Question about Dell Dimension 2400 PC Desktop
DESK TOP TO WIRELESS CONNECTION
DELL DIMENSION 2400 DESK TOP TRYING TO CONNECT TO INTERNET BY MAKING MY DESK WIRELESS WITH BELKIN G WIRELESS USB CONNECTOR ADAPTER
  • catmillin5 Apr 15, 2009
    COULD SOMEONE SOLVE THIS PROBLEM FOR ME
    Problem Solver:
  • 5 Answers
First make sure you have the correct drivers installed, go to the Belkin website to get the latest drivers for your device.
Next make sure that your router is set to broadcast, and that is in Wireless G mode. You can find that information at the router manufacturers website.
Posted on Apr 15, 2009
My dell desk top says check cable signal. where is the cable signal and how do i fix this problem
The cable connect the monitor to the computer you can check it by making sure it is connect properly,unplug it and then plug it back again because it may not be properly connected.
Aug 16, 2010 | Dell Dimension 2400 PC Desktop
New wireless network trying to connect to unsuccessfully
Try going to Network and Sharing Center - Manage Network Connections. Click on the connection and enable it.
Also try Network and Sharing Center - Manage Wireless Connections, and moving the wireless connection you'd like to use and move it to the top of the list. Select any operations that will enable or connect to the network.
Jul 07, 2010 | Dell Dimension 2400 PC Desktop
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
HOW IS THE WIRING SET UP IN MY DELL DEMENSION 2400 DESK TOP// I AM TRYING TO PUT BACK TOGETHER THE IINSIDE OF THE TOWER NOT SURE HOW IT IS SUPPOSE TO LOOK
Most of the connections only fit in one place ...
Here is the Service Manaul for the 2400 Dimension.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/index.htm
Jun 13, 2009 | Dell Dimension 2400 PC Desktop
USB ports and resolution failures
Reinstall your drivers you'll find them in your control panel
Apr 11, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400, wireless internet
Hi Whitney,
I was able to locate manual and a troubleshooting guide.
  1. Manual
  2. Troubleshooting Guide
Summary: Your modem only supports 802.11b standard, which limits the throughput to max. 11Mbps (compare to 802.11g = 54Mbps, 802.11n = 108 Mbps). In other words: your connection is only about 10% of the speed compared to a wired connection via Ethernet cable (100 Mbps). So - if you can - you should try to use a wired instead of a wireless connection, but you have to decide what makes is more important to you: having no cable and you can be away from the modem or the connection speed.
This also means - and that is in regards to APremkumar's solution - that you can skip all 802.11n adapters (this would just be a waste of money). Since you will not find an adapter that only connects to a class b network, look for something like "802.11b/g".
An example page is here. You can choose between an internal (PCI card) or external (USB adapter) solution. Both are ok and the decision depends on the availablity of a free USB port on your Dell and your comfort of opening the computer case or not. (You can always come back here and ask for help;-)
If you have any more questions, please let me know - I'm happy to help!
Mar 30, 2009 | Dell Dimension 2400 PC Desktop
Add wireless card
You can add one via a USB port like THESE
Or you can add one to an empty PCI slot on your motherboard if you have one available. Like This One
Mar 01, 2009 | Dell Dimension 4500 PC Desktop
Trying to get wifi for Dell Dimension 2400
Less expensive for recieving is simply the "usb stick" I would recommand a "ralink" chipset, (can be found in USROBOTICS and some less expensive brand like TOPLINK
Nov 26, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
189 people viewed this question
Alun Cox
