Question about Fuji FinePix F700 Digital Camera
Digital camera monitor black, does not save picture
All functions semm to work, except the taking of a picture. The monitor shows settings, but not the view of a picture. Flash works, no picture is save to floppy. I have replaced battery, and floppy, did not cure problem. Monitor function indicates picture taken, but is black. No image appears on monitor in any moide. Tried formatting floppy, did not help.
  • thisthat Nov 27, 2007
    All functions semm to work, except the taking of a picture. The monitor shows settings, also show picture, but when i take a picture is all black.
    Flash works, picture is save as a black screen into the floppy.
  • Fuji Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=839010&prodcat=2147483647&sscucatid=664262&quicklink=true
Applicable cameras include:
F303, F410, and F700
Posted on Dec 23, 2007
  • 63 Answers
From the symptom it indicate that the lens module is faulty,you need to replace the lens module. most of the digital camera the lens module is very costly.
Posted on Sep 14, 2007
Nikon d40 monitor is black when camera is on
Does the menu show when you press the MENU button? Can you see your pictures when you press the Playback button (right-pointing triangle)? If so, then there's nothing to fix.
The D40 works as SLRs have worked for half a century. There's a viewfinder which allows you to frame and compose your picture. The LCD monitor is for menus, camera settings, and picture review. LiveView, which allows you to use the monitor for shooting, is a recent development, which Nikon introduced into their cameras with the D3 and D300, both introduced years after the D40.
Dec 05, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
My D70 was working normally when I last used it. I left it safely stored at my vacation home for three months, and when I tried to use it today it appeared to take pictures, all functions seemed to be...
The shutter in the camera lens is not working, the motor that controls the aperture has failed or the related gears. This device will require a camera specialist to resolve the issue and an estimate recommended.
May 03, 2011 | Nikon D70s Digital Camera
Camera will turn, applications will show in monitor but monitor will not turn on. AF is working, flash is working, but no picture will be taken nor can images be seen in monitor...it is black with the...
It's better for both of us if I just upload some diagrams, it's not complicated but I'd most likely miss a step in the description.
First Diagram
This diagram will show the arrow buttons and the sequence
Diagram
You should be good to go
Jan 20, 2011 | Nikon Coolpix 885 Digital Camera
I bought a tasco Digital Trail Camera it works great except that it does not take any night pictures did I forget a setting or is there a default?
If it takes no pictures then you set it for day only. If it takes pictures that are black then the capacitor that controls the flash is not functional.
Nov 08, 2010 | Sport & Outdoor - Others
Nikon coolpix 4300 monitor lights up and displays
It is time to replace that camera. If the sensor is bad it will not take pictures, if the play back does not work it will take picture but no show. If you camera wont do either than it is too far gone for repair and should be replaced.
Nov 19, 2009 | Nikon Coolpix 4300 Digital Camera
No display powershot a75
Did you get a solution to your problem? I am experiencing the exact same thing with my A75. Still takes pictures and displays them for the 2 second preview, then back to black. And they download fine, too. But I get the same black screen in every mode except stitch assist and movie mode. Thanks.
Jun 06, 2009 | Canon PowerShot A75 Digital Camera
Camera menu and all features function except it wont save picture
The problem is inthe two sections.
1) Bad CCD . replacement will solv the problem.
2) Thin film ribbion cable carrying signal to the shutter / apparture control gets damaged in regular use. replacement of the same will solve the problem. Have to take the help of a repairer.
Mar 21, 2009 | Nikon Coolpix 5700 Digital Camera
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
MPEGMovieVX DSC-P200
There is a sensor behind the lens of your camera that takes light and converts it to electrical signals that in turn is decoded by the board. If the sensor is damaged, there will be no picture to display only what you have in the memory stick. Work on it. Good Luck
Jul 03, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Fuji FinePix F700 Digital Camera Logo
88 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
