Question about HP Pavillion a818n Desktop PC (Refurb) Pentium 515(2.93Ghz) 512MB 160GB (PS453AAR)
No display on computer
I have HP 1020n PC with m.b PTGD-LA, intel P4, 512 ddr ram and 200 gig sata hard drive. When I turn on the PC, monitor shows no display. My monitor is working fine with other PCs. My hard drive working fine with other PCs. I have to check Mother Board, RAM and processor. Which one should i try replacing? It do not give single beep or sound. Fans, CD drives etc working fine, no problem with PSU
Can anybody guide me?
  • 123 Answers
First thing is do you have a beep when the system boots? Sounds like you may have a BIOS issue I would start there........your RAM and processor are more than likely NOT the problem
Posted on Jul 31, 2009
Video wont show
Hi
Is your monitor on?
Then check the VGA [cable from the CPU to the Monitor] connections.
Try replacing the cable and see what happens.
Feb 28, 2012 | HP Compaq Presario SR5210NX Desktop PC...
Video wont show
This would be caused by several things.
1) bad power supply causing the computer not to start
2) bad video card
3) bad monitor (does the monitor light come on?)
4) other component bad--disconnect them all except the CPU, memory, and video card and see if you get an image.
I have a HP m7388a PC and the mb is faulty (video card doesnt work) (i tried it with a similar card and still didnt work) I dont want to buy a different mb as it will probably result in me having to...
you should not think about replacing the motherboard until you have exhaused all of the troubleshooting on your computer
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Apr 10, 2011 | HP Puffer2UL8E (51883631) Motherboard
The fan is loud when I turn it on and it beeps 3 times and there's no signal to monitor
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
don
Feb 15, 2011 | Gateway GT5405E Refurbished Intel Desktop...
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Unbuffered non-ECC DIMMs only
• Maximum total system memory: 2 GB; minimum total system memory: 64 MB
• Serial Presence Detect (SPD) DIMMs only
• Suspend to RAM
And yes, you can increase the hard disk.
Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
845 GLLY Maximum Hard disk support
Try first to reformat the 40 GIG hard drive that you have since it still detected under BIOS so hopefully that can still be reformatted and still work after that, but if still have the same problem this 40GIG hard drive may have alot of bad sectors already , Sorry to say but the 200 gig of sata drive wonto work for this motherboard since it doesn't support SATA drive , you can get a 1600GIG of IDE drive for this, this is teh complete specs of your motherboard
http://shopping.msn.com/specs/intel-desktop-board-d845glly-motherboard-micro-atx-i845gl/itemid63207496/?itemtext=itemname:intel-desktop-board-d845glly-motherboard-micro-atx-i845gl
Nov 04, 2008 | Intel D845GLLY Motherboard
Secondary hard drive
I had this trouble had to reset BIOS to default then it worked but would either recognize IDE drive and not SATA remove IDE SATA was recognized
Its something in the BIOS setup As I do not know your BIOS you will have to check it out with *********** board manual how to do it to setup both drives
Aug 08, 2008 | Intel Motherboard
I can't get the full capacity of 320 gig drive
the hard drive you bought is not compatible with your motherboard. I am pretty sure that your board is only compatible with IDE ATA hard drive. you can still use it as external hard drive though.
Feb 09, 2008 | Gateway M305CRV Notebook
Computers & Internet Logo
153 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
