Question about Whirlpool Refrigerators
Refrigerator continuously cycles
The compessor cycles on & off continuously
  • 358 Answers
This is a generic problem with Whirpool refrigerators.The start relay for the compresor(located on the side of the compresor under the black plastic cover) is probably bad ,replace it(about $ 20) with a new one(write down where the wires go) that should solve the problem if not the compresor is bad.
Posted on Apr 15, 2009
Only getting warm air from a/c.
low on freon does the compressor cycle on and off alot? or the temp acuator isnt working or compessor failure i wd ck the presurres 1st if the low and high press. is close 2 the same its the compressor
Jun 03, 2012 | 2003 Chevrolet Monte Carlo
It doesn't cool, and in freezer side its collecting water, and also water dripping in the refrigirator .
If this is happening while compressor is running normally , first check temperature of condenser coils (black tubing)while running. If hot to touch,compressor is ok.(Good news)If not hot ,it's shot,or your defrost heater stuck on.(not likely)
If compessor not coming on at all it could be a control problem.eg thermostat ,or stuck defrost timer.
If compessor wants to come on or you hear clicking ,suspect start relay or start capacitor.
hope this helps
Aug 15, 2011 | Whirlpool ET8WTKXK Top Freezer...
My refrigerator stoped cooling so i removed the back panel & noticed the compessor trying to cycle, but would make a clicking noise and kick out...how can i test to see if its the reley or compressor?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 04, 2011 | Amana ASD2626HE Side by Side Refrigerator
What type of freon does the walk in refer take
How about a compressor model number. This will identify the Refrigerant used.
Dec 07, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
Compessor cycles on and off repeatedly
Have you checked for any air leaks on all the pipes and hoses on the compressor ? Air leaks are the most common cause of continuous cycling.
Aug 23, 2010 | Ingersoll Rand 2545/7100 Electric Air...
Compessor is running hot, fan is not running
need to know brand and model. which fan was replaced ( evap or cond ) . if evap fan it may be the door sw as some model only run fan wth door closed. if it's the cond (fan) motor then ck wiring at compressor . or borken wire. in or about the compresser area .. hope thes help . mm
Jul 05, 2010 | Refrigerators
AFD253DEW has stopped cooling
check cold control or defrost timer. then check compessor
Jan 02, 2010 | Amana AFD2535FES Stainless Steel Bottom...
Refrigerator isn't cold but freezer is
sounds like u have a air flow problem , most common problem could be the damper or also called the difuser. it opens and closes to let air into the fresh food side. also if the frz fan motor is not working , then it will also not be able to send air to the fresh food cycle even if the difusser or damper is open. 1st check to see if you hear a fan sound in the frz. if u do then its not a evaporator fan motor problem. if u dont then u may have a bad motor. the motor should be running antytime u hear the compessor running. hope this helps
Oct 06, 2009 | Whirlpool Refrigerators
Does not cool
bad compessor
Feb 22, 2009 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
