Question about Hitachi 46F510 46" Projection HDTV
My lamp light is blinking and the temp light is too
Ihava a warranty but i dont know where to go. i use to go circuit city, but now their close and i don't know what to do. please hlp me
  • 16 Answers
If you bought the TV before December 1, 2006,
your service plan is provided by National Product Care Company or Service Saver Incorporated.
Call their administrator at 1.800.286.0470.
Televisions purchased after Dec. 1, 2006: 1.800.878.1167
I would help with the actual problem but I can't read the entire subject line; it is too long. Sorry.
Source:
http://www.assurantsolutions.com/news/news_021009.html
Posted on Apr 15, 2009
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and...
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
Oct 14, 2011 | Samsung DLP HL-P5663W 56" TV
I have my samsung almost for 3 years. and cahnge the original lamp after that i replaced the lamps 3 times more.i dont kwon is normal. but i think is something else. thank god i dont pay anything for the...
use only original samsung lamp with the housing and socket attatched.
The lamp door switch may be intermittent,so you are temporarily fixing it by open and closing the door. The ballast can cause the failure as well. Avoid short period off and on times as turning the set back on in intervals less than an hour will cause microscopic cracks in the glass because the lamp needs too cool down to room temp before it is restarted for ultimate life........I hope this helps!!
Jun 03, 2010 | Samsung DLP HL-P5663W 56" TV
Power light is on, temp light blinks, and lamp light blinks, no picture.
Its possible that your lamp is bad, or you have not closed the lamp cover properly. If you don't close it, the sensor will tell the TV not to turn on.
Feb 04, 2010 | Hitachi 42V715 42" HDTV
The power light keeps on blinking red three times with no picture
OK. Great! 3 times is simple. The lamp door is not properly closed or the lamp is not fully engaged into the socket. Most likely it is a door issue, though.
Mar 24, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
BLINKING TEMP LIGHT ON HP VP6110 PROJECTOR
All projectors are cooled by the use of a fan. The light chamber has its owned fan to extract the excessive heat generated by lamp. Check to see if this fan, close to the fan is operating.
Mar 23, 2009 | HP Digital Projector Vp6110 Multimedia...
No sound no picture
The temp light blinking means that the fan is not running. The lamp light blinking means that the lamp door os not secure. Check to be sure that all access doors are closed properly. There are safety interlocks to prevent the set from powering up if all doors are not properly closed. Did you replace the lamp recently? Re-open the access door and be sure that it is closed completely and straight.
Let me know if you have further problems.
Dan
Jan 14, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi #55VS69A
I had this same problem over the summer, I had my TV for two years before it went out. You need a new lamp. The lamp is not hard to replace on your own. However, you MUST make sure that you do not touch the lamp (the bulb part) in anyway. If you do your new lamp will not last as long. You can order the lamps online. They range anywhere from 150-300 dollars online. However, I found a TV repair company in my city that only charged me 100.00 for the lamp and they told me If I took out the box that holds the lamp they would replace the lamp for me. They also gave me a 1 yr warrantee on the lamp. All I had to do was un-screw the box from the back of the TV take the box to the TV repair company and I placed the box back into my TV. My TV works. While going through this process, I learned that these lamps go out all the time, the more you watch the TV the more often you'll replace the lamp. I was told from the repair company it could be as often as every year. The Lamp does have MURCURY in it so if you replace the lamp on your own be careful and have it recycled. If you live in SLC UT the repair company I went though was Village TV Sales and Service.
Jul 15, 2008 | Hitachi 55VS69 55" Projection HDTV
Don't know what is going on
Check the door lamp switch & lamp pwr switch, boss on the door or lamp assy may not close switch. apply tape to boss
Mar 15, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 46F510 46" Projection HDTV Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
