Hdmi to vizio tv not support!
When i plug my hdmi into my tv and into the back of my ps3. i have the ps3 off and i have the tv on the hdmi channel. i turn it on and it says not support! ive tried it on both outputs and on other peoples tvs with different hdmi cords. it worked before but suddenly stopped.
    Novelist:
  • 159 Answers
Hdmi conector in the tv is a connector really fragile. this is high technology soldering, meaning: the tiny connections around this small rectangle can unsolder from the printed board really easy specially when the consumer plug in and out really often the hdmi cable on it (or not often), the scenario gets worst when you have to change the main board (this board holds the hdmi conector) only because this failure. OPTIONS:
the component input is equal to the hdmi.
Posted on Apr 15, 2009
Vizio hdmi blacking out when displaying PS3 in 720p
in these case hdmi technology is new then ps3 you will use the hdmi or usb display mediator for ps3
Feb 09, 2012 | Vizio XVT3D424SV 42 in. 3D LCD TV
I switched my ps3 from one tv to my vizio, and the voices of the characters arent being heard, but all of the background noise is. i have it hooked up with an hdmi cable, and the video is fine. i checked...
Shot in the dark here, but sometimes HDMI cables get a little discombobulated... Try doing a hot plug by powering both the TV and the PS3 up and then removing the HDMI cable from both of them at the same time. Wait 1 minute, then plug them both back in at the same time. Good luck!
Jul 21, 2011 | Vizio M221NV 22 in. HDTV LCD TV
Hi I have a 32 inch hd vizio tv and a ps3 system and I bought s Belkin hdmi audio and video cable and I'm trying to figure out how connect the cable to the tv and ps3 to get hd channels and hd games and...
Cable: First you need to be using an HD Cable box to get the HD channels that your provider offers. if you don't, you can't get HD channels. Keep in mind that not all of the channels that your provider offers are in HD. Out of the 300+ channels that my provider Cox Communications in Las Vegas offers, they offer 91 of them in HD. If you have an HD box, you need to go into the settings menu and make sure that your video output is set to constant as you do not want it bouncing between different resolutions when you change channels. In your case you will have two options, 720p and 1080i (1080p does not exist for cable due to the amount of bandwidth required). Choose 720p because your set is under 40" and you won't see a a difference between 720p and 1080i except for that because it's progressive, HD may actually look better. (NOTE: although your analog channels will display at 720p, they are not in HD. They are simply up converted SD so don't expect that they will look like HD channels.) Also be sure to set your audio settings on your box to "HDMI out."
In general, HDMI devices should automatically detect HDMI input but since I don't know what kind of box you are using, it is possible that HDMI-out is disabled in the settings. My box (Scientific Atlanta) doesn't have that option, but I don't know about others. As far as the set is concerned, plug the HDMI cable into the input you want to use (if it's a new Vizio, I'm assuming there are three inputs as that's what my 32" Vizio in the kids' room has) and the set will auto-detect the HDMI input and automatically set the resolution accordingly.
SIDE NOTE: The only other way you're going to get HD channels from cable without a box is if you're using your COAX cable directly in to the TV and that is only if your cable provider has them floating on the line and you're only going to get the 5 major networks and Univision in HD.
PS3: This is even easier. WIth your PS3 powered off and your TV powered on, connect one end of your HDMI cable to the HDMI out on the PS3 and the other end to the appropriate HDMI input on your TV (of your choosing). Power on your PS3. Your TV will automatically detect the HDMI input from the PS3 and put that HDMI input on the screen. You will get an on-screen message from the PS3 detecting HDMI and it will ask you if you want o use HDMI or words to that effect (I can't remember the exact message... it's been a while). Choose "yes" and it will adjust the picture accordingly and should automatically choose the highest video resolution your television can display. To verify your settings, first hit the "guide" button on your Vizio remote control and in the upper right corner it will tell you at exactly what resolution it is displaying at. If it's not where you want it to be, on your PS3, go the Settings Menu and scroll down to "Display Settings" and the first item on the list is "Video Output Settings." Follow the step by step on screen menu prompts to determine your display settings, and choose "automatic" when prompted. If everything is copasedic, the highest resolution your television can display at will be listed at the top (and will be the current setting) and all of the other resolutions will be listed below it. If something is wrong between the "handshake" between the HDMI from the PS3 to the TV and it doesn't display in HD, go back into Video Output Settings" and when prompted, choose manual in stead and set the resolution on the PS3 the highest your TV can display. NOTE: Most 32" TV's have a maximum resolution of 720p fir the reasons I stated earlier. Check your manual for the specifics on yours. Furthermore, all PS3 games are in 720p so even if you have a 1080p TV, don't expect higher resolutions than that. AS far as Netflix is concerned, not all of their programming is in HD. The scale for Netflix is SD/Low/Medium/High/X-High. HD/Low/Medium/High/X-High, your quality depends on the program and strength of your Internet connection.
Closing: I'm a little confused by your issue as HDMI is automatic and you should automatically be getting HD so the only other thing I can think of is that your display needs calibrating and you just think you aren't getting HD. In order to get the most out of your new TV and your PS3, I would highly recommend that you calibrate your set with a Blu-Ray calibration disc that comes with color filters. It will take you about an hour or so to get the hang of and use correctly but the results will be very noticeable. The presets that come out of the box and the settings that they use on the floor in the store are awful and you don't realize how much you've been missing in picture quality until you calibrate. Do not rent this disc from Netflix as it does not come eith the color filters. You can buy a calibration disc at Amazon. I got the DVE one, from what I understand, the Spears and Munsel one is very good as well.
http://www.amazon.com/s/ref=nb_sb_ss_i_0_24?url=search-alias%3Daps&field-keywords=blu-ray+calibration+disc&sprefix=blu-ray+calibration+disc
Apr 23, 2011 | Video Game Consoles & Games
Hi, please please please help..... I have just bought a new Panasonic 42 Inch Full HD 1080p Widescreen LCD TV TX-L42U2B from Argos, I also bought the HDMI cable they recommended on the same website...
hello chis, it may the ps3 your having trouble with connect ps3 to hdmi 1 reset the ps3 by doing this. press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button this will reset the display setting on the ps3 you should get1080p if this dfon't work feel free to get back to me thanks
regards
shaun
Jan 08, 2011 | Sony Playstation 3 (PS3) Console
When i plug my hdmi cable into the back of my PS3, it says no input on my TV ?
you need to connect both the yellow red white cable and the hdmi cable into your ps3 and go the yellow red white av channel
go to the ps3 settings and change the video settings (ithink) to hdmi and also change the sound to hdmi
the screen will go blank and then the tv should change to the hdmi av channel if not change to it and accept the changes
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
How do I get from 480 to 1080p on my tv? I have an HD box on my vizio 42 inch tv but my channels are still showing 480?
1080P is a quality you'll only get with a blue ray quality video. Therefore, you won't get 1080P on cable tv. If your cable provider has HD channels available, you'll be able to get 720 or 1080i quality video (on those channels only). For the best quality, make sure you are using an HDMI cable. Just be sure your cable box supports an HDMI output. Your Vizio definately supports that type of input. If you have a PS3 or alternative blue ray player, you'll be able to watch 1080P.
Sep 12, 2009 | Vizio Televison & Video
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Cant tune ps3 to lg tv
Be sure you have the HDMI cable in the correct slot for the input channel you are trying to connect. Try another input channel like HDMI 2, 3, or 4 depending on how many channels you have. If you have another TV with HDMI, try plugging it in the other one to see if it is a problem with your TV or the PS3.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
My PS3 only works on my Plasma tv's HDMI channel. None of my other tv's have this HDMI channel. Why doesnt my PS3 work on any other channels or my other tv's? Could anyone help out with that?
When you have the ps3 hooked up through av cables on crt tv not hdmi. Continue to hold power until the console beeps again and this will reset which audio video output resolution back down so it can be seen and heard. Hope this helpes.
Jul 13, 2008 | Sony Playstation 3 (PS3) Console
PS3 HDMI output problems
Thanks it works,I have a vizio and did the steps.
May 04, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
2,864 people viewed this question
Top Televison & Video Experts
Electro Med Services...
