Aqb24j2wc shuts off before reaching set temp. lower temp & it runs for a few minutes & shuts down again. it will not start on it's own.
  • wlme Apr 15, 2009
    When I turn on the A/C, it turns on briefly and shuts off and then seldom turns itself back on to cool. It's definitely not 64 degrees in here, like the thermostat show it should be.
  • 400 Answers
Check the thermistor sensors on the evaporator
Posted on Apr 15, 2009
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
Rooftop rv air conditioner unit will run but will not shut off. Have cleaned both filters.
Sounds like the thermostat is faulty. To check it turn it up to the max temp. It should shut off in a few minutes (providing the interior room temp is lower then the max temp setting). If it still does not shut off remove the t/stat from the wall. Pull off one of the wires it should stop. Re-attach the wire, if it starts up again soon as you re-attach the wire, replace the t/stat..
Jul 29, 2014 | Dometic Rooftop RV Air Conditioner
Engine only reaches temperature after I turn it off
please check if cooling fans are running all the time- only should come on when engine temp reaches fan temp setting- google it for exact temp
Feb 21, 2014 | 1994 Chevrolet Suburban
Outside unit runs for about 5 seconds then shuts off for a few seconds. It repeats this cycle.
Put in a 5 minute time delay. It is a two wire device in line with the contactor. Sounds like it is set to 75 turns of at 74 and repeats. The tstat should have a differential of 2 degrees as well.
Dec 22, 2013 | Heating & Cooling
Jandy LX250-L Burner shuts down and no errors
It is more likely the board on the LX.
If you have a volt meter check the IND connection on the Fenwal for 24volts while running and keep your meter on it until it shuts down. If the power is still present at the IND while shutting down then it would appear to be a Fenwal problem. It sounds like the temp circuit on the board or the temp sensor it self is bad. Try dipping the temp sensor in a glass of water with a confirmed temp to see if it is accurate.
Apr 03, 2017 | Pool & Spa
Spa heateer run by Balboa 500Z control box. Standard mode will not shut off. Lowering temp to 88 still gets temp up to104.what is problem?
Sounds like the temp probe is not working or is disconnected. Temp going high, motor running means that it is calling for more heat which brings both the heater and the pump on until after set temp is reached. Once reached, heater will turn off and a few seconds later the pump will shut down.
Check connections for the temp probe. If connected make sure probe is where it should be. If it is, might try to replace it before considering the control board.
Aug 25, 2012 | Garden
Motor shuts down when reaching normal operation temp
Sounds like the mass air flow sensor or the air intake temperature sensor. Sometimes just wiping out the throttle body/air intake can make all the difference
Good Luck and Happy Motoring
Jun 22, 2017 | 2000 Dodge Durango
I have a 1991 buick regal stalls and shut off after warming up
egr valve is not opening up when the engine reaches it normal operating temperture
Feb 07, 2010 | 1991 Buick Regal
Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Aug 03, 2009 | Heating & Cooling
WHIRLPOOL NO-FROST REFRIG/FREEZR MODEL-EHT201ZKWR5
looks like operating normally...
the fridge as it reaches it's temperature shuts the compressor off and then after a few minutes..the fridge would increase temperature again and would turn back the compressor again.
its the thermostat which is cutting on and off the compressor.
and i think it is normal. based on the temperatures that you indicated..it is cooling very well..0 F in the freezer and 40 in the refrigerator... that's good.
drcool
Nov 06, 2008 | Whirlpool Refrigerators
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
