Question about THQ The Lawnmower Man
Lawnmower will start but will not stay on
The lawnmower will start after pumping gas, but dies immediately after starting. I changed out gas tank because I could not get the screw out of the filter. I have a Weedeater 300 series push lawnmower. I changed oil, sparkplug, and gas. I put all parts back on including springs when I replaced gas tank. I need mower to mow a lot that no one else will mow and owner is dead. Can not afford to keep buying or having lawn mower fixed (they want $52.+ to even look at it.) Thank you for any help you can give me.
  • gpjones777 Apr 15, 2009
    Thanks. I might try to take off the gas tank and see if all is connected or if there is a leak anywhere.
  • gpjones777 Apr 24, 2009
    SFHS, thank you for your response. Where did you get new springs? I live in a small town and our Walmart doesn't carry much of anything. Thank you.
I had the same problem, what you need to do is adjust your throttle. To do that you there is a switch right in front of the filter. If you are looking right at it pull it all the way to left. If this dosen't work then check the springs that are connected to that switch they have a bad habit of coming loose. I had to replace all of my springs. Hope that helps.
Posted on Apr 23, 2009
  • 23 Answers
It sounds like you have a leak in your gas line
Posted on Apr 15, 2009
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Why won't it stay running?
May have drawn sediment up into the fuel system. Is it carb or fuel injection ?
Aug 08, 2015 | Cars & Trucks
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
Lawnmower starts and dies... where is the main jet for the carb?
try cleaning the air filter, then a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season.
Aug 27, 2010 | Poulan "Poulan" Push Mower
My troybuilt yard pony riding lawnmower will start with the choke fully open and then dies immediatly when you take the choke off. It will only start and run with the choke fully open, but dies after 20-30...
Do you mean that you can start it normally using the choke (that would be choke CLOSED), but then it dies immediately when you move it to run (that would be choke OPEN)? And if you leave the choke in the starting position that it dies after 20-30 seconds?----- If I have that all right, then you definitely have a restriction in the gas supply. Drain all of the gas from the mower and don't use any old gas. If you have any more old gas (from last season) don't use it. If this mower has a gas filter, replace it. Put just a little fresh gas in the tank plus a little of the cleaner. Start it up, do that a few times if needed. Use a fuel additive such as Sea Foam to keep the gas from gumming up so fast.
Mar 15, 2010 | Troy-Bilt Garden
Someone put sugar in my Honda lawnmower's gas tank.
You will need to flush out the carburetor as well. The sugar is clogging up the port that **** gas thru them to the intake.
Dec 18, 2009 | Garden
Mower will not start
you could have water in gas,look in the gas tank for any bubbles floating on bottom of tank this is water empty gas from tank and remove carburetor bowl too remove water from it .
May 13, 2009 | Garden
1998 dodge intrepid 2.7 engine
try putting fuel injection cleaner in the gas tank
Jan 26, 2009 | 1998 Dodge Intrepid
Engine dies while still driving. May start up immediately, may start in 5 mintes, 30 minutes, or longer.
does ur car heat up? if not please check your ground coz it may be rusted. What I suppose it is: your fuel pump. they die slow. Immediately it dies, hit the gas tank with a 2x4 and if your ground is good, it may start or you'll hear the pump turn on immediately you put it on ign.
Jul 28, 2008 | 1994 Oldsmobile 88
THQ The Lawnmower Man Logo
1,798 people viewed this question
Top THQ Video Game Consoles & Games Experts
Jimmer_9
Level 1 Expert
James Wishart
Sandeep Kumar
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
