Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Zenith z tv only half screen
Have a zenith z tv philips remote has been used for years ...must have puhed wrong button by mistake...my tv has a black band that covers half of tv how can i fix?
  • 116 Answers
Most likely in PIP mode. (pic in pic)
Posted on Apr 15, 2009
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
Press the "TV" button on the remote to program the Philips remote to your television set
Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
A large pop and I lost my screen, it turned black
Its not the CRT, its the Y Sustain board.. This happened to mine 30 minutes ago.. and has happened to every owner of a plasma tv that uses the toshiba Y Sustain board..
Jul 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Need universal code for philips sru3004 universal remote
here are some sites with your code.
www.remote-codes.com
www.tvcodes.com
www.universal-remote.net/philipsmagnavox.html
Apr 15, 2009 | Zenith TVBR1342 13 in. Combo
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
TV remote a Zenith H20D50DT HealthView TV
i used a philips universal remote and just typed in the first zenith code in the list... it worked... so, hope this helps.
the call button remote would only go to a couple chanels and then turn off. with the universal remote i can go to input channel and that way can play xbox... helps with long hospital stays.
Jan 23, 2009 | Zenith ZN110 Remote Control
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
2 Problems
this answer has given also to some one had the same problem.
"On your remote should be a button called TV caption or text. Turn off the closed caption as someone hit it and turned it on by accident. If its not on your remote, then it is in the menu." Good Luck
You can also get a user manual at the link below:
http://www.retrevo.com/s/Zenith-C27A24T-TVs-review-manual/id/277ag102/t/1-2/
Jan 20, 2008 | Zenith C27A24T 27" TV
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Auxiliary button on tv remote (I believe) needs off and I can't get figure out how...
The remote should have TV, VCR, AUX and maybe CABLE buttons at the top, one of which will light up when any button is pressed. Since it is a universal remote, the button at top lights up to let you know what mode it is in. If the AUX button lights up when any button is pressed, it means the remote is currently set to the AUX mode. To set it back to TV, simply press the TV button at the top. This puts the remote back in the TV mode and the TV button should now light up when any button is pressed. If that works and you are using a cable box with that set, then make sure the TV is on channel 3 by pressing 3 ENTER.
Sep 21, 2006 | Zenith C27A24T 27" TV
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
