P4 PC with Antec power supply won't start when ''cold''.
My PC won't start on its own when cold. When I switch on the power strip and press the ''ON'' button, the fans will turn over, and the hard drive light will light for about one second. Then everything goes dead, except the power light.
I have found that blowing hot air from a hair dryer into the back of the power supply for about 10 seconds before turning on the power strip computer is all that's necessary for a normal start, but I'm tired of having to do this.
I operate the computer in a room that is about 67 degrees F.
I'm on my second power supply, which is an Antec Neo HE550. The previous power supply behaved in the same way, only it didn't take a hair dryer to start. It only took a two or three attempts before it finally started.
My motherboard is an Intel D865PERL, and I'm operating with Windows XP, two hard drives, one floppy drive and one DVD ROM drive.
550 Watts should be enought to get all this stuff going with no problem on the first try.
  • Travis18 Apr 15, 2009
    To Mr. Tech Geek: The power strip is ruled out as the problem because I could have the power strip switch on and switch on the PC's power at the PC's power supply and still have the problem. I have a volt meter and have measured the 5 and 12 Volt levels. They are right on the money. Yes, I have a video card.
  • Mr Tech Geek May 11, 2010
    power strip could be bad....do you have a voltage meter? try a different one..do you have a video card in the pc too?
  • 20 Answers
The first thing you should do is replace the power supply with another and see if the problem continues. if it does call me and we will work it out
Marc
215-729-1745
Posted on Apr 15, 2009
Is there a fuse
Yes there is, there is also a protection diode in line with the switch.
Aug 29, 2013 | Antec : True430 430W P4 ATX Power Supply...
LEDs on motherboard light up but computer won't start
It still may be dead. Go here and get a PSU tester:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=psu%20tester&bop=And&Order=REVIEWS&PageSize=20
Apr 24, 2012 | Antec : True430 430W P4 ATX Power Supply...
I have an Antec Truepower 2.0 TPII-430. This power supply provides power to the fans but when I push the computer power-up button, nothing happens. I installed another similar power supply and everything...
Test it. Unplug the molex connector from the mothrboard. You can use a wire or a paper clip to test it to power on. You will connect (short) pin 14 to and ground pin. (diagram here) For example, put one end of the paper clip into pin 14, and the other end into 13, 15, or 16. If the power supply turns on and fan running then maybe a problem with the front panel switch on the computer case.
P.S. make sure you unplug all other leads to drives before doing this.
Apr 06, 2011 | Antec : True430 430W P4 ATX Power Supply...
ANTEC MODEL SP-500 POWER SUPPLY SHORTED OUT
It is best you replace this power supply.
These power supplies have dangerous voltages inside the unit and if you do not have electronic knowledge, any mistakes you make can be fatal.
Feb 22, 2011 | Antec : True430 430W P4 ATX Power Supply...
Cooling fan for antec power supply pp 303xp does not come on when computer is switched on. Is this a replaceable item or do I have to buy a new power supply?
I THINK I REMEMBER reading that Antec had introduced a feature on some of their psu s where essentially the fan(s) were thermally controlled - if the psu was not working very hard it remained cool and the fan remained off but as the psu got warm with additional load it gradually increased fan speed. Perhaps this the issue you are seeing and nothing is wrong ?
PSU's are generally difficult to open and contain few accessible parts. some you can actually change the fan. I don't know about yours though.
Jan 04, 2011 | Antec PP-303XP 300WATTS ATX12V ATX POWER...
Re: PSU Antec NEO ECO 520C 520W RT This power supply was purchased through Newegg.com on 5 August 2010. It was installed into an Antec 200 Case in the same month. It has operated flawlessly until 1...
I agree with you about the power supply being faulty. Unfortunately FixYa is not affiliated with Antec nor sells or service any computer components.
You need to contact the supplier who sold you the power supply or contact Antec.
Nov 09, 2010 | Antec Computers & Internet
How can I test my Antec True 380sp is working properly
Would you like to do a full scale test or just see if it turns on?
Just to see if it turns on just hotwire it!
http://www.overclock.net/faqs/96712-how-jump-start-power-supply-psu.html
For a full scale test you need to buy one of these:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Description=power%20supply%20tester&bop=And&ActiveSearchResult=True&Order=PRICE
Or if you have the patience you can use a multimeter.
http://pcsupport.about.com/od/toolsofthetrade/ht/power-supply-test-multimeter.htm
Apr 21, 2010 | Antec True Power 380w (P4 Ready) Power...
P4 PC with Antec power supply won't start when cold
I haven't heard of a sensor that keeps it from starting when too cold. Usually in electronics, if it is a cold problem, there is a cold solder joint somewhere. When you apply heat, the joint solder expands enough to make contact and once electricity is flowing, the joint stays heated due to the resistance provided by the cold joint. Since the heat is applied to the power supply, I would say that the power supply is the problem again. If the power supply is still under warranty, I would exchange it or get my money back and go with a different name brand since you've experienced power supply problems with another model.
Dec 19, 2009 | Computers & Internet
I replaced my power supply with a new Antec 650
Let give it a try.
Turn off your computer and unplug it from main supply. Remove the battery for cmos bios. wait half an hour. insert battery again and reset the cmos through jumpers. Plug the main supply and start your computer.
May be it can help you.
Sep 07, 2009 | Antec 650W EarthWatts ATX Power Supply 80...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
