Question about Panasonic MC-V7710 Bagless Upright Vacuum
Panasonic Quickdraw 2
I just bought one of these, but when I press the side pedal, it won't recline so I can use it. HELP! Is there anything I can do to get it going?
0 characters
1 Points
I just bought a Hoover Air Lite, and the mechanism that moves the belt isn't doing anything, I tried resetting the brushroll but that didn't do anything. Why is it not working and what can I do to fi
Hi Brian! The vacuum must be in vacuum mode for the brushes to spin. Try these trouble shooting steps below to get your brushes spinning.
1. Power the vacuum on.
2. Recline the handle by securing the nozzle and pulling the handle back.
3. Press the brushroll on/off button located directly next to power button.
The brushes should begin to spin, if not repeat the same steps only you will press the brushroll on/off button twice consecutively. This is the brushroll reset procedure. Hope this works out for you!
Oct 02, 2014 | Hoover Vacuums
Will not go into carpet drive what do i do?
Hi Jack, it's Jack at Dyson.
I'm sorry to hear you're having an issue with your DC24. If the machine won't recline when you press the handle release pedal, we'd need to take some further details to confirm what is needed to resolve this. If a repair is needed, we can also confirm if this is covered under our 5-year parts and labour guarantee.
When you have your machine to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll look forward to speaking with you.
Aug 26, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson will not recline
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty reclining your DC28. This can sometimes be caused if an object - for example, a pen that's accidentally been vacuumed up - is jamming the changeover valve. This is easy to check for using the airway inspection port:
If you're unable to find anything jamming the changeover valve but continue to have difficulty reclining your vacuum, please get in touch directly so our experts can provide further assistance. If a repair or a replacement part is needed we can also confirm if this is covered under our 5-year warranty. You can reach us on 1-866-693-9766 (US), or 1-877-397-6622 (CA)
Jul 21, 2014 | Dyson DC28 Animal Upright Vacuum New DC 28...
Why beter bar dosent spin while in the vaccum mode only in up right position ?
Hello! The air pressure from the motor is most likely spinning the brushes in the upright position. This vacuum has a brush-roll on/off pedal located on the left side of the cleaner. To activate the brushes, power the vacuum on, recline the handle and then press the brush-roll on/off pedal. The brushes should begin to spin. If they do not the belt may need to be replaced. Hope this helps!
Jul 12, 2014 | Hoover Vacuums
How do i fix a stuck release pedal
If your stabiliser pedal seems to be jammed, it may just need realigning. This is simple to do by following the steps shown in the video below.
If you'd like some further advice from our experts after giving this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If your machine needs a repair, we can also confirm if this is covered under your Dyson guarantee. Please do not attempt to dismantle the vacuum yourself as this could void any guarantee on your machine.
Jun 18, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Brush won`t spin on brand new vacuum
Hi! Many of our vacuums include a brushroll shut-off feature that needs to be activated in order for the brushes to spin. The brushroll shut-off pedal is usually located on the right side of the cleaner on the hood. Your instruction manual will show you exactly where your brushroll shut off pedal/button is located if your vacuum has this feature. Also, on many models the brushes will not spin when locked in the upright position. The handle must be reclined for the brushes to spin. Hope this helps!
Jun 13, 2014 | Hoover Vacuums
Dc25 animal brush is not spinning,belt is ok,and thers no strainge noises or smells from it.
Hi Kevin,
Thank you for your inquiry. I am sorry to hear about this issue with your DC25 brush bar. Assuming you have already tried cleaning the brush of any obstructions, following the instructions below may resolve the issue:
1) Plug your machine into the power outlet
2) Locate the grey brush bar button next to your power button
3) With the machine turned off, press and hold the brush button down for 10 seconds
4) Release the grey brush button, step on the foot pedal to recline the machine
5) Press the power button to power on the machine
6) Check to see if the brush rotates
If you have any additional questions or require further assistance, please contact our US Dyson Helpline toll-free at 1-(866) 693-9766 or our UK support colleagues at 0800 298 0298. Thank you very much for your time.
Oct 06, 2013 | Dyson DC25 Vacuum
Can't get detachable hose to **** air
have you checked the hose to see if its split or ripped very comon fault hope is will help many thanks nick...
Nov 11, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Sanitaire vacuum cleaner sc684
supposed to be a foot pedal on the left rear of the motor housing
Aug 24, 2008 | Eureka Sanitaire SC4570 Bagged Upright...
Panasonic MC-V7710 Bagless Upright Vacuum Logo
124 people viewed this question
Top Panasonic Vacuums Experts
Ryan S
Ryan S
Jim Parker
Jim Parker
Roger Potts
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
