Question about GE Dishwashers
GE Dishwasher not draining the water out
Dishwasher GE GSD2100N00BB is not draining the water out even after changing the motor/pump kit and selenoid. The drain on the bottom of the dishwasher is clean and the hose is not cloged or has any kinks. Also plug from trash disposal has been removed.
  • 1 more comment
  • eddavid1020 Apr 26, 2009
    Motor/pump comes with the flap and selenoid and thinking that the replacement motor/pump was bad a second one was tried and I still have the same problem.
    Drain inside the dishwasher is clean and hose does not have anything blocking the water
    Model GSD2100N00BB does not have the piston.
  • eddavid1020 Apr 28, 2009
    Drain line is clear and not leaking either
    This dishwasher has no belts
    Pump is new, it came with the replacement motor/pump and solenoid (part #WD26X10013)
    The washing process sounds to be doing good except for the water not coming out.
    Took the dishwasher out and the drain to the patio and water coming out has no pressure........in order for the water to come out, hose has to be at floor level, if I lift it to the garbage disposal height water will not come out.
    The one I have now is the third pump that I have tried and all have the same problem.........
  • GE Master
  • 3,866 Answers
There is a pump that pumps this water out of this unit have you tested the pump itself outside of the unit to see if its is pumping water at all? the motor pump kit you bought for this unit was it certified by the manufacture to be a actual replacement for this unt? Dishwashers are so inexpensive they can be baught for less then what the old one is repaired for. I seen a slew of information and you bee nthrought a lotf of experts for information i am jst wondering if there getting any benefit from trying to help you out with your issue?
1. check pumps outside of unit!
2. check hoses for clogs outside of unit!
Make sure these pumps are geting signal to pump water from unit. You need this part direct from them
part# WD19X10020
and
part# WD21X479
Thanks and rate me please!
Posted on Apr 28, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Apr 28, 2009
    Make sure the pump is nor reversed by accident!!! just a friendly reminder!
    Sergeant:
  • 291 Answers
I will provide you with all the data on possible causes and their possible fixes.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Apr 26, 2009
  • jamesrated Apr 26, 2009
    check all the above possibilities i gave you.
    thanks and please do not forget to accept the solution
    Genius:
  • 1,689 Answers
Hi eddavid,
thank you for using fixya.
with regard to your issue, here is the possible cause. The check valve is worn and letting water back in the tub while it is draining there for not draining all the water out.
Can temporarily be repaired with a cork until i can get a new check valve.
You may also try to restart dishwasher with rinse only and as soon as it starts push reset and it will drain water out.
Going deeper into the appliance, the dishwasher has a rubber flapper style check valve located between the soil collection chamber and the drain line. These go bad and restrict the water from draining out. Also some models have a valve under screen in back called a piston valve if this has debris keeping it from opening and closing or is deteriorated you will need to change this also.Start washer let fill initiate pump out water should exit rapidy into drain if its slow check both items above
Hope this helps, if you have other question, please do not hesitate to let me know.
Regards,
voodoo
I have a Hotpoint BF71 dishwasher. I put it on but it hasn't worked, it filled with water which won't drain not will it even start now. I took out the filter but I couldn't find any blockages Help!
Reset the power at the breaker, but you may need a new pump and motor assembly. The same pump washes and drains on most Hotpoint models- a solenoid is used to open a drain flap and let the water out, but a bad pump will equal no wash or drain... Hotpoint Dishwasher Pump and Motor Assembly WD26X10013 Hotpoint Dishwasher Drain Solenoid Kit WD21X10268
Jul 11, 2016 | Hotpoint Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
GE GSD2000J01WW dishwasher , full of water at bottom of machine
The drain motor (pump out motor) in line with the outlet pipe could be faulty. This motor must spin (to pump out water) in the drain mode. If AC (mains)voltage is across motor in pumpout mode and the motor does not spin indicates that the motor is open circuit and needs replacing. Has one of the 2 motor push on electrical connections dislodged?
Is the outlet pipe obstructed?
Jan 22, 2010 | Dishwashers
Water is puddeling on the bottom of my 18 yr. old GE dishwasher
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Sep 22, 2009 | EuroTech 24 in. EDW194E Built-in...
Water not completely draining from dishwasher
clean and inspect pump broken fins may need pump kit
Aug 15, 2009 | GE Nautilus 24" Built-in Dishwasher
Ge quietpower 3 wont turn on
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or Control Board
Aug 05, 2009 | General Electric Adora GHDA670N Built-in...
Dishwasher won't drain?
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jul 15, 2009 | General Electric Adora GHDA670N Built-in...
Dishwasher will not drain. had to install a pump kit because the macerator blade had stripped off. It rinses good now but still will not drain. The drain solenoid works well
OK, check the following areas to combat this issue further.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 18, 2009 | GE Dishwashers
GE DISWASHER - PDW7300J00WW- WATER STANDING IN BASE OF UNIT - WATER DOESN'T DRAIN. CHECKED HOSE TO DISPOSAL AND TO UNIT IT IS FREE OF OBSTRUCTIONS? wHAT NEXT?
Check the following to address this issue--
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 03, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water in dishwasher will not drain.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 02, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
581 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
