Question about True 72 cu. ft. / 2039 liter Commercial Freezer GDM-72F
Gdm 72 with remote temp goes from -10 to 20
Freon is correct. pressure switch??
  • Dennis Boxerman May 11, 2010
    can you give some more details? Be alittle more specific with the problems and I will try to get it going for you.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 24, 2010
Why gdm 72f cap tubes
That freezer is meant to have a stable load an example is storage. A supermarket application would require a tx valve.
Apr 28, 2014 | True 72 cu. ft. / 2039 liter Commercial...
How to put hardstart kit in compressor GDM-72
depends if it is only a two wire hard start.. then wire it parelel with the run capacitor . place line to line and load to load . load goes to compressor and line to power which is usualy realy the neutral for a 120v compressor since the hot runs to a overload and straight to the compressor
Sep 13, 2013 | True 72 cu. ft. / 2039 liter Commercial...
Where are the Freon nodules for a True GDM-72 cooler?
SEALED SYSTEM REPLACING COMPRESSOR ON COMMERCIAL FREEZER
Aug 08, 2013 | True 72 cu. ft. / 2039 liter Commercial...
True gdm 72 goes below 20 degrees
Usually a blocked condenser fooling the thermostat into running overtime. Possibly thermostat fault but less likely
Apr 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
My true cooler freezer in side fans dont turn on i run it for 15 min. the make is gdm-72f
first place to look is in the evap where the defrost/ fan delay is located. It is usually attached to the "U" tube on the evap and senses the temp. It prevents circulating warm are after a defrost. It could be bad and keeping the fans from running. Start there and let me know if I can be of further help
Jan 27, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Product in my true gdm-49f freezer is frosting up and there is an ice build up around the inside of the case. what could be the causes of this.
Try defrosting the unit by shutting it down until all ice is gone. If this corrects the problem and the ice returns you may either have a defrosting problem or a low freon charge.
Jan 20, 2011 | True 49 cu. ft. / 1388 liter Commercial...
My freezer is having uneven temps throughout. Some areas freeze the items solid and some not at all. the fans are running and all areas are at a temp below freezing....I am in a panic . This freezer is a...
I would check all seals and make sure there are no air leaks. From what you describe there may be several areas that allow warm air to enter and cold air to escape. If the humidity goes up in your location and the door is open a lot it can cause havoc with consistency.
Sep 21, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Freezer not Cooling
Marc is correct, you should check to see if you have a blocked filter (this should always be changed when a system is vacuumed and refilled) or you may have oil in the line(s) causing the blockage. But you should know that there is a blockage because your low side pressure will be lower than it should be or in a vacuum and your high side pressure will be much higher than it should be. The blockage could be oil, or a plugged filter or even moisture in the system which will freeze at the end of the capilliary tube in the evaporator which blocks the flow of the refrigerant. But if this was the case the freezer would start to cool down but only for a short time from first start-up then warm up as the capilliary tube plugs up with the frozen moisture. I would suggest that you remove the refrigerant, purge the system to be sure there's no oil etc int he lines, remove the old filter and install a new one, put the system into a deep vacuum for several hours, refill the sytem with the correct amount of refrigerant and monitor it to see if there's a change. Good luck
Sep 15, 2006 | True 72 cu. ft. / 2039 liter Commercial...
True 72 cu. ft. / 2039 liter Commercial Freezer GDM-72F Logo
57 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
