Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper not feeding into Canon Pixma MP210 printer.
When I attempt to print, the printer grabs the paper in the lower right hand corner (I'm facing the printer), crunches it a little, then rejects the whole sheet. I see there are 11 other complaints of the same problem, some of whom solved it by pressing a heavy card through the rollers. That hasn't worked for me.
The online manual for the tool is useless. Your help would be gratefully received.
Thanks,
A.J. Garr
  • junglejuice Apr 16, 2009
    I thought I had something stuck in it. I shook it upside down, but to no avail. I then tried the card trick (mentioned above). The card got stuck, but when I pulled it out a small key(I must have dropped it it) popped out! Fortunately, now it works fine.
  • Anonymous Apr 29, 2009
    I am having the problem,with my Canon Mr210 printer,the paper is not going thru,and any solution to this problem,would be of great help.It work at one time,and have not been working since then.I keep getting the error button,and it is telling,the paper is jammed.Thank.
    New Friend:
    Problem Solver:
  • 7 Answers
Https://www.youtube.com/watch?v=2qM5By8V8IM
Posted on Jun 20, 2017
SOURCE:
SOURCE: paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Posted on May 08, 2008
SOURCE: Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Posted on May 11, 2008
SOURCE: canon pixma mp170 all in one printer
Seems to work a little better when I adjust the plastic clip that slides to fit the paper, so that it feeds straight ... still have problems with jamming, though
Posted on Aug 30, 2008
APremkumar
  • 564 Answers
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
Posted on May 26, 2009
  • 240 Answers
SOURCE: my canon pixma MP210, is not feeding the paper
There is a foreign object in the paper tray. Because it is curved you cannot see it. It is stuck in the narrowed area right before the feeding rollers.
Disconnect the cables and rotate the printer in a way it stands on its back.
Open the front cover. Use long thin flat screw driver that can go trough the paper out area and to reach the feed roller.Insert the screw driver between each pressure roller and the the feed roller to release the object. If successful it will fall out from the tray. Usually it's a coin, pen, point-protector, ruller, paper clip and so on.
Posted on Aug 01, 2010
CANON PIXMA IP2200 DOES NOT FEED PAPER
Several suggestions here include printing a heavy card instead of regular paper, or turning the printer upside down to remove any object like a key stuck in the printer.
Dec 20, 2017 | Canon PIXMA iP2200 InkJet Photo Printer
My canon pixma MP210, is not feeding the paper through, seems to jam, but printer still is printing. The paper is taken about 10cms into printer, then twists slightly but does not fee through. Have checked...
Aug 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Printer feed will just not grab paper
Rollers need replacing. They are supposed to have tread like tires, if not, Replace.
Apr 06, 2010 | Canon Office Equipment & Supplies
Paper pulls to the right, jams, won't print, tried different paper still won't print
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Grabbing the paper pulling it in at the left hand side
1) Try to adjust lateral directing limiters for paper.
2) See attentively inside device no there stranger subject such as pencil or piece of the torn paper. Use the lighting of the lamp or flash-light.
Mar 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jamming and feeding unevenly
Apr 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper completely jammed
check if there is a little paper that stuck on it that causes a paper jam
Mar 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma ip 2200
send me printer driver canon ip 2200
Nov 12, 2007 | Canon PIXMA iP2200 InkJet Photo Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
5,545 people viewed this question
Clive
Clive
old marine
old marine
