Question about Samsung HLP4663W 46" Rear Projection HDTV
TV turns off by itself.
The tv simply shuts off completely. Set can be turned on after a breif moment.
  • 7 more comments
  • cowsad Sep 15, 2007
    The tv does not turn on automatically, it only turns itself off. The remote must be used to restart.
  • murch1000 Nov 13, 2007
    I have the 56" model. Same problem with it turning off by itself. Seems like it is temperature related. The three lights in the front all blink when it shuts off. I tried moving the remotes and turning away from the set to be sure they were not the problem. I am thinking I must need a new fan eventhough I can still hear the current one working or a new lamp eventhough the picture looks fine.
  • maxrider Nov 14, 2007
    52" hitachi, picture will go turn multiple colors and if I turn the tv off it will go back to normal, and the tv turns off by itself
  • Anonymous Jan 30, 2008
    the television turns on for about 5 minutes and shuts automatically off.
  • Chaunceyai Jun 19, 2008
    my samsung turns on for a brief moment then immediately turns off then all the power buttons blink!
  • kaylijon Jul 15, 2008
    My HLP4663W shuts off after 20 minutes of watching and then I have to turn it back on again and it shuts off every 5 miuntes. Can't enjoy this television.. Anyone with a solution to this?
  • netbrowser Jul 27, 2008
    My Samsung TV (HLS6188) behaves this way after about 1.5 yrs. Sometimes, when i turned it back on, it stayed on for a long time. Sometimes, it shut down within a few minutes.
  • Anonymous Aug 15, 2008
    tv turns off by itself after a few minutes
  • digitalsanto May 11, 2010
    i have the same problem, my tv ONLY shuts off automatically, it doesn't go on automatically.  any other suggestions?
  • 790 Answers
Ok cowsad! you have defective tact switch relace all tact switches! the tact switch is have only resistance if you press it, but now ithink your switches is now have smal resistance thats why your tv is on and off automatically.
Posted on Sep 14, 2007
    Scholar:
  • 136 Answers
In my knowledge of TV tact switches if that was the case it would turn itself on as well but stranger things have happened /shrug
Posted on Sep 15, 2007
SOURCE:
Hisense tv troubleshooting
Check the tv menu settings...go to where you set the date and time etc... usually in the general section..
Look for timer or timers...turn off sleep timer, turn off power on timer and turn off power off timer...cheers
Feb 06, 2018 | Televison & Video
Over tv its getting aoutmatically off
Hello
Put your hand on the back of your TV to check for overheating, if your set keeps switching itself off without warning.
Many TV sets come equipped with a safety feature that switches the power off if the set gets too warm.
Check the cooling vents located at the rear of your unit. Vents can collect dust and dirt, resulting in the fans becoming blocked and failing to work properly.
Remove dirt from the vents with a damp, clean cloth. Ensure the air conditioning is kept at adequate levels in the room where your TV is located. Keep the drapes shut on hot, sunny days to keep the room cooler.
Check the sleep-timer function on your TV if it keeps turning off. A sleep-timer is used to turn a television set off after a certain period of time has elapsed. If the sleep-timer is not turned off, your television will continue to turn itself off after a certain period of time.
If the problem persists,then a heat sink has gone bad.
The on/off button simply toggles a low voltage circuit that powers your tv. If it is dusty, it may complete the electrical circuit and send a false signal.
Take a can of compressed air, open the back and clean the dust off the circuit boards.
NOTE;opening the TV VOIDS warranty!!
Dec 22, 2010 | Televison & Video
Picture shuts off
Is there a dark patch when you see the picture, easiest way to check is on the tv tuner with no cable attached, this way you have a grey static screen, if there is a darkness across the screen when it lights for that breif moment, then it may have a broken backlight tube. Had the same problem with my 32" LG.
Jul 29, 2010 | Astar LTV-32ASB 32 in. LCD Television
Loud noise now tv wont turn on
More than not if it is a loud noise shortly after you turn the set on, the color wheel is bad. The color wheel is not available by itself and requires the complete light engine to be replaced. The part number for the light engine is 75002250. I would suggest having a technician replace this for you if this is the case. Please take a moment to rate my answer. Thanks...
Nov 25, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
'95 Toshiba CF32E50 TV turns off by itself
there is a microswitch relay it will be a black square box that controls the power from the transformer ive seen those cause that problem before
Apr 24, 2009 | Televison & Video
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
RCA TruFlat TV
You may have a loose solder connection on the circuit board inside your set.
You need to have a technician check it for you.
Stargazer
Jan 16, 2008 | RCA 27F530T 27" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Tv turnitself off and on at will
This sounds like a power supply problem possibly a bad capacitor
Jun 19, 2006 | Quasar SP-2023D 20" TV
Samsung HLP4663W 46" Rear Projection HDTV Logo
529 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
