Question about Garmin StreetPilot 2720 GPS Receiver
TOUCH SCREEN SOMETIMES IT WILL WORK AND SOMETIMES IT WONT IT WILL ALWAYS WORK WITH THE REMOTE. BUT YOU CANT TOUCH IN THE COMANDS.
  • 3 more comments
  • radiometfan Nov 07, 2007
    I have a streetpilot 2610 with the same exact problem! Garmin tech support suggested a software update (which I did). Any techies have thoughts on this?
  • phatboi Nov 07, 2007
    My touchscreen just stopped working. I can't get past the home screen. Please advise if anyone knows how to fix this problem.
  • Anonymous Jan 01, 2008
    I can use my street pilot 2720 with the remote but the touch screen won't work at all.
  • bafire_murph Feb 01, 2009
    my 2720 touch screen is not working anymore after downloading new maps. when i turn it on i can click that i will not use while i drive, but when i try to use the screen again it wont work anymore.
  • James521 Feb 20, 2009
    Touch Screen will not work. It is not the screen b/c I can hear the clicks when I touch it. Tried the software update to no avail.
Try recalibrating the touchscreen
Posted on Oct 22, 2007
SOURCE:
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
Jan 11, 2016 | Tablets & eReaders
Tip
Remote code info
look around on the web. their is a few sites that have codes for most brands of remotes/tvs.
but before you buy a new remote, research to see if remote will work with your device.
sometime it only works with limited features, sometimes you wont find your deivce on the list, in that case you will have to do a code search.
always do research on any device you buy.
cheaper is not always better.
on Apr 09, 2014 | Televison & Video
I have a Samsung Mythic and when I touch the screen, no matter where I touch it always activates way lower than where I touched. For instance if I press on a name in the address book, even with a little...
You may have it set on jester comand which should be under setting- advanced settings -asscibilty. check to see if Jester comand is set on.
Hope that helps
Apr 03, 2017 | Samsung Cell Phones
My air conditioner wont turn on and i think it is because of a setting on the remote that i have touched accidently. now i cant turn it on can you help
Take out the batteries from the Remote and wait for sometime. Replace the batteries an switch on again. It should work OR if there is a reset switch on your AC press it and start fresh again.
Nov 21, 2009 | Heating & Cooling
My ipod touch is showing me a screen where is says to plug it into itunes and when i do it says i cant because i have to enter my password but i cant because the screen wont change what do i do?
Use the Five Rs to restore the iPod. You will lose the data that is currently on it if you restore but you can always re-sync the data to the iPod.
http://www.apple.com/support/ipod/five_rs/
-=/ Daft Tech /=-
Oct 26, 2009 | Apple iPod touch
My ds touch screen doesnt want to work
it can be a connection come loose inside the ds. theres a ribbon that is held in by a lil black plastic slide that pushes under the ribbon which clamps it in to place which means then pushes it against the connection. an it might have simply came out and now the screen has come on but the "touch" part of it wont work. i know this as i fixed my own on my ds. its very easy to fix if you know what your doing.
Aug 13, 2009 | Nintendo DS Lite Console
Screen is blue says composite, no signal.
TRY AND FIND VIDEO BUTTON ON TV REMOTE AND PRESS VIDEO BUTTON. ON THE MENU USE UP OR DOWN ARROW ON REMOTE TO CHANGE FROM COMPOSITE TO ANALOG TV.
Feb 01, 2009 | iLO 3200 32 in. LCD Television
Palm Treo Touch Screen
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus
Jan 23, 2008 | Palm Pilot Professional
My GPS system is having seizures
The solution is listed on the garmin site but it is not clear
The problem is with the infra red remote reciever on the unit
Sometimes the sun acts like the remote is being pressed and that is when it shakes
the solution, and I hope you still have the unit cause there is nothing outthere like it.
Answer: from garmin site Normally this issue is caused by sunlight from certain angles hitting the Infrared (IR) port on the unit. This makes the unit react as if the remote control was communicating with it. This makes it switch in between screens just like if you were using the remote.
You can disable the remote IR port on your StreetPilot® 26xx unit by:
  1. Powering your unit ON
  2. Press the Menu button
  3. Touch Options
  4. Touch the General tab
  5. Press the Menu button
  6. Touch Disable remote
If you wish to use the remote again you can enable the remote IR port on your StreetPilot 26xx unit by:
  3. Touch Options
  6. Touch Enable remote
http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=2610+remote+off
Dec 26, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin StreetPilot 2720 GPS Receiver Logo
219 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
