Question about Kenmore Dryers
Thanks Phil for your excellent description of how to install the belt and the tensioner on my Kenmore Electric Dryer. That will be very helpful once I get to the point of removing the drum. I guess I have another initial question. What is the best way to remove the drum? Do I take off a panel on the front or side (if so, how?), or do I need to remove all of the working parts that are located at the back of the dryer and are revealed when I remove the back cover? I am not sure which is the appropriate way to approach getting the drum out in the first place. Thanks. Sorry that I am so dumb about this basic part. Thanks, Michael
  • Michael Apr 16, 2009
    Great job by the Gurus. I needed assistance on two different parts of the repair, and I got very clear and helpful advice from both people. Thanks so much. I now can dive into an electric dryer in the fuure. Great service. Michael
    Genius:
  • 1,122 Answers
Does your kenmore dryer have a top lint filter or inside filter?i'am going to guess top,remove the 2 lint filter screws,pull the top toward you and up at the same time,disconnect the lid switch jack,remove the 2 front panel screws one on each side top.pull up and out and the front panel will come off,you don't really have to take the drum out just fit the new belt around it,you should see the marks of the old belt on the drum,line it up with that,let me know how you do-mike
Posted on Apr 15, 2009
  • MIKE major Apr 16, 2009
    good job trouble shooting,don't forget you can go to this page for almost any kind of repair in your home-mike
I need a diagram on how to open up the back or front to install the dryer drum belt for my Frigidaire FLSE60RGS0. we bought the belt, and I did get a diagram on how to install belt, but doesn't show us...
Disconnect the water, vent duct, and electric connection to gain access to the rear of the machine. Be prepared to catch any water that comes out of the hoses.
On the rear of the dryer, remove the panel that's behind the dryer section (upper panel).
If the belt is intact, make a drawing of the belt's route.
If the belt is broken, remove and discard it.
Slide the new belt onto the drum to approximately where it belongs (lined up with the motor pulley). I think this model might have a groove for the belt where it rides on the drum.
With the slack portion of the belt, squeeze it to make a loop and push it through and onto the tensioner pulley on the bottom of the dryer.
Using the tensioner spring to relax the belt (pull it toward the motor pulley), slip the belt onto the motor pulley.
Check the belt by pulling on it to see if the drum, motor and tensioner are rotating freely (don't pinch your fingers!).
I am not the best at abstract description. I hope this helped.
Good luck from Detroit, MI.
Mar 09, 2011 | Frigidaire FEX831CS Top Load Stacked...
Trying to install a dryer belt on a kenmore dryer model 62622101. don't see how ya thread the belt thru the existing bracket
the belt goes through a tensioner which fastenes to the floor in a set of slots. Get the belt through that tensioner then around the motor pulley. Put the drum on the wheels in the back, lift the front (you need a helper) and put the front back on and fasten, replace the top.
Much easier to say it than to do it ... but you got this far, I have faith you can finish the job.
Thanks for using FixYa.com
a
Nov 01, 2009 | Kenmore 62622 Electric Dryer
I have a kenmore 27 inch electric dryer that when you push the start button it sounds like it starts but the drum doesn't turn. What could this be?
A clear indication that your dryer belt is broken is when the dryer drive motor runs but the drum does not rotate. A new belt is relatively inexpensive from several online or a local parts vendor, but installing it can be a bit frustrating since the dryer drum usually needs to be remove to install a replacement belt. Access to the interior of the dryer is usually necessary. For Maytag (and some Kenmore) models, the front of the dryer can be easily removed (two screws below front contour) by pulling out on the bottom of the panel and rotating up to release the top clips. Once off, place to the side, then remove four machine screws from the front drum/lint filter assembly, then remove by pullling out. Once off, place aside. Remove drum by lifting up and pulling out on drum (since the belt is broken it will not provide any resistance). Once removed, inspect the motor pulley arrangement noting the belt routing path around the motor pulley, belt tensioner, and the drum. Inspect the drum for belt wear marks, noting approximate location on drum where belt rides. Install replacement belt by routing through pulley arrangement (ridged side of belt rides againt motor pulley), then "hang" the belt on the interior backside to enable reaching the belt after reinstalling the drum. After placing the drum edge on the rear rollers, lift the front of the drum up into position, working the belt around the drum into the drum groove. Once the belt is in the groove, the drum should stay in position without lifting from the front. Check for proper pulley routing, taking care to avoid routing the belt OVER the tensioner belt keeper, i.e., route the the belt under the belt keeper to avoid belt riding on the keeper and failing prematurely. Install the front/lint filter assembly. As you manually rotate the drum, reach along the top and side of the drum and gently pull the belt out of the groove and into its normal ride position. Install the front panel, plug the unit in, start and check for proper rotation of the drum.
Oct 04, 2009 | Kenmore Dryers
Belt installation for a maytag dryer model# sde305day
Usally put dryer belt around the drum first
then around motor the tensioner pulley has to to be pulled up when you do this to get the belt around tensioner then you release the tensioner pulley to put tension on belt
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
The idler pulley on an older GE dryer does not tension the belt. The idler pulley is mounted on a spring rod, but the rod's neutral position does not tension the belt. The rod is attached to the bottom of...
Do not bend the rod you are not threading the belt right I had the same problem with one. Try searching the internet for how to thread the belt on a GE dryer. It has to go around the pullys a different way. Hope this helps.
Jun 04, 2009 | Kenmore 60172 Electric Commercial Dryer
Installing the belt around the dryer drum and pulleys. I have a broken belt and a loose pulley at the bottom of the dryer. How to I get the pulley on? Where does the pulley attach to create the proper...
you will have to take the drum out to see where the tentioner was inserted , it is in line with the motor pulley, should be a couple holes it fits into.
putting the belt on is easy , with the lined side of the belt down on the drum take the slack at the bottom with a finger holding the belt , move the belt toward the tentioner until it touches the tentioner pulley
then with your other hand help bend the tentioner pulley with the belt on it until you can touch the motor pulley with that finger , slide it off your finger onto the motor pulley and the belt is on.
let me know if you have any questions.
Phil
Apr 14, 2009 | Dryers
Belt and assembly trouble. Please help!!
Yes, there is a tension pulley but I"m at a loss as to how you're burning the belt, if not routed around the tensioner... seems to me you'd have a world of belt slack.
You might check and see if you can freely spin the drum, or if it seems to be locked-up. There may be an obstruction, keeping it from rotating... it shouldn't require so much effort.
Just a suggestion... Good luck.
Mar 05, 2009 | Kenmore 62722 Electric Dryer
Kenmore dryer
It is very much easier to replace the belt from the front, than the back, the cabinet disassembles from the front, and the mechanism remians attached to the rear plate and cabinet floor.
  • pull lint filter out
  • remove 2 screws from under lint filter
  • with putty knife or other blunt blade, release clips at front corners of cabinet top
  • tilt up cabinet top
  • remove 1screw 1/3 way down each side of front of cabinet.
  • lift off cabinet front
  • drum, motor, tensioner, are all exposed
  • lift drum out forward
  • check rollers, drum felts, nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage and you dont want to do it again next month)
  • reinstall tensioner in slots in cabinet floor, reinstall tensioner spring between tensioner and cabinet floor
    (Once the cabinet is open the tensioner mounts are easily visible)
  • loop belt around drum at the wear marks of the prior belt
  • reinstall drum on unworn bearing rollers etc
  • loop belt around motor pulley
  • pull tensioner hard against spring to end of travel
  • loop belt around tensioner
  • relax tensioner
  • spin drum by hand to ensure belt isnt going to jump off
reinstall cabinet in reverse order
~15 MINUTES, but I do 3-4 per day
Oct 07, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
71 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
