Question about Breville Die Cast 800ESXL Espresso Machine
Everything sounds like its working...but nothing.
If I turn the nobe to the right to get the water flowing, water will come out. But when I fill the thing the coffee grinds go in and turn the water nobe to the right, it sounds like everything is normal but no coffee. Whe I take the coffee thing of it's hard to turn and the pressure blows the coffee about a foot away from the machine. There is a little water in the coffee grind holder, but thats it.
Another thing might be your coffee is too finely ground or tamped too tightly.  If water comes through the filter basket, try using a little less coffee and tamping less firmly.  If that works, you're all set.  If you still have a problem, you may need to switch to slightly coarser grind.
Posted on Oct 16, 2007
It sounds like your filter is clogged.  This can be tricky to unclog, but use the pin that came with the machine.  I have had the most success when I use the pin and try to run H20 (no coffee) through the filter basket.  Sometimes takes several tries, but eventually blows out the clog.
  • rsaintarnaud May 22, 2011
    Yes. That is the real problem with Breville : clogging of the ONE small hole on the bottom of the outer wall(bottom) of the filter.
    I solved the problem by cleaning the filter thoroughly by inserting a very fine needle in the small hole, and by boiling the filter in in a solution of vinegar for 15 minutes.
    To prevent future clogging by fine coffee particles, I put a piece of towel paper in the bottom of the filter before filling it with ground coffee. I use paper tissue folded in 8 that I cut as circular discs with scissors. This gives me 8 round paper filters.
    I have used this method for over 2 years now, and NO MORE CLOGGINGS!
    Raymond Saint-Arnaud
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
Oct 05, 2016 | Washing Machines
When I start the washer cycle on any cycle, it does nothing, doesn't fill, doesn't sound like its even moving. Dryer works fine. I checked power and I seen to have power coming out of thermocouple.
when washing machine is started ( after applying the wash settings as to water fill , load size rinse etc) the first action is to turn on the water tap solenoid
from there the water fills to the set level at which time the pressure switch turns of the water solenoid and switches on the motor to start the wash
following that line of procedure , if you do not get water flowing after pressing start, the problem is in the water control solenoid , tap turned off or problem in the program board
Call in a technician after checking the other items first
Feb 02, 2016 | Washing Machines
Knob won't work
Easy check for water filling problem like yours. Unplug the power and see if water still flows into machine. If yes----your inlet valve on the washer is stuck open and needs replaced. It is the part on the washer back where your fill hoses attach to. If the water is flowing into the machine while plugged in and it stops when unplugged, you have something in the control panel sending power to that inlet valve even when the machine is off. You would now need to find out where the power is coming from. If its an electronic control washer, the main board may need replaced.
Apr 11, 2015 | Washing Machines
I have a LG wm2487hwma washer that starts to get water and then gives the IE error. I ran the test where you push the spin speed and soil level buttons then the on then go 4 times. I went through the whole...
Have you tested your water inlets? It sound like you just tested the CCU. The IE error means that the water isn't filling at the expected rate (8 minutes). It could indicate that the hoses are faulty, the sensor (a reed switch) in the inlet valve is getting too much air and thus not spinning properly or there is a clog at the inlet filter.
First take off the hoses and put a bucket under them. Check if you have good water flow when you open the shut-off valves. If you have low incoming water pressure, your washer will not work. Check that there is no debris at the filter on the washer or at a filter cone at your shut-off for each hose. Clean or replace the filters. (There are anti-flood hoses that constrict the water flow when they detect a failure. We had to replace those hoses when only one failed. The cold water flow was fine. The hot water provided only a trickle. So, try new hoses.)
Make sure that the hoses aren't kinked when you replace them on the inlet. Double check that the drain hose isn't below the fill level of the washer. This will cause the water to pump out as it fills.
Otherwise, you will need to replace the inlet valves.
I hope this helps.
Dec 22, 2013 | Washing Machines
No water flow, low motor sound, weak steam
looks like your shower disc is blocked remove screw under head you well most proberly find it is blocked when looking up to light clean disc with brush until you can see through holes reassemble you will find flow and steam are better hope this helps
Dec 13, 2012 | Gaggia Baby Espresso Machine
I have a SE6TIE1, FD 8004 090109 Tecnik dishwasher and when i put my dishwasher on it only makes a little sound right at the beginning and then no sound and does not wash the dishes. I opened up the spray...
The water inlet valve, also called a solenoid fill valve, controls the flow of water into the dishwasher by opening and closing. If the water inlet valve doesn't open at all, water can't flow into the dishwasher.so it can not start the sequence.
Oct 25, 2017 | Tecnik Dishwashers
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore Top Load Model 110.82870100. Does not fill tub with full flow. Can make full flow by depressing and pulling out control knob several times.
It sounds like you need a new water level sensing transducer.
Unplug the power cord and turn off the water at the angle stops (you don't need to disconnect the supply hoses yet).
Release the front clips for the top piece and look for the transducer fairly high near the rear corner ( the parts people at sears will show you a diagram).
Sep 13, 2009 | Washing Machines
Kenmore Washer will not fill and run consistently.
Can't make any promises here. There could be several reasons for this issue. But from your description I would suspect that the hot and/or cold water hoses leading into the washer may be pressure locked. In recent years I've notice these hoses have been specially configured with a way to cut off the water flow in an emergency. Sometimes if you relieve the pressure on the hose the in-line cutoff valve will reset and the water can flow again.
Turn off the hot and cold water supply to the washer. Then dissconnect the water hoses from the spigot and reconnect. (relieve any pressure) Take this oppurtunity to inspect those hoses. Usually these flow controlled hoses indicated thier purpose with somekind of label (maybe even direction indication for water flow) Then turn the water back on. Dont open the spigot all the way just turn it on enough to get the water flowing. See if that helps.
Apr 24, 2009 | Kenmore 24032\24036 Top Load Washer
Water dispenser and Ice maker not filling with water.
You need to replace inlet valve for the dispenser and ice maker .
Dec 09, 2008 | U-Line Refrigerator Ice Maker
Breville Die Cast 800ESXL Espresso Machine Logo
774 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
