Question about Dell E228WFP LCD Monitor
Micro switch for on/off button broke how to fix and remove casing
Where to get spare and how to fit micro switch for on/off button broke how to fix and remove casing
  • cheechotta May 02, 2009
    Same problem - LCD Monitor's little on/off button has lost it's click and now the button is stuck permanently sucken inside the monitor, thus making it impossible to turn monitor on or off.  :(  I did nothing forceful - nothing out of the ordinary and it's busted.
    Novelist:
  • 152 Answers
Tonylpaul, Try mouser .com catalog pages 1282 thru 1291 You should find something that will work. Also visit YOUTUBE and search for lcd monitor disassembly videos to see how to get the thing apart. I'm louie12fix on fixya or lmistyrel@ aol.com Note: Is the switch Truly BAD? Did an elephant step on it? HMMMM ??? I wonder if this DELL has a power supply (internal) problem????
Posted on Apr 15, 2009
Tv power button
It seems that the micro-switch to turn on power is damaged. It can be replaced, and can be bought from most of the electronic spare part selling shops. De-solder out one among them as sample, because, pin configuration should be identified when you buy it. It wont cost more, a cheap component.
Jun 27, 2013 | Televison & Video
HP deskjet 3054 broken power button
Hp's usually have a micro switch underneath the power button. You probably just broke a support arm or type device. You might be able to super glue the piece back together and make it work. In my experience, this usually works about 40 percent of the time. Usually by pushing to ******* the switch to break the plastic you could have possibly damaged the small micro switch. My best suggestion is take it apart and try the super glue fix first. Good Luck!!
Jun 13, 2012 | HP Deskjet F2210 InkJet Printer
Replacement multi valve(micro switch) SUP 030 ADR
there are 2 micro switches on the multi valve i have 4 spare ones if your interested markpittock@hotmail.com
Feb 11, 2012 | Saeco Primea Cappuccino Touch Plus Coffee...
Basically i've broke my monitor buttons and was wondering if there's a way to remove the 'brightness' settings without having to press the monitor buttons, as it is constantly on my screen. thankss.
unplug remove screws take out the little white plug from by switches ...put case back on leave the white plug OUT fixed but no power light or buttons display works fine
Apr 04, 2010 | Samsung Syncmaster 17" 720N Monitor
A420n broke the button to turn it on needs replaced
When mine broke all i did was disconnect the two wires from the button, solder to a small toggle switch,drill a hole in the case and fit toggle switch,works fine
Feb 07, 2010 | HP Pavilion a420n PC Desktop
Karcher K6.50 possible pressure switch problem?
sounds like the unloader is stuck onthe machine which pushes against the micro switch.
follow the instructions for a parts diagram.
www.karcher.com
click on europe
then click on international
go to service and spare parts will open, click spare parts
then put in k6.50m on there will be another number on your machine 8 digit , easy way to find your machine, could 10 different models
Mar 17, 2009 | Garden
I have a hp dv6000. The left click button on touchpad stopped working. I've tried updating driver and that hasn't helped. Would you reccmmend replacing touchpad?
THE MICRO SWITCH ON THE PAD HAS BROKE AND YOU HAVE TO HAVE A SERVICE PERSON FIX FOR YOU OR IF YOU ARE INCLIND OF FIXINF YOU SELF, RADIO SHACK MAY HAVE THE PART, ANY COMPUTER OULET CENTER MAY HAVE IT, REMOVE ABOUT 12 SCREWS AND SOLDER IRON, UNSOLDER FROM THE BOARD RE SOLDER
ON THE CURCUIT BOARD RE ASSEMIBLE THE CASE AND IT SOULD WORK
ROD GANDY THE CANDYMANGANDY
Feb 02, 2009 | HP Pavilion dv4000 Notebook
Microphone/L button
sounds like your mic is disconnected or broke, it is a very small micro mic internally attached by a small wire. this wire could be broke.
For your L button, sounds like this is not making contact with the micro switch, sounds like you will have to take this baby apart to fix both issues.
If you have a DS lite the L and R buttons can be very fiddly to seat in place when putting it back together, the springs are fiddly. I would recommend bending the leg on the spring downwards so it seats in nicer when looking to reassemble.
Good luck
May 25, 2008 | Nintendo DS Console
Power Switch for this PC?
I've read your question & am still confused about which switch you need. I'm guessing that it's the power switch on your case that is broke? If so you can go to just about any auto parts store & buy a push-button two wire off/on switch. Even in a Low's store. It may or may not fit just perfactly on your case but it's better then turning the power off with a pen directly off the motherboard. Been down the road your on. It's either this or buy another case. You will not find your case a new switch. You can use your case's wiring connector to plug into the board listed on pg. 1-18 in your manual. It's two pins. You can splice the two pin connector from your case to a new switch's wires. As far as connectors go. You can buy a small pack of single connectors for a computer from radio shack to connect to the boards (power) ATX power switch. All the parts shouldn't cost you more than $10.00. Cheeper than a new case!
Feb 15, 2008 | ASUS A7V333-X (A7V333-X/L) Motherboard
Dell E228WFP LCD Monitor Logo
295 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
