Question about Brother MFC-8460N All-In-One Printer
Borther MFC8460n how do you reset the fax journal report to clear
How do you reset the fax journal report to clear both incoming faxes and outgoing faxes for the Borther MCF 8460N?
Thanks.
Mix-it-up
  • 832 Answers
SOURCE: Unable to Receive Incomming Fax's
OK.
Posted on Oct 17, 2007
ctf1800
  • 4402 Answers
SOURCE: fax memory
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000100/000095/faq000195_006.html?reg=us&c=mx&lang=es&prod=mfc420cn_us&Cat=11&ot=us_ot
Posted on Dec 18, 2007
kman203
  • 99 Answers
SOURCE: Fax says "Out of Memory"
Unplug Fax machine for a minute or two. Plug back in and try again.
Hope this helps!
Posted on Mar 24, 2008
SOURCE: Cannot Send or Receive Faxes
brother mfc 240c cannot receive fax. it can send fax only.
Posted on Sep 01, 2008
  • 54 Answers
SOURCE: will not feed paper
Replace the paper feeding (PF) kit and the fuser. Instructions on how to do so maybe found on this manual.
Posted on Apr 13, 2009
How to retrieve 1 week ago fax history from brother 2280 fax machine
Printing reports
How to print a report
1 Press Reports.
2 Press ? or ? to select the report you want.
Press Menu/Set.
-OR-
Enter the number of the report you want to print.
For example, press 2 to print the Help List.
Following reports are available
1.Transmission
Prints a Transmission Verification Report for your last transmission.
2.Help List
Prints the Help List so you can see at-a-glance how to quickly program your machine.
3.Quick-Dial
Lists names and numbers stored in the One-Touch and Speed-Dial memory, in numerical order.
4.Fax Journal
Lists information about the last incoming and outgoing faxes. (TX means Transmit.) (RX means Receive.)
5.User Settings
Lists your settings.
6.Network Config (MFC-7225N only)
Lists your Network settings.
Jun 11, 2011 | Office Equipment & Supplies
How do I set the Fax 2910 Brother to print a fax confirmation each time? Thanks
Using the Reports Key
Five reports are available:
1 HELP LIST: Prints the Menu Table so you can see at-a-glance how to quickly program every menu selection.
2 AUTO DIAL: Lists names and numbers stored in Speed Dial and One Touch Dial (FAX models only) memory, in numerical order.
3 FAX ACTIVITY: Lists information about the last 200 incoming and outgoing faxes. TX means Transmit; RX means Receive.
4 TRANSMISSION: (CONFIRMATION) Prints a Transmission Verification Report for your last transmission.
5 USER SETTINGS: Lists settings for GENERAL SETUP, SETUP RECEIVE, SETUP SEND, SETUP REPORTS, and TEL SERVICE.
The settings for REMOTE FAX OPT are included.
Jan 18, 2011 | Brother IntelliFax-2820 Laser Fax
BROTHER MFC8840D IS THERE A WAY TO SHOW THAT I SENT A FAX TO A SPECIFIC PHONE NUMBER AT THE END OF MAY?
Possibly. The Fax Journal has the last 200 faxes (incoming or outgoing). Press Menu then select Fax (up and down arrows). Press Set, and use the navigation keys until Setup Reports or Report Settings appears. Then press Set and use the navigation keys to find the Act. Interval or Journal Period. Press Set again and a length of time for the Journal (anything but off). Press Set again. (If you use the 7 day count-down, you will get additional queries for day of week and time of day for the start of the count-down.) Press Stop/Exit and the Activity Report will print when 200 faxes are in memory, the memory is full or the desired time frame. (The setting of 50 faxes will print at every 50 faxes.) After printing the report, these entries will be deleted.
I hope this helps.
(if the report was already generated, you won't get the old entries. Similarly if the memory was cleared after an Out Of Memory error, you won't find this entry. If Fax Storage was on, you may be able to actual get the original Fax. Menu > Fax > Remote Fax Opt > Print Fax or Print Document. Then Start and when all stored Faxes print hit Stop/Esc.)
Aug 05, 2010 | Brother MFC-8840D All-In-One Laser Printer
Need to know how to print FAX report showing when items were faxed to what number on Brother IntelliFAX 2820
Press the report button and chose Fax journal with the down arrows and press menu/set. This will print the last 50 incomming and outgoing faxes.
Dec 28, 2009 | Brother IntelliFax-2820 Laser Fax
How do i get my brother intellifax 2820 to time stamp the faxes i receive.
From everything that I've seen I don't see any way to tim stamp incoming faxes. Almost all fax machines should automatically time stamp outgoing faxes unless the user has removed that function for some reason. If you are getting faxes from people that don't include time stamps than the next best thing is to use the journaling feature. The 2820 can print a journal of past incoming faxes that will include timestamps of the past faxes recieved in either 6,12,24 hour or 2, 7 day intervals. The default is every 50 faxes. To change the settings:
Press Menu/Set, 2,4,2
2. Journal Period
Use Arrows to choose an interval
Press Menu/Set
Press Stop/Exit
Jun 22, 2009 | Brother IntelliFax-2820 Laser Fax
Transmission report
In programming you will find under "Reports" a setting for transmission confirmation report. Typically this is not turned on as a factory setting because fo our new green attitude. It wastes paper. Any time you need to confirm a transmission you can simply press the report button( some times followed by the "Set" button) and get a list fo the last 40 transactions( incoming and outgoing combined)
Jun 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Retrieval of fax from memory
No. And even if you could, it would simply list the # the fax was received from, and the # of pages. The actual fax is not retained.
May 14, 2009 | Office Equipment & Supplies
We would appreciate instructions on how to print a report that shows both incoming and outgoing transmissions. I only figured out how to print transmission on outgoing. Incoming transmission is what we...
Most machines will prnt an "activity report" ACT showing both Transmission TX and recieve RX.
If you got far enough to print the transmission report you you should see an option for activity or RX report.
Without the make and model all I can say is you are likely on the right track.
Hope this helps
Apr 24, 2009 | Office Equipment & Supplies
PANASONIC UF 8000 FAX
Normally function/Menu and start should print the help list or a separate help button may also be provided.
Samir
Mar 13, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Brother MFC-8460N All-In-One Printer Logo
208 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
