Question about Quartet gbc QRT670S Wall or Ceiling Projection Screen, 70x70, Matte White Screen/Black Matte Casing Projector Screen
I have quartet projection screen mounted on a wall over a counter. Is there a way to adjust the cam so that the screen bottoms out at the counter. Right now, it is either too short or too long.
3 Suggested Answers
AVWIZARD
  • 3 Answers
SOURCE: My quartet projection screen will not go back up.
The problem is most likely a damaged spring end cap. As you face the screen from the front, this is the cap that covers the right end of the cylinder that encloses the screen material. The cap is held in place by 3 Phillips head screws. If you remove the spring end cap, you will see a slot in it that is designed to hold the spring assembly stationary as you pull down on the screen. If this slot is damaged, then the internal spring inside the roller will lose tension. The fix is to pull out the screen & roller assembly, roll it back up manually, then replace the spring end cap with a new one. (I believe the part # from Quartet Apollo is K0329). The cap at the other end has a cup receiver designed to accept the pin end that is on the left side of the cylinder that houses the screen material. The tricky part is fitting the pin end back into the pin end end cap. It is easier with 2 people. If you fashion a short hook out of a coat hanger. you can use it to lift the pin end into the pin end cap. There are part #'s and exploded diagrams on the Pegasus part sales website: http://shopping.netsuite.com/s.nl?c=440001. The site is down now for maintenence, but it should be back up soon. HTH
Posted on Jun 23, 2009
I subscribed just to say thanks a million, Mr. umright!!!
I thought I ruined my screen even before properly installing it, but your leather belt trick was pure genius! It took a little effort, but I was able to make my screen roll up again without dismantling it!
Posted on May 13, 2010
How do I lift out built-in KitchenAid glass cooktop KECT 365 when mounting brackets wern't used
You are either:
A) missing the mounting screws and brackets that hold the unit in place
B) it is stuck and will require brute force to remove
C) both
Dec 30, 2013 | KitchenAid Cooktops
Tip
Projection Screen Tip
When mounting a screen on or near a wall, consideration must be given to items such as marker boards, maps, and pictures that will be placed on the wall behind the screen. Be sure to leave enough clearance behind the screen surface to eliminate the possibility of damage.
on Aug 16, 2010 | Office Equipment & Supplies
Needs cleaned and on the top and bottom of the the picture it is bowed up like the lenes need adjusted
The mirror may have been partially detached from the back wall.
Take the screen off and check it.
PLEASE RATE THIS ANSWER
Aug 13, 2011 | Philips Magnavox 51MP392H Rear Projection...
My Model TV # is 51swx20B. Two days ago the picture started having a lot of green in it and no blue. What is the repair needed.
Do adjustments on focus block. Will have to open front panel access door, focus block blue will be on left, green will be on top. Top screen bottom focus. Turn clockwise to increase, counter clockwise to decrease brightness. Turn the color all the way down on menu where it's pure black and white and make adjustments for perfect black and white picture, then when you adjust color, it will be perfect.
Aug 09, 2011 | Hitachi 51SWX20B 51" Rear Projection...
I have an ULPT-X Omni Mount that I will be using with a Samsung 65" LED. How do I mount the ULPT-X to make sure that the exact center of the TV will be in the center of the wall space it will be hung on. ...
What do you mean by centered on the top and bottom? It doesn't need to be centered in the exact part of the wall for the tv. it all depends on what your viewing height is for where you want the tv vertically. Once you figure that out you mount it where you want it for your personal viewing preference.
Thank you,
Lee
Oct 26, 2010 | Televison & Video
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Go to the manufacture website,or Ebay.com or Amazon.com have many electronics acessories.
Sep 28, 2009 | Quartet gbc 550S 71" 1:1 Projector Screen
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
2002 headlight adjustment
Need to pull your car about 20 feet from a wall. turn your lights on and adjust your screw and you will see the light beam go up or down. If your screw in on top it will be counter and if its on bottom it will be clock.
Oct 23, 2008 | 2002 Toyota Avalon
Screen Voltage
is the black box about 3inx3in insize and can you letters on it and may the words focus or screen if so thats it the pots are counter sunk and must be adjusted with an insulated screw driver ,if your not sure get a tech to do it for you.
Aug 26, 2007 | Samsung HCN4226W 42" Rear Projection...
Quartet gbc QRT670S Wall or Ceiling Projection Screen, 70x70, Matte White Screen/Black Matte Casing Projector Screen Logo
49 people viewed this question
Top Quartet gbc Televison & Video Experts
Electro Med Services...
Are you a Quartet gbc Televison and Video Expert? Answer questions, earn points and help others
