom.com if you still are unable to find the pictures,music and other stuff you want to remove.
1. Run the Clear Flash tool on your device Using the Clear Flash tool to resolve TomTom device issues
2. Disconnect the TomTom from the computer both through the Device > Disconnect Device option in HOME and from the USB cable/dock
3. Close and exit TomTom HOME completely
* Windows: After closing the HOME window, right click the TomTom icon in the System Tray and select Exit
* Mac: From the Finder, choose Exit when you have the TomTom HOME window open
4. Restart the computer
5. After the computer has restarted, open TomTom HOME
6. Login to your MyTomTom account - use the Log in link in the upper-right hand corner
7. Connect the device and let all updates download and install (this may take a moment)
* Updates should download and install automatically, otherwise, click on Update my device.
If you need to delete pictures,music,and stuff you may find it easier to default your unit. BUT SAVE the backup as you may want to extract parts of it and that you need.
Mar 02, 2010 | Tomtom GO GPS Receiver
It shows a 'X' mark
the other users who faced the same error tried this instructions and solved the problem as follows:-- We have a result!
After calling the helpline to find it was number unobtainable! I returned the unit to Halfords who called another helpline number. They took my e-mail address and when I returned home an e-mail was waiting with the following instructions which worked.
I now have a fully functioning TomTom! Thanks for the advice fellas:
Thank you for contacting TomTom Customer Support.
In this email you will find the solution for the error on your TomTom. This solution can be used in the following situations:
• The device hangs in the start screen (splash screen)
• An SD-card with a red cross is displayed on the screen
• A picture with a red dot and white cross is displayed
• The device can’t be turned off
If you haven't already done so, please download and Install TomTom Home from http://www.tomtom.com/7602
If you don’t have a full backup of your TomTom yet we advise you to make one before continuing with the steps in this email. You can make a backup by following the steps below:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Click on 'Backup and Restore -> Backup' in TomTom Home 2.0
3. Enter a name for the backup and click [OK]
• IMPORTANT: When the software is asking to delete parts from the backup click [NO]
After the backup is made you delete the files from the root directory of the TomTom. Follow the steps below to do this:
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the [x].
Next we will reinstall the application via TomTom HOME.
1. Start TomTom HOME on your computer
• TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click on 'Update my device'. If you get the message 'No Items Available', or there is not an application to download, click on 'Add Maps, Traffic, Voices etc -> Items on my computer', select the application and click on 'Add'.
3. Select the Application update.
4. Click on 'Device -> Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer.
5. On a PC, in the System Tray by the computer clock, click on the 'Safely Remove Hardware' icon and disconnect the TomTom also in this way.
When switching on the device it should boot as normal again.
Nov 03, 2009 | Tomtom GO 720 GPS Receiver
Flashing X on TomTom but cant get it off on spotlight on my mac!
Make a full backup onto your computer making sure all files are shown. Do not use tt home. Make sure you have a copy of your map in your backup. Do not format. Delete everything on your tt. Connect to tt home and tt home will reinstall the navcore for your device. Copy and paste your map from your backup onto your tt. You should be set to go. A reminder you will lose all your preferances and favorites when you do this.
May 31, 2009 | Tomtom ONE GPS Receiver
I recently uploaded a tomtom map to my tomtom 1 series 3. Do I need to remove the map of England before I can get access to the french map?
Since you TomTom only has a 1 gb flash drive you will have to remove the map of England to put the map of France on your TomTom One Third Edition. Make sure you make a backup of your map of England or you will have to purchase a new map of England Do not use TomTom Home to do this simply make a new folder on your desktop. Connect your TomTom to the PC. Next go to "My Computer" and open the drive of your TomTom. After opening the drive of your TomTom copy your map of England and paste it into the new folder you made on your desktop. When you are ready to put the map of England back onto your TomTom just copy and paste the map of France into the new folder and copy and paste the map of England back into your TomTom.
May 13, 2009 | Tomtom ONE 3rd Edition GPS
TomTom Go 630 malfunction
re install/repair the software
May 04, 2009 | Tomtom Go 630 GPS Receiver
Can not use computer voices on my tomtom 520t
On your device you may have a corrupt file that is causing the noise distortion when you use the computer voices. The solution to this is to completely remove the software from your device and reinstall it again as described in the steps below. Please ensure that you have the latest TomTom Home software installed on your computer:-
You can download and install the latest version of TomTom HOME from the following link:
http://www.tomtom.com/home
Once you have the latest version of TomTom Home installed, please follow these steps:-
STEP 1. Creating a Manual backup of your TomTom
• Charge your unit for at least two hours (preferably via the home charger)
• Perform a reset on your device (see: http://www.tomtom.com/6965 )
If you have not made a backup yet you can do so by making a manual backup of your TomTom. To do this, please look at the following web page:-
http://www.tomtom.com/3171#backup
• Connect your TomTom to the computer
• Open My Computer, you should see the TomTom as a removable drive, double click into it. (on a mac you will see the TomTom as a disk drive on your desktop)
• You will see a list of files and folders.
• Copy all of the folders on the TomTom, one by one to the backup folder. DO NOT copy the 'Loquendo' folder.
• This can take up to 1 hour to complete depending on the device.
• If you get any error messages while copying, move on to the next folder and copy that to the backup folder.
• If possible, please make a note of any error message that occur while copying the folders, and make a note of which folder causes the error message.
IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your device as described in step 1. If you are unable to complete step 1, please reply back with a list of yellow folders that you have managed to successfully copy to your PC and also reply back with any error messages that you receive at this point.
STEP 2. Format the hard-disk,
• Open 'My Computer'
• Right click on the TomTom icon (the device should be seen in drive E,F,G,H,I etc) and select 'Format'.
• Do a full format by selecting FAT 32 and click on Start, do not select 'quick format'. The TomTom is now formatted.
• Disconnect the TomTom from the computer and switch it on. It will load up with a red cross on the screen.
• Reset the TomTom with a paperclip in the reset hole for 30 seconds, see http://www.tomtom.com/6965 in how to do this.
• Once Reset, switch the TomTom off, disconnect it from the computer and then switch it back on again, it will still show a red cross on the screen.
STEP 3. Restore the Folders to the TomTom
• Connect your TomTom back to the computer and make sure it is switched on
• Go to your backup folder on your desktop, double left click into it. You will see all of your backup folders.
• Copy the folders one by one to the TomTom by right clicking on the folder, select copy then open My Computer, double left click onto the TomTom drive and choose paste.
• Turn the device off (with the on/off switch) and disconnect it from the computer.
• Switch the TomTom back on.
STEP 4. Update your device
• Open TomTom Home
• Connect your device to the PC
• A list of updates should appear, if not, click on Update my Go
• Select only the program application update.
• Click on Update and Install.
• Once Installed, open TomTom Home
• Click on 'Device -> Disconnect Device'.
• Switch your TomTom On to complete the installation.
The Application is now installed, and your TomTom should now be working.
STEP 5. Run the Clear Flash Tool
• Close TomTom Home. (on a PC, make sure you close TomTom Home from the system tray in the bottom right hand corner of your screen by the computer clock)
• Download and run the clear flash tool from : http://www.tomtom.com/updates/clear_flash/clear_flash.exe Make sure your TomTom is connected to the computer and switched on when you do this.
STEP 6. Install a computer voice
• Open TomTom Home
• Click on 'Add maps, traffic and voices -> computer voices
• select the voice of Kate and install it.
The Computer voice is now installed, and your TomTom should now be working.
Dec 06, 2008 | Tomtom GO 910 GPS Receiver
TomTom GO700
Hi there
This happens because files on your card are corrupted after an unsuccessful download.
If you have a card backup at hand, put the card into a computer, format it , and restore backup.
After that the TOMTOM will restart working normally.
If you did not make a copy or backup of the original card, or you cannot reach the computer hosting the last backup.Then follow the procedure below to restore your data :
1. Uninstall the application
2. Reinstall the application
attention_25.gif We highly recommend backing up your device before continuing. questionmark_25.gif
This will preserve any maps and voices you may have purchased.
1. Connect your device to your computer.
2. Go to Computer (Vista), My Computer (XP) or your Desktop (Mac).
3. Double-click the TomTom disk drive to open your TomTom.
4. Make sure that hidden folders and files are shown. To do this:
  • Vista: Go to Organize > Folder and Search Options, click on the View tab and select the option Show hidden files and folders.
  • XP: Tools > Folder Options..., click on the View tab and select the option Show hidden files and folders.
  • Mac: With the exception of some system files, your Mac should already show all hidden files and folders on the TomTom drive.
5. Identify the map folders on the TomTom. These are named for countries or regions such as USA_and_Canada, North_America or any other country or geographical region.
6. Delete all files EXCEPT these map folder(s) and the folder titled ASR, if it exists (the ASR folder will not appear on every device).
7. Properly disconnect the TomTom from the computer and exit TomTom HOME, if it is open.
  • Vista/XP: Right-click the TomTom drive and choose Eject.
  • Mac: Drag the TomTom drive to your Trash.
8. When the TomTom boots you should see a screen with the flashing X.
Proceed to reinstall the application (below):
Sep 09, 2008 | Tomtom GO 700 GPS Receiver
TomTom 720
Hi Robert,
Well first let me say I am sorry to hear you had these problems. Now its unfortunate that again you have a problem that sounds from you description is corrupted data.
Theres not much can be done unless you have made a backup of your TomTom to your PC as theres no way to restore the data / files to working condition other than using a backup. So, if you don't have a backup then it looks like you need to return your TomTom to retailer once again.
Can I suggest for you and any other TomTom users reading this. If you do get an NEW or exchange unit , before using it for the first time, connect to your PC and perform a backup of the files contained on it or on any removable media ( SD card and similar on some TomTom models ) this way if theres any problems in the future a reinstall of the backup might produce a solution.
Good luck
Sep 08, 2008 | Tomtom ONE GPS Receiver
When turns on shows a computer screen and red cross
Hi there
Apr 20, 2008 | Tomtom ONE GPS Receiver
Flashing x
eave on charge for two hours, then with the SD card out (if it has one) hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Feb 21, 2008 | Tomtom GO 910 GPS Receiver
Tomtom XL 330 Car GPS Receiver Logo
166 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
