Question about Frigidaire GLTF1670A Front Load Washer
Kenmore front loader drum grinding
Our front loader washer spins with an incredibly loud noise. It sounds as if it's spinning on ball bearings that are metal to metal. It's a low almost grinding sound. this is a new sound and so loud that you can hear it throughout the whole house. The machine also smells like mold all the time and although it's not a Neptune, it sounds like it has the same issues that machine had. Any suggestions on what the grinding sound could be and how to fix it. By the way, I recently started adding vinegar to the wash cycle to try to keep the mold smell away. It's a bit better but I wonder if the vinegar, which is an acid, has caused the problem. I did a little research on vinegar in washing machines and found many sites which suggested using it to help clean the machine. Help please....
  • 641 Answers
This can be a symptom of drum bearing wear. A quick check for wear is to see if the inner drum moves up and down relative to the fixed outer drum. It should only move a minute amount. If it moves more than a millimeter or two, it is probably worn bearings. Regarding the bad smell - Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Posted on Sep 14, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
Dec 03, 2015 | Washing Machines
Troubleshooting kenmore washer front loader 417 390 12890
basket rubbing to the door gasket ..could be bad bearing or broken spider
Mar 01, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Why does my washer make noise before the spin cycle
Depending on what the noise sounds like, these front load washers have rear bearing issues. The drum bearing is just not strong enough to support the weight and the larger the drum the more weight and I doubt they use larger bearings for more cubic feet machines. They need a buddy bearing or some sort of support to take all the weight off the rear bearing.
Nov 19, 2013 | Kenmore HE2 Plus Front Load Washer
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
I have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Aug 31, 2012 | Kenmore Washing Machines
Loud grinding noise when on when it starts to spin?
If it is a front loader, then it sounds like the drum bearings have failed, spin the drum from the front by hand, if it feels rough or is noisy, then bearings have failed.
Jan 26, 2011 | Washing Machines
My kenmore front loading washer is screeching during spin cycle and seems to be spinning poorly at times. what is going on?
The wash drum should spin smoothly by hand without much noise. It is supported with two sets of ball bearings. If the water seal fails, water starts to leak into the inner bearing and they start to rust causing a loud noise especially during the spin cycle. The only way to fix it is to replace the bearings and seal. It a big and expensive job to replace the bearings since you literally need to take your washer apart to get to the bearings. Sorry.
Oct 07, 2010 | Kenmore 44102 Front Load Washer
I get a loud noise during the spin cycle - sounds like the ball bearings are wearing off. Is there a way to fix this? How?
Yip could well be drum bearing failure, itss quite a big job / expensive......Depending on age may not be worthwhile!!
Jun 24, 2010 | Kenmore 43052 Front Load Washer
Loud grinding noise only during the spin cycle.
Try looking at the solution for loud noise during spin with gray water in drain. This also sounds like the bearings on the shaft supporting the stainless steel drum, in the aft half of the outer drum.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
261 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
