I want install viewsat platinum on my pc
Please tell me how i do for that my pc reconize a viewsat platinum. i connect the serial cable of 9 pin but the pc not reconize it.
  • ben15 Feb 18, 2008
    yea i ahve the same problem and i don't know what is wrong
    Genius:
  • 1,153 Answers
There are different kinds of 9 pin sc, you have straight and null modem cable if you have tried one then try other.
Posted on Sep 21, 2007
SOURCE:
Trying to connect a USB to the serial port of a Bernina Sewing Machine (Bernina 170). Has been working for a couple of years and has stopped all of a sudden. Does not work on and XP PC, Vista or win 7....
The Dynex adapter does not have any numbers on it. It was the one that is only about a foot in length and has a square center piece that houses the conversion electronics. Standard 9 pin RS-232 male plug on one end and the standard USB plug on the other end. I purchased it within the last month at BestBuy here in Austin TX.
Oct 28, 2010 | Bernina Artista 170
The serial number not working.
Please visit http://serials.ws and search for Sony Vegas Movie Studio Platinum 9 Full Version for PC. Then it searches with different results. choose appropriate one .
Nov 03, 2009 | Sony Vegas Movie Studio Platinum 9 for PC
Viewsat platinum lite 4 line, is dead.
Those four lines are usually hardware related.
When you say you tried to download the latest "fix".
What "fix" are you talking about?
Mar 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Programing a uniden BC246T
Not all programming software supports usb. Either find software that supports usb or you can buy add on cards to your pc that will give you a serial port. Hope this helps
Jan 26, 2009 | Uniden BC246T Handheld Scanner
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Connecting to a P.C
It it really has 11 pins I'm not sure but then my guess is that this is the service port connector which normally should have 9 pins. A vga connector has 15 pins and LG (as far as I know) uses standard 9 pin serial ports for service and plain old dvi or vga ports for connecting a computer.
Please visit Hardware Book for more info on connectors and cables.
Jan 15, 2008 | LG RZ-20LA70 20 in. LCD Television
Viewsat platinum
make sure the receiver is off using the switch on the back. connect serial cable.. open unloader program on computer, pick the bin you want to upload. click pc to stb.. after the slide bar appears turn of the viewsat... it should start to dl now.. wait.. when the computer says finished, don't turn off the viewsat yet. the viewsat will auto start.. if it doesn't wait till the software is finished ,, the screen will come back to a channel.. If no picture go and set up the antenna.
Sep 20, 2007 | GPS
E200 Serial Port URGENT
You will not find any matching connector to connect the JK-744 host adapter for attaching to the 9 pin serial port on the pc. If you want full pinout details please contact me directly. Please do include some information on what you are trying to achieve. Maybe I can be of help in that department. I however have a feeling that trying any micro surgery on the JK-744 or trying any kind of non Casio adapter is likely to mess up the JK-744 device itself.
Sep 05, 2005 | Casio Cassiopeia E-200 Pocket PC
146 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
