Question about Kicker ZR360 Car Audio Amplifier
ZR360 BLOWING UP MY SUBS
I have: a ZR360 mounted on a block of wood, through the carpet, behind the rear seat of my 95 Z28. The power comes from the battery through an appropriate power cable and into a distribution block, then another cable (8ga) into the amp. The ground...it's 8ga ( I think) is connected to the hatch lock assembly of the car...it's also where the car's deck and tail lights are grounded...as well as other things.( I figured it must be a decent ground point) The speakers are 10 inch subs which are mounted on a 1.5 inch thick board, side by side, and that fits over what used to be the trunk of the z28, actually it can hold four six packs stacked 2 x 2. Makes a perfect subwoofer encloser( I hope). I have the speakers connected in series- L+ to L+ amp/ R- to R- amp/ L- to R+ speakers. I ran the amp in Low-Pass Adjusted the gain about 10 oclock from dead 8. I turned the H/U about halfway up. I put U2 in. Halfway through 'Streets with no name' the subs started to shake, hum, pop, and then the cones just started pounding like something out of a bad trip and tore right out of the frames. Then all hell broke loose and if it wasn't mine, I'd laugh myself stupid. The subs just slapped and thrashed and wailed, but wouldn't die. I bought 2 more 10 inch subs and mounted them the same way. The worked fine, like the other ones, but after a while, the same thing starts to happen and then I shut it down. The subs react when: I tap the module I hit a pot hole I touch them while their powered up Turn the gain past 10 oclock I've checked for loose wires, connections, I've taped the leads, the connections, the wires. Any thoughts? Thanks
PUT YOU SUS INTO A BOX , OR SELL ME YOUR AMP, THANKS
Posted on Apr 03, 2009
  • 631 Answers
The ZR series amps had several problems that could be an issue for your amp. The modules failed and caused intermittent problems. If you know someone with a similar amp, try to borrow their module. The solder connections on the vertical board (the one the module pluges into) develops cracks in the solder connection where the vertical board connects to the main board. The amps have a fuse that is connected in series between the input RCA shield and the secondary ground. This fuse can be blown by shorted speaker wires (shorting to chassis ground). It's a surface mount fuse that's under the main board. Virtually all of these should be checked and/or repaired by a qualified technician. There is also the possibility that the head unit is damaged (assuming the head unit is connected directly to the amp). If the shields for the RCA jacks are open, it can cause the same problems as when the shield fuse opens in the amplifier. To check the shields of the head unit, you unplug all of the RCA cables from the head unit and measure the resistance between the shield of the RCA output jack and the case of the head unit. There should be no more than ~1-2 ohms resistance between any of the RCA output jack shields and the case. If there is significant resistance or it's open, the head unit needs to be repaired.
Posted on Sep 16, 2007
SOURCE:
My husband took the rear seat out. When he put it back in,he put it on the wrong bar and forced it down.How can I get my seat unstuck and be able to use it again?
I will assume that the seat release lever releases. You'll need two people one to hold down/pull out on the release lever the other to pry it out
you'll want a small block of 1/2-3/4 " wood or some protecting material to put down to protect the floor carpet... a pry bar or equivalent. there is a metal frame at the rear you'll be prying up and on.
Hope this helps
model make year would help me too?.
Jan 08, 2018 | Seat Cars & Trucks
Where is fuse box located on 2005 sts cadillac
which one ? has four
Fuse Block - Left Rear
In the passenger compartment, under the left side of the rear seat carpet
Fuse Block - Right Rear
In the passenger compartment, under the right side of the rear seat carpet
Fuse Block - Steering Column Fuse Box or Holder
In the back of the left I/P knee bolster to the left of the steering column
Fuse Block - Underhood
Right side of the engine compartment
Sep 03, 2017 | Cadillac Cars & Trucks
Can't find the interior fuse box on a Cadillac CTS 07...looked under the back seat not there.
This Cadillac factory service info . Doesn't lie ! your vehicle has four fuse boxes !
In the passenger compartment, under the left side of the rear seat at carpet
Power and Grounding Component Views
Electrical Center Identification Views
In the passenger compartment, under the right side of the rear seat at carpet
In the passenger compartment, behind the driver knee bolster, at the base of the steering column near C202
In the engine compartment, in the right front corner
Aug 23, 2016 | Cadillac Cars & Trucks
I just purchased a 2005 cadilllac srx v8 n i cannot get the third row seat tto function? Help?
Rear Seat Switches
There are three push button switches that are used to operate the power folding seat; front stow switch, rear stow switch, and recline switch. The front stow switch is located in the right rear quarter trim panel just behind the second row seat. The rear stow and recline switches are located in the right rear trim panel just inside the liftgate. Battery positive voltage is supplied at all times to all three switches from the FFS SW Fuse located in the left rear fuse block. The folding seat will operate only in a supervised mode, i.e. press and hold the selected switch button through the entire cycle of operation, or release the switch when the desired seat position is reached. When any folding seat switch is pressed, it sends a 12 volt signal through the switch signal circuit to the RSM. The RSM then commands the appropriate seat motors to move in response to the switch signal.
Rear Seat Module and Power and Ground
The rear seat module controls the position of the third row seat. When commanded it moves the seat from the seated position to the stowed position, or, from the stowed position to the seated position. With the seat in the seated position, the RSM can also move the angle of the seat back forward or rearward.
Battery positive voltage is supplied at all times to the module through the battery positive voltage circuit and the FFSM fuse located in the left rear fuse block. This voltage is used to power up the RSM and also to apply power to the seat motors when commanded. The RSM is grounded through the module ground circuit and G401.
The first place to start would be check the fuse's .Do you know where the left rear fuse block is located ? Fuse Block - Left Rear
In the passenger compartment, near the left side of the rear seat under the carpet
If the fuse is good next thing to do would be ,have check for DTC'S in the rear seat module ! This has nothing to do with check engine light or OBD 2 diagnostic trouble codes an a code reader for said OBD2 codes will not work . Would need a factory scan tool to check these codes.
DTC B1395
Battery positive voltage is supplied at all times to the rear seat load floor switch and the rear seat position switch by the rear seat module (RSM). The RSM monitors these battery positive voltage supply circuits for the protection of internal circuitry of the module.
DTC B1395 Device Voltage Reference Output 1 Circuit
DTC B1420 Device Voltage
Battery positive voltage is supplied at all times to the seat adjuster switch and the memory seat module (MSM) through the same circuit. The MSM uses this battery voltage input to determine if battery positive voltage is applied to the seat adjuster switch.
DTC B1545 Seat Stow Switch 1 Circuit
DTC B1546, Seat Stow Switch 2 Circuit
DTC B3729 Seat Recline Control Switch
DTC B1735 Seat Front Up Switch Circuit
DTC B1740 Seat Front Down Switch Circuit
DTC B1745 Seat Rear Up Switch Circuit
DTC B1750 Seat Rear Down Switch Circuit
DTC B1755 Seat Assembly Horizontal Forward Switch Circuit
DTC B1760 Seat Assembly Horizontal Rearward Switch Circuit
DTC B1815 Seat Recline Forward Switch Circuit
DTC B1820 Seat Recline Rearward Switch Circuit
Just from looking at the factory service info , I'd say you would be bet off just taking this to the dealer !
The first plase
May 28, 2016 | 2005 Cadillac SRX
How many Fuse box Cadillac / srx 2005
There are a few......one or more in the engine compartment, one or more under or around the dash, one or more under the seats.
Mar 11, 2016 | Cadillac Cars & Trucks
What do I look for to fix the Power seats and power tilt steering has no power
A control module ! Electronics The steering column has a tilt/telescoping control system that consists of an electronic control module capable of class 2 serial data communication, a steering column power assembly with positioning motor and sensor, and a steering column control switch. The multi-function lever provides for the control of the headlamp high beams, and the windshield washer and wiper.
The tilt/telescoping steering column in/out/up/down switch is an input to the driver position module (DPM). The tilt/telescoping drive motor is an output function of the DPM.
Steering column memory settings are stored in the DPM. The steering column position sensor is an internal part of the tilt/telescoping motor assemblies, and is an input to the DPM. The DPM uses the position sensor input when storing and recalling memory settings.
Same thing with the seats , electronic control module .
Battery positive voltage is supplied at all times to the memory seat module (MSM) through the battery positive voltage circuit from the POWER SEATS circuit breaker located instrument panel (I/P) fuse block. This voltage is used to power up MSM and also to apply power to the seat motors when commanded. Battery positive voltage from the TILT/TELE SW/MEM SEAT MOD fuse located in the body control module (BCM) fuse block that supplies voltage to the seat adjuster switch and the memory function switch, also supplies voltage to the MSM. The MSM monitors this voltage circuit in order to determine if battery voltage is supplied to the seat adjuster switch. The MSM is grounded through the module ground circuit and G301.
Body Control Module (BCM)
RH footwell, mounted to the toe board, behind the carpet
Nov 05, 2015 | 2006 Cadillac XLR
Carpets are wet under driver and passenger front seats neat the rear mounts of the seats. What could cause this and how can it be fixed? Thank you
A leaking heater core will allow water to run out of the case under the dash and pool under the carpet.
Nov 18, 2014 | 2000 Jaguar S-Type
My tail lights and dash lights keep flcking n and off in my 2007 pontiac g5
shorted wiring , usually found under carpet area towards rear passenger area. removal of rear seat required (battery under seat) I have found breaks usually around driver seat mounting ( driver seat removal may also be required to find break/short)
Jan 21, 2014 | Cars & Trucks
Replace battery under rear seat cushion
just grab the seat from the edge at carpet on the bottom and pull upwards in one swift motion. you've another fuse block under there as well
Jul 06, 2013 | 2003 Cadillac Deville
How did you remove the front power seats in 2009 GMC Acadia?
Two bolt behind the rear seat tracks under little covers, the lift up the back of the seat and pull the seat assembly towards the rear, the you have your electrical connectors
Feb 19, 2013 | 2009 GMC Acadia
Kicker ZR360 Car Audio Amplifier Logo
369 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
