Question about Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
My router is not accepting or showing my phone line.
All the lights come on but that one.at first it worked,then when id try to make a call it would be a busy sound on my end.then it quit showing the phone line at all.please help.ive changed phone cords till im tired,ive even tried reseting.
The first and second light burning, but the third and fourth do not. This is also with theother device. Why is it a known fault or not
Posted on Apr 09, 2011
  • 3 Answers
Ahhhhhhhh, you need a new router...
Posted on Jul 27, 2009
Adsl flashing red light
talk to your isp supplier and confirm they are sending you signal... check the phone line to confirm signal (put a phone on and get tone).... reboot the router if that doesn't work set the router to default (button push) and see if that allows you to reprogram the router to your specs usually requires putting in a login user id and password
Nov 11, 2013 | Comtrend CT-520 Router
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
Phone system does not accept blocked caller ID
Wow, that really tests my memory...oh wait. I have it on a bookmark :-)
http://www.tech-faq.com/lass-codes.shtml
The phone system isn't blocking calls, your phone company is.
Try *87 or *68 and see if that works. You dial it into line #1.
Anonymous Call Rejection is the telco feature.
Carl
Mar 30, 2009 | Panasonic KX-T7633 Corded Phone
My line one caller ID is not working, but my other lines are.
Partner gets caller id from a carrier. If you have a caller id service it will show on your 18D
Dec 09, 2008 | Lucent PARTNER18 Corded Phone
Losing connection lately, and no caller ID??
Hello Kimberlynbil,
You actually have two problems here, one can be solved (but it's hard) the other might not be able to be solved at all.
First the hard (cost wise) to solve problem: Caller ID
What you can do is get a wireless phone that works in the 5 GHz range.
Now for the second problem which is why I suggested the solution to the second problem: Router cuts off phone and phone cuts off router.
This occurs because the router (wireless) and the phone wireless are using the same frequency spectrum 2.4 - 2.5 GHz. when the phone tries to communicate with the hand set the router sees this as an interference and ups its power slightly and this drops the phone call on the first ring which consequentially is the ring on which the data for caller id travels. once the phone senses the interference from the router it up is power slightly and then "steps on the router's transmission cutting off your wireless connection to your PC. So the phone and the computer are off line until one of them stops transmitting.
I hope this helps,
Shuttle83
Oct 23, 2008 | Linksys Wireless-G Broadband Router
Uniden CXA15198 not showing caller id
Hi! There is a small device available in the market which is a converter. By connecting this between landline and phone, caller ID start display simply.
It cost to me Rs.450/- made by Fintel. Try to get it cheaper at your place.
Try this and the problem is solved.
Nrupesh
Apr 08, 2008 | Uniden CXA15198 Twin Corded/Cordless Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Caller Id
Try changing the cord between the base unit and the phone jack. Some phones are pretty fussy about this, and when they are, it's usually the caller ID information that gets clobbered. Alternatively, try attaching the base unit to a different phone jack - preferably the jack with the shortest wiring run to where the phone service comes into your home.
Jan 29, 2008 | GE 28112EE2 Cordless Phone
Not working
Go into your routers settings, usually by typing it's ip address in your web browser and save all the settings to your hard drive or make a note of all the settings. Look to the connections menu and see if your ISP's ip address and dns servers are showing and not showing noughts, if it does show noughts your isp is at fault, if there is dns server numbers showing,look to see if there is an option to restart the router, if restart it and try again. On the router normally at the rear there should be a hard reset button which should be held in for atleast 10 seconds and let the router reboot. If non of this works, then the router is probably faulty
Apr 21, 2007 | Actiontec GT704WG Wireless Router...
Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router Logo
85 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
