Question about GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZDI15CBBC stopped making ice
I have a small leak in water hose underneath the ice bin. I cut water source for a day or two to try to fix problem. when I turned everything on, no ice was produced and unit did not cool. I ran cleaning cycle twice, but still no ice. any suggestions?
SOURCE: ge monogram zd115c automatic icemaker not making ice
Unfortunately, this has been a regular problem with mine for 6 years.  It started within the first week of installation.  I suggest calling GE and keeping track of when you called, who you spoke to, etc.  Every single part has been replaced at lest once and I am still without reliable ice.  I have been asking or a replacement since day one.  GE is not good on the customer service end of things.
Posted on Sep 15, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
  • 286 Answers
SOURCE: uline clr2060 produces little ice
First thing is to remove the water from the trough. Pull out the grey standpipe in the back of water trough. Then see if the grid has a good frost pattern.If the frost pattern is NOT even then you need a service call to check the sealed system. If you do have a frost pattern check to see if the water is splashing over or make sure the drain is in the bin drain hole.If water is getting in the bin then the ice can melt as fast as it makes it.Make sure your cleaning with U-line cleaner.
Posted on May 28, 2009
SOURCE: GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Posted on Jun 04, 2009
woodchuck789
  • 4066 Answers
SOURCE: ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Posted on Jul 01, 2009
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
Water overflowing in ice maker tray on a GE
make sure your refrigerator unit is level first . If it is , and you have eight square faced plastic cover on the front of the ice maker itself that can be removed by un- snapping it, remove it and see if there is a small screw with a spring underneath it or positive or negative arrow's on the unit where the screw is located. Regardless, if there is a screw all by itself turned the screw 1/2 turn Counterclockwise. this will decrease the amount of time the water valve is open during the ice bin filling cycle.
Mar 13, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Ge monogram bottom freezer ice maker spills ice
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice maker or supply line leaking water at icemaker
Hello Carltomoree,
Interesting question(s)...
Problems COULD be a lot of things... but since you have gone to all the trouble to locatize A PROBLEM... I would LOOK
right there first... and fix that...
PLASTIC FITTINGS do often split and fail... or simply need to be reseated and firmly tightened... (do not overtighten).
Water valve... too strong... (probably not)...
BECAUSE a leaky water delivery can have
a profound effect on the fill of the ice cube tray...
Allow the refrigerator to stabilize... SEVERAL DAYS
and then start worrying about the fill level...
Ice makers are TYPICALLY adjustable for different water flows.
so the amount of water delivered per cycle... or delivery of small cubes ... even the frequency of delivery can usually be adjusted
Worry about that LEAK first.
Check out the link below...
A whole new head is still available for your refrigerator
but wouldn't it be nice if it were only an inexpensive
PLASTIC coupling or a split PLASTIC feeder tube...??
Partselect
http://www.partselect.com/AdvancedModelSymptoms.aspx?ModelNum=ZFSB27DAGSS&mfgModelNum=&fkMfgID=2&Source=msac&term=ZFSB27DAGSS&utm_source=adcenter&utm_medium=cpc&utm_term=ZFSB27DAGSS&match=p&utm_content=m830071057&sw=zfsb27dagss+parts&ModelMasterID=110865&PID=13
appliancepartspros repair-help
http://www.appliancepartspros.com/repair-help/general-electric-refrigerator-zfsb27dagss-repair/zfsb27dagss-leaking.html
repairclinic: whole head kit
GE Refrigerator Ice Maker Assembly WR30X10093
Carnac the Magnificent
Jun 23, 2017 | GE Refrigerators
GE Monogram ZISS480DMCS Ice Maker Problem
Check and make sure that the float arm in the ice bin is down and able to swing. This arm should be down until the bin is full of ice which would raise the arm and stop any water flow until ice cubes are removed, and allows the arm to drop again to start the cycle all over again, to replace the ice that was used. The arm has a spot to snap in and be held where it would be in a position all the way raised, to allow the bin to come out for cleaning or all of the ice removal from the bin, such as to dump the ice in a cooler. The arm should be gently pulled down to hang freely and will slowly raise on its own as the bin fills with ice.
Jan 02, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZDI15C Automatic Icemaker Logo
88 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal DeAngelo
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
