Question about GE PSS25NGM Side by Side Refrigerator
GE Profile fresh food getting TOO cold
I have a 6 year old Profile Arctica model #PSS25NGM that is running on the cold side and freezing fresh food. The temp select LCD will show a temp, say 37. But when the select is set the disply will go back to cab temperature which has been steady at 29-32 degrees. The freezer side is working just fine. Set it at 0, it stays and reads 0. No matter where I set the fridge temp the 'desired' temp will read correct but the actual won't move much from the 29-32. Reading another post I checked for any obstuctions that might be holding any louvers open allowing freezer air into the fridge but I couldn't even tell if this model has them. I am thinking that a control board might be inacurate but I work on engines not fridges.
  • 10 more comments
  • jmwcatmech Sep 15, 2007
    Problem solved.
  • Anonymous Dec 16, 2007
  • DIY John Dec 16, 2007
    Fresh food side of refrigerator freezing food and not keeping temp setting of 37, temp ranging from 29-35 veg/fruit drawer freezing foods. Also water dispenser now not working either. Custom cool temperature board replaced Part #WR55X10168
  • baranacle Dec 29, 2007
    I have a GE PSI23SGMA BS side by side and is freezing the food. I tried to reset the temperature however it keeps resetting to itself to 28 degrees.
  • Anonymous Apr 07, 2008
    I'm having the same problem with this unit. Called GE to see if there was a
    recall ... they said no.
  • LearningNook Jul 25, 2008
    Same thing!  Same age too.  Just one month past my extended warranty - go figure.  Any ideas?
  • aldunn Sep 04, 2008
    I have the same model, six years old this August-2008. Digital display set at 37 and actual temp around 27-28. GE tech coming today. I may send to garage and buy something other than GE. This sucks. Everyone seems to have the same problem. GE losing numerous customers over not standing behind their product and repairing these existing issues, especially for such an expensive product.I am a retired Marine and I assure you I will get the word out.
  • Anonymous Nov 26, 2008
    I have the same problem. My refrigerator is almost 7 years old and is freezing everything. The eggs, milk, produce. I tried to reset the temperature and it resets itself to 29 degrees. Ive left the door open, it gets up to 47 and 5 mins after I close it, back to 29 degrees.
  • Anonymous Dec 09, 2008
    Exactly the same problem. No matter how high I set the temperature it goes back to 29 degrees. This refrigerator came with the house I bought - I left a sub-zero in my old house. I miss my sub-zero... :(. Would never buy a GE.
  • toachie Dec 16, 2008
    me too...salads freezing in drawers, milk freezing on top shelf...anyone able to get this fixed?
  • Anonymous Mar 02, 2009
    Refrig side is freezing food temp set warm still problem
  • ksubrian Apr 20, 2009
    I have had the same problem for years. Everything, including the fresh
    water container freezes in the refrigerator even with the temp control
    set at the highest level, 44 degrees. Have been able to control it
    somewhat by raising freezer temp to 6 or 7 degrees.
    Finally got tired of it the other day and tore apart the air
    distributor in the top of the frig section. I found a damper that had
    broken off from the control motor. What it looks like to me happened
    was that due to poor engineering by GE, the motor that moves the damper
    is allowed to run too long. Once the damper is closed, the motor keeps
    running putting pressure on the damper and breaking it.
    I found a replacement part at item #1055112.
    The part description even states that it has been updated to prevent
    freezing in the refrigerator. Have not bought the part yet to see if it
    fixes the problem.
    Ridiculous that GE never had a recall for this. I'll never buy another GE refrigerator.
  • 74 Answers
Faulty air damper is the usual cause , or possible sensor fault
Posted on Aug 28, 2008
  • GE Master
  • 5,323 Answers
All fridges have air flow control vents somewhere? some are manually set others are electronically or thermally digitally set, as for the readings wouldnt count on that to much as they can give false readings? eye and ear test is best, what u see and hear inside the freezer and fridge? My suspicions are with either the thermistors freezer and fridge ones, or the air flow control device, in ur case to far opened? lastly the cold control thermostat itself may be bad, u need a multi meter to test these. and can do a live test for voltage at the cold control thermostat as well as ohms test
Posted on Mar 14, 2015
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
The thermister located inside the wall of the fresh food compartment under a small ribbed cover must be faulty. The system telys on capacitances changes in the NTC(negative temperature coefficient) If the NTC is faulty then the dbrain will continue to send cold air into the fresh food compartment. I have a service tech's repair manual for a late model GE ice box right ova HERE
Jan 28, 2010 | GE PSS25MGN Side by Side Refrigerator
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Erratic temperature control. Freezer temperature varies from -4 to +2 even though set to -1, refrigerator also with wide variation. refrigerator is about 2.5 years old and this is a new problem.
Unles this is a big change and is not affecting the fresh food sect temperatures.Those should be 38 degrees for food safety. As far as the temperatures measurements those are easily altered by placing articles of packages near the thermistors in freezer and fresh food compartment. There are many issues you need to consider with the model refrigerator Artic/Profile. They are very sensitive to power surge and simple failures. Hopefully your being only 2.5 years out GE has resolved the problems of the past.GE is a good company and they do support their customers through the 5 year sealed system replacement. There are very many models of your type. Could you send me the model number listed for example PSS26MRSS. If you could I will get you some information that can help you save you repair cost in the end, Now if there is a problem with the thermistors we will need to resolve that because it will cause more problems later. Thanks Sea Breeze
Nov 10, 2009 | GE Profile¿ Arctica® Energy...
Can the fresh food drawers be disassembled?
yes they can be disassembled but it should not be special temperature drawer or zone which can be independetly controled otherwise you can change the temperature deviation in the compartment which can lead colder temp or below freezing .not good for the fresh food.
Jul 01, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Ge profile atrica not getting cold enough
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
Mar 22, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Side by Side is getting too cold on the fridge side.
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
GE PSS25NGM Side by Side Refrigerator Logo
2,451 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
