Question about U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination
Open Thermistor on U-Line
I have a flashing light on my U-Line drawer refrigerator which indicates an open thermistor. The unit is also frosting on the back panel - is this likely to be caused by an open thermistor. Is this something I can fix myself and where can I find instructions?
  • 286 Answers
It might be a bad thermistor. I would need the exact model number. It could be a open harness as well.
Posted on Aug 23, 2009
Start button will click but won't start
Hello. Your model dryer has a service flash on the lower door strike/catch concerning not staying closed or not closing properly. If the door is allowed to open too much, the door switch will not be closed and the dryer won't run. The part number for the new kit is 279570 and it includes 2 door strikes and several catches. You choose the ones you need. However, if the door *is* closing properly, you can put the unit in diagnostic mode(door closed, all indicators off) by pressing/holding any button *except* stop for 2 seconds, then releasing, press/hold 2 sec, release, press/hold 2 seconds, release-- all the indicator lights will light for 5 seconds, and an 8 88 will be shown in the display. If there are *no* active fault codes, the indicators will momentarily turn off and then stay on with the 8 88 displayed. If there is an active fault code, it will be flashing in the display. (ex. would be an "F" and "xx" where "xx" would be a number.) If you press the same button you originally pressed once, then again, then again, the most recent code will be displayed, then the next, and so on up to 4 stored codes. To turn off diagnostic mode, just press stop. I hope this helps you!
F01 PRIMARY CONTROL FAILURE
F02 KEYPAD
F22 OUTLET THERMISTOR OPEN
F23 OUTLET THERMISTOR SHORTED
F24 INLET THERMISTOR OPEN
F25 INLET THERMISTOR SHORTED
F26 MOTOR DRIVE SYSTEM FAILURE
F28 MOISTURE SENSOR OPEN
F29 MOISTURE SENSOR SHORTED
F30 RESTRICTED AIRFLOW
F70 NO COMMUNICATIONS BETW ELECTRONIC ASSEM
F71 " " " " "
F72 THRU F78 CONSOLE ELECTRONICS FAILURE
Aug 23, 2015 | Kenmore Dryers
All od the sudden my side by side ge artica keeps refridgeratoor at about 40 degrees and freezer at about 16 degrees
Open the freezer and look for frost buildup on the back panel. If you see frost, you have a defrost problem. Possible causes are the defrost heater or evaporator thermistor. You will need a multimeter to test the components. The heater should show continuity. The thermistor should be between 10k and 80k? at fridge to freezer temperatures. Anything less than that, the thermistor is bad. Remove the back panel of the freezer to access. The heater is mounted to the bottom of the evaporator coils. The evaporator thermistor is mounted to the top of the evaporator.
If no frost, I would suspect the freezer thermistor. It's at the left lower rear of the freezer or behind a grill on the right wall of the freezer. Same thing, if it reads less than 10k? replace it.
If all the components check good, the only thing left is the main control board. You can find this behind a panel on the back of the fridge.
Part numbers: Defrost heater WR51X10055, thermistor WR55X10025, Control board WR55X10942.
Mar 05, 2011 | GE PSI23MGM Side by Side Refrigerator
Refrigerator not cooling freezer works fine blower motor in rear of unit on but turning slowly
Since the freezer is fine, you are in good shape. Pull off the back cover inside the freezer to inspect the evaporator coils. You should see a light frost pattern. If it is heavily frosted, then you have a open heater element - located at bottom of evaporator. If heater is good and you have heavy frost buildup, replace motherboard and thermistor which is clipped to the top of the evaporator.
Oct 01, 2010 | GE GSS20IEP Side by Side Refrigerator
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Blinking light on 2075DWRRB
Thermistors are calibrated together with the board. When you order a board thermistors will come with them. When you get the board (display) a thermistor will be with it. You will have to pull unit out. remove the back panel and you will see the wires for the thermistor on your left and it plugs into the right side. That should help you. just remove permagum and pull the thermistor out. It just site in a tube.Part number for that model is 68005
Oct 09, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Uline under the counter two drawer refrig seems to be running very hot, with ER blinking on temp gauge inside top drawer
Hi
Er means that somthing is wrong. It could be a temperature problem that caused it. Does it beep at all. That is a alarm for the door being open. You may need to check the magnet on the door and the reed switch on the wall. Upper left for the top drawer. and on the bottom is on the grill and door. Normally this is something I would ask for a tech to look at. But if you feel confident to try this I can get you into the program to see what its telling us. Now hold the up arrow and at the same time press and release the light bulb 3 times. Then release the up arrow last. If you did this right then you will have a 0 on the display. Yes, Then up arrow until you get to 3. Then press and release, It should give you a number. E# ? Let me know what this is. You may have a couple so write down all of them.
Now after you got the number then just push up arrow until you get to 99 then press and release the light bulb to go back to the refrigeration cycle.
E3= bottom drawer open to long
E10= Top drawer open
E1 = Thermistor #1 open
E5 = 10 degrees to warm E6 = 10 degrees too cold E7= Thermistor 2 E8=Thermistor 3 E9 =Thermistor 4 open thermistor 1 located top drawer Thermistor#2 I/M or evap if no icemaker
Thermistor3 is located in freezer or base if no freezer thermistor 4 is drain pan
Hope this helps
Jul 22, 2009 | U-Line Refrigerators
GSS22WGPD WW GE Side by Side Refrigerator
first remove freezer panel in back and check frost pattern on evaporator coil while ref. is running and evap. fan disconnected. should be totally covered in light frost.
Aug 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Refrigerators Logo
583 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
