Question about Sharp AR-M277 Black and White Copier
Network Error on display
I am recieving a network error on my Sharp AR-M700 mutil-fucntion copier when trying to scan to email. I can ping it over the network and can still send print jobs to it via network, but It will not scan and send to email via network without getting the error. I think the error is c-00 and c-02. I got both of them today. Oh, yea I am getting this on two machines a Sharp AR-640 and a Sharp AR-M700
    Problem Solver:
  • 8 Answers
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Posted on Feb 21, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
If you’re getting this on both machines, it is your network...
There a few possibilities...
1. SMTP / DNS Info. Is that correct? Your It can help with this?
go to the Nic page of the machine (IP Address in win explorer) , go to admin page, which the pass word should be sharp , look for the network settings. look at both the smtp info and the gateway and dns info.. Verify that it is correct.
2. Have you changed your Internet Service Provider?
For example, Comcast is making a habit of blocking port 25. Embarq DNS information is a mess, their mail relay is a real hassle.
3. E Mail server information changed? Does your server require authentication, is the Time out set correctly?
Posting the correct codes really help in resolving these issues
Below are a few of the codes...
CE 01 The network card is not installed or broken
CE 02 the specified mail server is server is not found.
CE 03 The specified server suspends response during Transmission of images.
Posted on Oct 23, 2008
SOURCE:
Sharp AR-m162 is printing from my computer but refuses to scan to the computer. It worked fine yesterday.
Run Sharpdesk network scan tool. in low right of your taskbar click on network scan tool
create a profile in profile tab, This will show up on sharp display as an avaiable location to scan to.you can choose where to scan to and what program if any to open when recieving a scan. Next in scanners tab click "auto detect" it will find available sharp scanners on the network. check one you want to use in the box in the list click "ok" close it make sure it is running in the task bar and add it to startup if need be but you should be good to go after this
David
Nov 13, 2017 | Sharp AR-M162 All-In-One Laser Printer
What is network error (CE 03)
There is something not setup at all on the webpage or setup wrong on the webpage of the copier to allow you to scan to email. Need an IT guy make sure that your SMTP, DNS and reply address are correct on the webpage of the machine.
Nov 01, 2011 | Sharp AR-M455N Copier
Unconsistant scanning function error can't connect
first change usb cable.(blue one) remove software then re install.
May 25, 2010 | Sharp AR-M205 Copier
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
I have an AR-M207 machine scanning error msg
Is it possible to ping top this machine? My i.t tech just whispered into my ear and said perhaps the machine can't scan perhaps because the authentication name/password (login name/paddword of your pc) has changed, so the copier doesnt have the permission to write information directly to your computer.
Jun 08, 2009 | Sharp AR-M207E Black and White Copier
Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
Apr 09, 2009 | Sharp AR-168D Black and White Copier
Error CE while scanning though N/W in Sharp AR M-205
If subcode is 00 then network connection is problem, if 02, then its not talking to the network scanner tool on the computer. Might be an IP address problem, where the address in the webpage of copier is wrong for the PC.
Mar 19, 2009 | Sharp AR-M205 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
AR-207 on a network
Driver - Download correct driver for your model and install after deleting old.
http://www.driverskit.com/Printer/Sharp_Electronics/page2.html
Nov 08, 2007 | Sharp AR-207 Copier
Sharp AR-M277 Black and White Copier Logo
4,285 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
