Question about Dryers
The noise appears to be located at the tensioning idler wheel. I removed it and the shaft is shiny along with the wheel bearing which is a sleeve bearing. It's lubed well and not wobbly on the shaft. When I lessen the tention on the wheel the noise subsides or even goes away. I placed a round file on the idler as it was running to smooth it out or rough it up (what ever) and it quited down for a while and now its back. Can a drum belt cause noise? It looks ok, has minor cracks but looks like it has much life left to it. Looking for suggestions :) Thanks, David
  • 72 Answers
If the belt has cracks it is wearing out and loosening up. everything is precise even though it is just plastic it matters. also make sure you use packing grease to lube it.
Posted on Apr 15, 2009
Dryer shutd off.
see the next steps and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out.replace the belt along with the idler pulley.
Idler pulley
Dryers have a tension or ideler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing houses if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play.
Blower wheel
Your dryer's blower whells pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower whell Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor
Jul 09, 2013 | Dryers
Whirlpool Duet Dryer Idler Pulley
see this causes and fix it. God bless you
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear. Check our videos for other style dryers.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out. Replace the Belt along with the idler pulley.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing housing if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play. This video walks thru another type.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower wheel. Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor.
Oct 02, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Hoover condenser dryer, drum is stiking, if i manually spin the drum ir will go bk in cycle
Rollers
Belt
Idler pulley
Glides
Rear drum bearing
Blower wheel
Motor
Oct 02, 2012 | Dryers
When the dryer tumbles, it makes a loud noise. What could it be? How do I fix it?
Go to Sears and purchase a new belt & idler pulley wheel for yours. The bearing in the pulley has dried up bearing causing this noise. The belt will be stretched and replacing it the same time will save a future headache
Dec 27, 2010 | Dryers
1997 chevy tahoe has developed a squeaking noise only under load between 1000 and 1500 rpm. noise disappears as soon as you ease off on the throttle. serpentine belt is in good condition. brakes are good...
unfortunatly you cant always tell on the out side of a u joint if its bad if you chalk the wheels and remove the drive shaft that would give you the definet be carefull not to let the caps come loose because you almost never find all the needle bearings any roughness in the movement or shiny spots are cause for changing hope this helps
Jun 10, 2010 | 1997 Chevrolet Tahoe
Maytag mde3000ayw - this dryer makes a lot of scraping noise and squeaking. What could be the cause?
Hello there:
It's noisy If your dryer is noisy, check these: Rollers Idler pulley Glides Rear drum bearing Blower wheel Rollers Manydryers use rollers or wheels to support the clothes drum. When theserollers are worn, they can be noisy. You should replace the whole setof rollers at the same time. Idler pulley Dryershave a tension or idler pulley that keeps tension on the main drivebelt. When it's worn, it can be noisy. When that happens, don'tlubricate it. Just replace it. Glides Manydryers use nylon or plastic glides at the front of the clothes drum forsupport. When these are worn, they can be noisy. When that happens,replace them. Rear drum bearing Somedryers support the clothes drum in the rear with a center spindleinstead of rollers. The spindle may be a ball-and-socket type supportor a shaft through a sleeve. When the components are worn, they maysqueak, squeal, or rub. You can't repair them. Just replace them whenthey're worn. Blower wheel Yourdryer's blower wheel pulls air over the heat source, through theclothes drum, and past the thermostats, then pushes it out the exhaustduct. The blower wheel, which is usually plastic, may wear out overtime. But if it's noisy, it may simply be clogged with lint. Clean theblower and test to see if the dryer is still noisy. If it is, youprobably need to replace it.
Dec 25, 2009 | Dryers
Dryer has a squeaking noise. does it need to be
Change the belt and check all of the bearings for play. If any have too much slack replace them.
Jun 23, 2009 | Dryers
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Idler pulley
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
Model 8600 , drum makes loud noise, not a squeak
HI,
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Jul 26, 2008 | Maytag Dryers
Dryers Logo
50 people viewed this question
Top Dryers Experts
