Question about Philips Epic 17PF9936-37 17" Flat Panel LCD Monitor
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
Philips 17PF9936/37 now has no video, I get sound, and a bit of blue flashing on the screen. The power light starts out green, then blinks red after a couple of minutes. The power supply measures at +12.3 volts ok. I have tried connecting the video into all ports but no change. Any ideas? Thanks.
  • 3 more comments
  • GP151001 May 01, 2009
    Ordered replacement capacitors and replaced them just fine.
    However, I noticed the cable (philips part #313913102961) going from the scaler board to the LCD display had several wires with insulation that was missing. The wires were touching eachother. I went looking for a replacement cable at the Philips support page (support.philips.com), Encompass_parts.com, and andrewselectronics.com. The answer I got was "it is no longer available."
    So, I tried to repair the small, 40 pin cable end by removing the pins. I got most pins out, but cracked the connector. The pins were not repairable nor reusable, and of course, the connector is not available at the above sources either.
    I don't recall ever seeing one exactly like it. Maybe someone knows what it is called? Or where I can get the replacement pins or connector?
    fyi:
    I ordered the capicitors from http://www.part-express.com, and also ordered replacement connector pins (WM2562-ND), that "may" work from http://www.Digikey.com that go to a Romex connector of similar dimensions. We'll see if they work once they come in.
  • GP151001 May 03, 2009
    I agree. Philips discontinued providing the cable assembly, and couldn't/wouldn't tell me anything about the connector. Somewhere there are probably hundreds of these things sitting in a bin or box. At least the individual pins I received from digikey.com can be squeezed into the connector. They are longer and have a wider diameter but can be forced into the plastic connector. So, that will be my next project. Thanks.
  • GP151001 Jun 04, 2009
    It's fixed! I found a replacement cable athttp://www.shopjimmy.com. Unfortunately they mixed up the cable packs initially, but rectified it after a phone call.
    So, after following the advice here, I replaced the bulging capacitors and smoked multi-colored ribbon cable, I am good to go. Thanks!
  • Lou Ebert May 11, 2010
    GP151001, LCD TV's are similar to LCD computer monitors and subject to same faults that are common in both types of these devices. If you do not own a 20-25w fine-point soldering pencil and know what to look for and replace bad capacitors that have failed, you will not be able to repair the unit. I assume that you may have a VOM/DMM to measure the AC to DC Black-Brick power supply that sits on the floor? Inside the unit is another type of supply called an INVERTER. It takes 12vdc and turns it into 800 to1200v ac to light the Cold Cathode Fluorescent tubes on the rear of the lcd panel. There are also 2 other power supply circuits that get power from the 12.3v brick. they provide +5volts and maybe 3.3v to provide voltage to the digital signal processing circuits and audio circuits.
    Your problem lies inside the TV/monitor and may only need some new capacitors to be installed. to see typical bad capacitors, visit these sites that have posted pictures. http://forums.pcper.com/showthread.php?t... and http://www.net/blog-entry/specialed/2008/12/31/how-to fix-your-lcd-monitor and pkrobot.freehostia.com/LCDRepair5.htm then you will know what to lookfor inside your tv set. then you will have a better understanding of what you are dealing with. Hope this has been of some help. I'm louie12fix on fixya or lmistyrel@ aol.com Bye for now.
    Novelist:
  • 152 Answers
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Posted on May 03, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
42 Philips tv won't turn on just blue light flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sep 10, 2015 | Philips 40PFL4706 40 LED-LCD TV - 16:9 -...
Flashing light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Unlike other brand TVs, reading the blinking codes to Philips is different. Check the linked site by type in 'Philips' at its search box, and press Enter.
Apr 14, 2014 | Philips 32PFL5403 LCD TV
Sound on but no picture
Is the screen pitch black or a blue/grayish ? Dim the lights in the room, and shine a bright flash light on the panel. Turn on the set, if you see a faint picture, you have a backlight issue
Dec 13, 2012 | Philips 52PFL7403D 52 in. LCD HDTV
I have sound on my philips tv but no video
Hi
There are some circumstances for which this type of problem occurs to your TV....
You'll need to do this in the dark or low light conditions! Make sure TV is off. Now turn on the TV. If the TV "glows" when you turn it on, the problem is the TCON board. There is also a slight chance that it's the main input board...but this is less likely. However if the TV does not "glow" when you turn it on, the problem is the back light inverter boards.
Also hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don
Jan 03, 2011 | Philips 190B6CB/27 19" LCD
Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 20, 2008 | Philips 32PFL3403D/27 32 in. LCD TV
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips Epic 17PF9936-37 17" Flat Panel LCD Monitor Logo
406 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
