Question about Comet BXD2527 Pressure Washer Pump
Need a service manual for comet fds super (300) pressure washer
Want to service and check valves burner etc,on my comet fds super 300 hot/cold pressure washer electric plus diesel burner.
  • mlpb May 04, 2009
    many thanks for the information,only just got round to veiwing as been without a computer for few weeks.
3 Suggested Answers
  • 68 Answers
SOURCE: It will not dispense the soap.
You need to adjust the nozzle on the end of the lance so the machine will draw chemical at low pressure.
Posted on Apr 21, 2010
Testimonial: "Thanks for your help, I will give that a try."
kel1guy2002
  • 3740 Answers
SOURCE: I have a Pressure Washer
Derek, Hi and welcome to FixYa. I am Kelly.
I just now happened across your post and note it is 3 months old. Hopefully you already have the problem solved.
If not.. looking at the pump history of having the un-loader valve replaced it sure seems that the current un-loader valve is sticking. When an un-loader valve is removed the internal housing is sanded smooth and everything about the un-loader valve is coated with Lubriplate #105 White Grease. I get the feeling that who ever did the un-loader valve repair failed to sand / clean the housing and use White Grease for the final assembly.
You should remove the valve... Sand the housing and get some Lubriplate #105 white grease (auto parts store) in a tube. Lubricate it liberally and reassemble it. If should work fine after that.
Thanks for choosing FixYa,
Kelly
Posted on Dec 07, 2010
Calve gap on a Honda GX390 engine? Hi, I have a gas power washer with a Honda GX390 engine in it. I need to adjust the valves. Any idea what the gaps are supposed to be? Also do I adjust on a cold engine...
Hi intake is 0.15+ or - 0.02mm and exhaust is 0.20 + or- 0.02mm cold engine..I always double check after running the engine again...you can check out the owners and service manual and all specs here http://cdn.powerequipment.honda.com/engines/pdf/manuals/37Z5F602.pdf
Feb 23, 2015 | Honda Garden
I purchased a Bosch 300 series from Sears. My son was home when the technicians installed the washer and dryer. They connected cold water pipe with the hot water hose and the other way around. The mac
Hello Ion;
My name is Peter. I am a retired (excuse the expression) Sears field service appliance technician.
First, The people who installed your appliances are not technicians. Sears contracts delivery people to deliver appliances.
Often, It is not uncommon for me to make service calls the day after an appliance has been installed.
First, shut both the hot and cold water supply valves off. Remove the connection hoses from the valves. Be careful, where I am going with this is, after years of not being operated your shut off valves my be bad and partially block with rubber seating material. So, when you turn off the valves some water will still be in the lines. Your valves could be turned off, faulty and full open.
Now, with the hoses removed, open each water valve. Check for full flow. If you have a blocked cold water valve you will get an error code.
Next, the connections on your washer are marked; 'C' & 'H'. Make sure you have the hot water line to the 'H' and the cold water line to the 'C'. You will get an error code if the lines are reversed.
Nov 11, 2014 | Bosch Vision 300 Series 6.7 cu. ft....
I would like a karcher instruction manual for a HDS650 pressure washer
I believe the HDS sends spark to the ignitor any time the machine is on ( hot or cold) You should hear the crackle of the ignitor in the burner area. Perhaps the ignitor rods are not properly aligned. Perhaps your ignitor coil is bad. There are several safety switches and the thermostat that would keep the burner from firing if they are bad. There is a pressure switch that turns on and off the motor for hot or cold operation. That is apparently working. I think there is a flow switch that turns off the burner. The thermostat might not be opening and closing contacts and that will keep the burner from working. I believe there is a high temperature safety switch as well.
Jul 15, 2014 | Garden
Y a t'il un niveau d'huile dans la comet bxd 2525
L'utiliser cette pompe sans huile est une erreur fatale:
[PDF]COMET PLUNGER PUMP SERVICE MANUAL INDEX
www.cometpump.com/_images/support/Pump_Repair_Manual.pdfLUBRICATION: Make sure crankcase is filled with Comet Pump oil. Running this pump without oil will cause damage and void any warranties. Change the pump ..
Mar 14, 2014 | Comet BXD 2525 G Pressure Washer Pump
B&E pressure washer w/ comet 3540 pump
Things to check:
1) is water coming out of the bottom of the pump or is the oil in the crankcase high level and milky yellow. If so your seals are bad.
2) Your check valves might not be seating properly. A couple of fouled check vavles will cause either no pressure or pulsing pressure. A good inlet water strainer keeps foreign matter out of valves. But valves do wear out and get build up that keeps them from working right.
3) Your unloader valve might be worn or fouled. Bad unloader would usually show as low pressure ( but more than hose pressure) or low volume out the trigger nozzle.
Valves are your most likely problem.
Feb 17, 2014 | Comet Pressure Washer Hw3540s Triplex Pump...
Comet pressure washer is pulsating
check your check valves.
or one of the wobble plate pistons is not working right ( broken, broken spring etc)
Aug 17, 2013 | Comet AXD 3020 G Pressure Washer Pump
Comet tw 5050 mix oil and water
what you have is a bad seal or a crack within the pump crack more common if any water was left in it during the cold winter
Jun 22, 2012 | Comet Pressure Washer Tw5050 Triplex Pump...
My Maytag Neptune FAV6800 washing machine overfills on the rinse cycle. Pulling the electric power does not stop the water flow. I have to turn off the water at the faucet feeding the hose. It seems to...
If you pull the power to the machine and water continues to flow then the water inlet valve is stuck open. You will need to replace the water inlet valve. The Service manual will step you thru the process.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
The water inlet valve is p/n 25001046 Substitution: 12002242 Water valve shop around for best price.
Is this Cold water inlet valve issue? If so and you only do Cold water wash/rinse like me you could switch the fill hose connections from hot to cold to hot at the faucet. Turn the hot water faucet valve off and select Warm/Warm temp selection and you will be filling with cold water wash/rinse. Maybe that would hold you over until you replace the Water Inlet Valve assembly.
You can check out your pressure switch transitions as I had this poster do for his issue at this link http://www.fixya.com/support/t5471295-washer_fills_water_begins_agitate_but
His issue seems to be a definite stuck pressure switch not water inlet valve such as yours. Check to make sure your pressure switch is OK by watching the fill point transitions as I mention in the post.
If you machine is a series 12 or above the Low and Mid fill pressure switch transitions will toggle at the same time. Series 12 and above us a 2 level pressure switch. Series 10 and 1 use a 3 level pressure switch.
Good Luck………….. D*ick
Aug 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
No water going in
Hello mariel_black,
If you have good water pressure at the washer source valves I would shut both the Hot and Cold water source supply valves off then remove the water inlet hoses at the back of the washer and inspect the water inlet screens for sediment blockage.
The washer inlet screens look like this;
If the above items check OK reconnect washer supply hoses and turn on water supply valves. If we are talking about a FAV6800AW/FAV9800AW washer then I would go into Service Mode Board Output Test page 16 of the Service Manual and turn on the Hot and Cold water valves and see if the machine water inlet solenoids operate and release water into the wash tub. I will summarize how to get into Service Mode and perform the check of the Hot/Cold washer inlet solenoids.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Press the Delicates key the display will read something like “ot” the lid will lock. Now press Spin Only key this will turn on the cold water valve, do you here water flow into the washer? Press the Spin Only key to shut the cold water valve off.
Now press Normal key, do you here water flow into the washer? Press the Normal key to shut the valve off or the off key to get out of Service Mode. If you don’t hear either Hot/Cold water inlet valve operate then you have a bad solenoid or loss of 120VAC applied to that solenoid valve and more troubleshooting may need to take place and possible replacement of the washer water inlet valve assembly. Post back if you have questions.
Jun 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Comet BXD2527 Pressure Washer Pump Logo
656 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
